ppic Wrote:tmdb seems to be more useable for scrapping yes, for thumb, we already have image link in db (when available)
Understood, but would it be possible to expand this return with additional pictures? The single thumb in the database tends to be small, often black and white.
If would could throw in some addition (optional) sources for the skin to make use of it would lead to a richer browsing expeiance (IMO).
yes, doable, just need to have a good source, i think ronie will prefer to handle a unique or just 2 images format, if the source give us plenty kind of image, non standard sized, it will be a mess for him.
blacklist Wrote:If would could throw in some addition (optional) sources for the skin to make use of it would lead to a richer browsing expeiance (IMO).
blacklist Wrote:For instance, (possibly nsfw)
http://www.skins.be/Anne-Hathaway/
a 'richer' browsing experience, eh ?
i see...lol!
ronie Wrote:a 'richer' browsing experience, eh ?
i see...lol!
They are wallpapers.
I was trying to be considerate.
Their advertising tends to be a bit nsfw.
ppic Wrote:yes, doable, just need to have a good source, i think ronie will prefer to handle a unique or just 2 images format, if the source give us plenty kind of image, non standard sized, it will be a mess for him.
Maybe Ronie can correct me, but I think it's not a big deal on image size as long as we are specific on the constraints and center the image. Might result in some cut off heads occasionally, but not the end of the world.
On browsing through themovidedb actor bios, however - frankly they suck. Imdb would be better. Maybe we can make use of the already existing imdb scraper?
blacklist Wrote:On browsing through themovidedb actor bios, however - frankly they suck. Imdb would be better. Maybe we can make use of the already existing imdb scraper?
imdb scraper doesn't get actor inforamtions i think.
ppic Wrote:imdb scraper doesn't get actor inforamtions i think.
No, but I thought it would be easier to modify the existing scraper to get actor info instead of writing a new scraper.
I'm not sure what was going on with that google images link i posted.
Maybe we can make use of this:
http://code.google.com/appengine/docs/python/images/
Or.
http://blogoscoped.com/archive/2007-07-23-n30.html.
It looks like you need a google API key, I'm notmsure at all how that works, but may make getting google images trivial.
PIL is included in xbmc
but it's used to interact with image directly!
yes your google request seems to be good
This is going to sound way off topic. But can anybody see how easy it would be to make this a "Harry Potter" style skin? lol. Just think if you was to add the "Ken/Burns-slide-zoom" effect on the larger fanart images. You would then get the feel of a "The Daily Prophet" or "The Quibbler" news paper. Oh my, How silly I sound. But I can see the appeal for it.
Oddsodz Wrote:This is going to sound way off topic. But can anybody see how easy it would be to make this a "Harry Potter" style skin? lol. Just think if you was to add the "Ken/Burns-slide-zoom" effect on the larger fanart images. You would then get the feel of a "The Daily Prophet" or "The Quibbler" news paper. Oh my, How silly I sound. But I can see the appeal for it.
It's subconscious because i used potter I do many of my mock-ups.
I agree that it could go that direction. Maybe one day someone will do a Harry Potter mod.
blacklist Wrote:For the bio information i think themoviedb or imdb are going to be the best bet. I think themoviedb is more friendly to scrape from, they don't tend to mess with the layout of their site like imdb does. Unfortunately, their site Has fairly limited information in comparison.
http://www.themoviedb.org/person/1813. Is Anne Hathaway at themoviedb
http://www.imdb.com/name/nm0004266/ is Anne at imdb.
Now, unless im wrong (might be) the database already records themoviedb id? If so thatbmakes the scrape pretty trivial.
For the image my first choice would be images.google.com i think:
PHP Code:
http://images.google.com/images?hl=en&gbv=2&tbs=isch:1&&sa=X&ei=tPkETbzkK8T7lweM8uDiCQ&ved=0CC8QBSgA&q=James+franco&spell=1#q=James+franco
Returns a pretty good selection of images of James Franco, and it is fairly easy to place image size constraints on the call.
Alternatively, there a a bunch of fan site and celebrity image archives that might be used... But have more likelihood of returning 0 results. (frankly they are geared at female celebrities for the most part....)
Returns a pretty thorough page devoted to the actress, and
http://www.skins.be/feeds/en/anne-hathaway.xml
Returns an rss feed of wallpapers dedicated to the actor.
now, these certainly wouldn't work for all actors, but then we could possibly fall back to google?
Wouldn't it be easier to petition TMDB folks to add more image fields to their actor db? Would require more user-input than just scraping google images for stuff that already exists, but the added bonus is that the results would be more uniformly useful and straightforward to scrape....
I know thetvdb folks have been threatening to upgrade for a long time without much external progress, but don't know about TMDB.... In that case, does it make sense to try to set up a new site for this? Seems like it wouldn't be terribly involved:
* Import all actor info from TMDB, and use their ID as primary key for lookups
* Add fields for fanarts and other ratios of images, and return multiples for each when they exist....
Certainly not a trivial task, but much more useful in the long term than any clever workarounds.
Kode has put together a great framework for something just like this for the TV Logos:
http://fanart.tv
It's freshly redone and moved to that URL, but he's said adding support for other "types" of info (logos, season thumbs, [presumably] actors) will be trivial once everything's ironed out....
I'm sure if we all pitched in, we could have a perfect solution in a reasonable time.
