I've been trying to get the XBMC Flicks addon to work, but after I install the plugin from the addons and go into the app, the browser window never opens up to link my account to XBMC flicks.
I'm on OS X (and yes, I set the setting to 'yes' for OS X) and Dharma 10.1.
Any help would be appreciated. If there is any other information I can provide I'll be happy to.
HKDude Wrote:Thanks fekker! That was the issue.
Peace has been restored as the wife and daughters can watch Netflicks again.
Darn it, I spoke too soon. I checked last night and the shows I chose in the queue worked fine. However, it turns out the bulk of the items in my queue are not working. I'm getting the generic "script failed: plugin.video.XBMCflicks" on the user interface. The log is showing the following clues:
19:59:51 T:1304 M:3339431936 NOTICE: USER INFO FILE LOC: C:\Users\htpc\AppData\Roaming\XBMC\userdata\addon_data\plugin.video.xbmcflicks\userinfo.txt
19:59:51 T:1304 M:3339427840 NOTICE: matched file contents, it is in the correct format
19:59:51 T:1304 M:3339427840 NOTICE: finished loading up user information from file
19:59:51 T:1304 M:3339427840 NOTICE: .. getAuth called ..
19:59:51 T:1304 M:3339427840 NOTICE: OSX Setting is set to: False
19:59:51 T:1304 M:3339427840 NOTICE: .. user configured ..
19:59:51 T:1304 M:3339055104 ERROR: Error Type: exceptions.AttributeError
19:59:51 T:1304 M:3339055104 ERROR: Error Contents: 'NoneType' object has no attribute 'group'
19:59:51 T:1304 M:3338944512 ERROR: Traceback (most recent call last):
File "C:\Users\htpc\AppData\Roaming\XBMC\addons\plugin.video.xbmcflicks\default.py", line 26, in ?
import resources.lib.menu as menu
File "C:\Users\htpc\AppData\Roaming\XBMC\addons\plugin.video.xbmcflicks\resources\lib\menu.py", line 464, in ?
getEpisodeListing(tvShowID,tvSeasonID,"Disc")
File "C:\Users\htpc\AppData\Roaming\XBMC\addons\plugin.video.xbmcflicks\resources\lib\iqueue.py", line 1664, in getEpisodeListing
curX = getMovieDataFromFeed(curX, curQueueItem, False, netflixClient, instantOnly, strType, True)
File "C:\Users\htpc\AppData\Roaming\XBMC\addons\plugin.video.xbmcflicks\resources\lib\iqueue.py", line 861, in getMovieDataFromFeed
curXe.TvEpisodeEpisodeSeasonNum = str(matchSeasonNum.group("seasonNum"))
AttributeError: 'NoneType' object has no attribute 'group'
19:59:51 T:2996 M:3338940416 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.xbmcflicks/?mode=tvExpandshId70128262seIdFalse
19:59:51 T:2996 M:3338940416 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.xbmcflicks/?mode=tvExpandshId70128262seIdFalse) failed
I did check and I can view the episode at NetFlix within my browser on the HTPC.
updated iewrap.exe
options (pass as arguments)
Argument: showscroll
ScrollBars are Enabled and visable
Argument: nobutton
Effect: Hides the button
Argument: notop
Effect: doesn't bring to top focus (i.e. in front of everything else)
Arugment: focus
Effect: Should bring focus to the window for those using remotes (after a 1 second delay)
Link:
https://rapidshare.com/files/460494891/iewrap.exe
HKDude Wrote:Darn it, I spoke too soon. I checked last night and the shows I chose in the queue worked fine. However, it turns out the bulk of the items in my queue are not working. I'm getting the generic "script failed: plugin.video.XBMCflicks" on the user interface. The log is showing the following clues:
woops.. fixed in 1.0.19 (submitted to xbmc, should be available soon)
You can fix it manually:
in the iqueue.py file change the following .. if matchEpNum: to if matchSeasonNum:
matchSeasonNum = re.search('(?sm)u{0,1}[\'"]season_number[\'"]: u{0,1}(?P<seasonNum>\\d{1,3})', matchAllEp.group())
if matchEpNum:
To this:
[b] [color=Green]if matchSeasonNum:[/color][/b]
lehite Wrote:Hi,
put the addon in debug mode, manually enter the auth details into the iqueue.py file (it'll tell ya in the log where to put what)
fekker Wrote:updated iewrap.exe
Argument: nobutton
Argument: notop
Arugment: focus
Link: https://rapidshare.com/files/460494891/iewrap.exe
Downloaded twice. Wrapper loads completely blank. Old wrapper works fine. Not sure what's going on.
lehite Wrote:Hi,
Try using "command tab" to switch to your browser and back again.
lehite Wrote:Hi,
Same is happening on windows with the iewrap.exe from RS.
Just a white screen with the Close button in the upper right corner.
Alt+Tab does nothing as far as fixing.
eQUIV Wrote:Downloaded twice. Wrapper loads completely blank. Old wrapper works fine. Not sure what's going on.
Did you remove the part that tells it what site to load?
<filename>c:\xbmcflix\iewrap.exe</filename>
<args>focus "{1}"</args>
You can test it via the command line (same thing that xbmc calls, basically)
iewrap.exe focus
http://www.google.com
iewrap.exe showscroll focus
iewrap.exe nobutton
etc
post your playercorefactory.xml
fekker Wrote:Did you remove the part that tells it what site to load?
I'm not sure what you're referring to.
Quote:You can test it via the command line (same thing that xbmc calls, basically)
iewrap.exe focus http://www.google.com
iewrap.exe showscroll focus http://www.google.com
iewrap.exe nobutton http://www.google.com
etc
Command line appears to work fine. It will load websites with that method. Something seems to be restricting/preventing XBMC to send URLs to the new wrapper. When the wrapper opens via the plugin, it is still blank.
<playercorefactory>
<players>
<player name="IE" type="ExternalPlayer">
<filename>C:\NetflixControl\iewrap.exe</filename>
<hidexbmc>false</hidexbmc>
<hideconsole>false</hideconsole>
<warpcursor>none</warpcursor>
</player>
</players>
<rules action="prepend">
<rule name="html" filetypes="html" player="IE" />
</rules>
</playercorefactory>
Awesome plugin! Seems to work rather well. I do have a question though. Will it ever be possible to have shows/movies from your instant queue load inside of XBMC rather than outside XBMC in a separate browser?
Ok, I was using old source on the wrapper that I made the changes to.
try this one
https://rapidshare.com/files/460662645/iewrap.exe
For playback within xbmc, it's highly unlikely unless xbmc and netflix worked together on it, like boxee did.
Now what we can shoot for is a wrapper that uses the same controls as xbmc does, which is why silverlight 5 is good.
fekker Wrote:Ok, I was using old source on the wrapper that I made the changes to.
try this one
That took care of it. Thanks.
Excellent. The updated wrapper works now. However, the focus function does not. I still have to click before I can send keyboard/remote presses.
I would like to thank you for your hard work and efforts to resolve the problem. Perhaps yourself or someone can come up with a proper solution soon.
