ppic Wrote:hum, the last number is the db id of the show no?
yep
videodb:// - root of your video library
videodb://2 - root of your tv shows library
videodb://2/2 - tv shows titles list
videodb://2/2/
1 - "some tv show"
videodb://2/2/1/1 - season one of "some tv show"
ronie Wrote:yep
videodb://2/2/1 - "some tv show"
so, you can consider it as done
ronie Wrote:if the info is available online, yes.
next aired supports:
try to find out if season premieres are listed as such.
Well, if we know its episode 1x01 its "series premiere" and if its ?x01 then its a season premiere, right?
blacklist Wrote:Well, is we know its episode 1x01 its "series premiere" and if its ?x01 then its a season premiere, right?
that would be too easy. ;--)
ronie Wrote:how about difficult to code? ;-)
that's two lists (or more?), one for each day.
so we need to use onright/onleft to jump from one to the next one.
no problem there...and up/down will scroll inside each list,
but i assume you also want the entire page to scroll up/down
to get to the lists for wednesday, thursday and so on...?
not a clue if that can be done.
Yes, the idea being one long list, separated by days.
Can you skip the onleft/onright, and just make it jump to the top of the next list as you scroll down? I guess then you get a bunch of nested lists inside one big list.
So:
BIG LIST
Little List1
Item1
Item2
Item3 (ondown jumps to List2)
/Little List1
Little List2
Item1
Item2 (ondown jumps to List3)
/Lititle List2
Little List3
Item1
Item2
Item3
/Lititle List3
/BIG LIST
PS. Yes I like to push the boundries, but at least I try to help... a little
blacklist Wrote:Yes, the idea being one long list, separated by days.
So:
BIG LIST
Little List1
Item1
Item2
/Little List1
Little List2
Item1
/Lititle List2
Little List3
Item1
Item2
Item3
/Lititle List3
/BIG LIST
if BIG LIST was a grouplist control it could work,
but i have to test if you can nest several lists inside a grouplist.
ronie Wrote:that would be too easy. ;--)
videodb://2/2/1/1/1 == Series Premiere
videodb://2/2/1/?/1 == Season Premiere
ronie Wrote:create a ticket on trac and tell the devs 'Back' doesn't work on custom dialogs.
use 'ok' / 'enter' to close.
Ok, gotcha - but it doesn't work. It works fine on the RSS feeds, but not on this dialog. I have to get up out of my "comfortable chair" and push the "ESC" button on the keyboard to close the dialog.
ppic Wrote:he's not the only one who has headaches lol!
but it's so fun to see all of that, can't stop !
How is the actor stuff coming, btw?
blacklist Wrote:Ok, gotcha - but it doesn't work. It works fine on the RSS feeds, but not on this dialog. I have to get up out of my "comfortable chair" and pust the "ESC" button on the keyboard to close the dialog.
if it doesn't work than probably i was too lazy to adjust all the necessary id's
after i copied to code from the rss dialog to the next aired dialog. :-)
ronie Wrote:if it doesn't work than probably i was too lazy to adjust all the necessary id's
We have way too much to do to start getting lazy now!
I've got tons more crazy ideas to keep you busy!
blacklist Wrote:videodb://2/2/1/1/1 == Series Premiere
nah...as far as i can tell episodes aren't numbered that way.
let's stick with 1x01
blacklist Wrote:We have way too much to do to start getting lazy now! I've got tons more crazy ideas to keep you busy!
as long as i don't loose any sleep over it.... ;-)
my script is telling you that's it's 1x01, just need to use it no ?
actor stuff ? not worked on it till my last pm.
all i need to finish it is to choose the way i push you the data:
-same way as recently added, next aired ...
-new way: focused item is asking the script to push properties for this item.
what would be the best for you ronie?
dunpealhunter Wrote:Do you also have a bar in video's that you can use with your mouse to go to specific parts of a video? I miss that in almost every skin i see. The only skin that i found that has something remotely like that is transparency with the scrollweel.
ronie Wrote:correct, reason is, it's not possible in xbmc.
as far as i know, i'm not using any special tricks in T!
so if your scrollwheel works there, it should in every skin.
I don't know if you've ever used XBMP or XBMC on the Xbox but when using one of the analog sticks, you could go to specific spots on the progress bar... I wonder if that is something that was never ported or just broken just like DialogBusy didn't work on the non-Xbox versions of XBMC for quite some time...
It would be great to have that functionality on the Windows port... And i would kill for slow-mo!
ppic Wrote:so, you can consider it as done
ronie, if i push this kind of data, is it ok ?
21:05:02 T:8196 M:488873984 NOTICE: videodb://2/2/68/
21:05:02 T:8196 M:488873984 NOTICE: videodb://2/2/92/
21:05:02 T:8196 M:488873984 NOTICE: videodb://2/2/71/
21:05:02 T:8196 M:488873984 NOTICE: videodb://2/2/105/
21:05:02 T:8196 M:488873984 NOTICE: videodb://2/2/58/
21:05:02 T:8196 M:488873984 NOTICE: videodb://2/2/66/
21:05:02 T:8196 M:488873984 NOTICE: videodb://2/2/83/
21:05:02 T:8196 M:488873984 NOTICE: videodb://2/2/62/
21:05:02 T:8196 M:488873984 NOTICE: videodb://2/2/61/
21:05:02 T:8196 M:488873984 NOTICE: videodb://2/2/53/
