I have a Fire TV Stick for the TV in my bedroom. MQ 7 itself runs pretty smooth, but the Multi-Mod adds a lot of moving parts to the Skin. I don't know any way to lighten the load besides removing certain Mods or limiting what Mods are enabled (e.g., Holiday Settings, Weather Settings).
First let me say I love the MOD!! Awesome work!! I just have few questions? Do you need to install "all" the updates? or does the latest update cover all the previous updates? Also Is there any way to access all view types in the add-ons or do the add-ons themselves limit which view type you can use? Really some of the views but certain views do not show all the data and/or fan art and other do. I think the sets view would work great for Episodes on some of the add-ons but there is no option for it. I was thinking of editing and changing some of these to my liking the only problem I see is that everything time there is an update I will have to re-write it in the xml every time. Will this work with the newest MQ7 release?
Ah...OK. I didn't know you had those options for Glass List. Once I get all the new views working and post a new update, I'll take a look at adding some options like that.
