  • 2(current)
  • 139
v18 Aeon MQ 7 Leia Mod
#16
Intel NUC Haswell I3
Nvidia Shield
LibreECEC
Kodi - Leia
hello love it
but I don't get the ratings for rotten tom imdb critis enz
what am I doing wrong
@rico12345
You need to enter an OMDb API key.  Read here for more info.
Kodi v17.6 "Krypton" (Aeon MQ 7 Krypton Mod v2.0.0.8) running on Windows 10
Kodi v18.6 "Leia" (Aeon MQ 7 Leia Mod v1.0.2.4) running on Windows 10/Amazon Fire TV
Kodi v18.6 "Leia" (Aeon MQ 8 Multi-Mod v2.9.0) running on Windows 10/Amazon Fire TV Cube
Youtube Channel
@Ruk12345
Haha.
Youtube Channel
Usiing right list view...I do not see a way to remove the tag line from showing in upper left corner in a semi transparent block. Am i just missing the setting for turning it off?
HTPC Basement: i3 3225, Asrock z77 pro4m, 8gb Crucial DDR3 1600, Samsung 840 120gb SSD, Silverstone GD05B Case
HTPC Livingroom: WIP
Server: UnRaid: Intel G550, Asrock B75 pro3m, 4gb ram, Parity Drive 3tb WD Red, Data 2 x 2tb WD Red, Cache 1tb WD Blue, Fractal Design XL R2 Case
@AnthonyJS02
I don't have a setting to enable/disable that tagline. I can add one to the Top Menu.
Youtube Channel
(2018-03-10, 17:42)latts9923 Wrote: @AnthonyJS02
 Sounds good, no worries if too much work. Thanks
hello
i cant find Patreon API-Key for omdbapi.com. in System>Settings>Addons>Manage Dependencies>Metadata and Artwork Module>Configure>API Keys>
only for tvdb can i enter a key
i use universal movie scrapper is that good ?
i mean key for fanart tv not tvdb
Sorry about the silly question but can you be more specific of how to install the Mod after upgrading to Leia?
After upgrading to leia I received a message that mq7 is not compatible and I cant reinstall it.
please elaborate step by step how to reinstall mq7 and then latts9923 mod for leia.
Thanx
@rico12345
The Patreon API is a $1/month Paypal subscription.
Youtube Channel
@Dave.B
The Leia Mod is the updated version of MQ 7 with the Multi-Mod included...nothing else to install.
Youtube Channel
Thanks latts9923 that's what I thought. But after upgrading to Leia the default skin took over and mq7 was not available to switch too. When I tried to install it from zip file it was anounced incompatible and I couldn't install it.
@MB1968
If you upgraded from Krypton to Leia, you will need to uninstall the MQ7 Krypton Mod and install the MQ7 Leia Mod.
Youtube Channel
Love the KodiFlix view but is it possible to make the fanart smaller in this view? Like it is with Aeon Madnox? Smile
Asrock Extreme 4 Z97 Intel i7 4790k @4.7ghz | Windows 10 Pro x64
EVGA Hybrid FTW GTX 1070 | G.Skill Ripjaws 32GB ram
Samsung 500GB SSD | 2TB HDD 4TB USB HDD 750gb HDD
  • 2(current)
  • 139
  • 13 Vote(s) - 4.54 Average
Aeon MQ 7 Leia Mod4.5413
