KoTiX Wrote:I fixed and uploaded the new version!! tv scraper will follow next week
seems like that the download link for movieplayer-it-film.xml doesn't work.
Max
The link is correct, but when I try to download appear a HTTP 403:access denied error.
(I've tried with Firefox, Chrome and IE8).
Hi KoTiX,
Mind submitting to trac to trigger us to update the scraper in the repo as well?
it seem to work correctly with version 9.11 but with 10.xx it says it's unable to find the server.
Any guess? Thanks for your effort in mantaining this beautifull scraper.
olympia Wrote:Hi KoTiX,
Sure! once i update the tv scraper too I'll surely submit them to trac as usual
KoTiX Wrote:Sure! once i update the tv scraper too I'll surely submit them to trac as usual
Don't forget to also convert it to scraper addon before you submit
pierpa Wrote:Hi,
You are right
in 10.xx it was missing a tag in the search url, sorry for that and thank you for reporting it.
New 10.xx version is ready in my mediafire folder.
KoTiX Wrote:New 10.xx version is ready in my mediafire folder.
I use a very recent nightly build, I don't know if the 10.xx is this one
Anyway... just tried it, but I still experiencing some troubles. In all cases no film abstract is added neither infos about the director and actors. then in one case, galline in fuga, fanart and icons of the gladiator are added
xbmc (svn) updated the scraper to 1.5, but now i'm experiencing same problem too.
The scraper, downloaded the right poster and fanart, but there is no plot or description for movies (i've scraped about 5 new film i've just added, same problem for all). I've also tried it on a already scraped movie (was scraped ok two days ago), after rescraping there is no plot.
Don't use the version that is in svn because it's still not updated yet.
For recent nightly builds you have to download from my mediafire folder (link in first post) the 10.xx version of the scraper and overwrite the one you have downloaded from xbmc repository (the folder position depends if you are using xbmc as portable or not).
Hope this can help
