2019-03-31, 22:36
colored studio icons disappeared.
did:
- search the forum, but try the stuff i searched but nothing helps, maybe i am overseeing something?
- deleted the add on and reinstalled it again, the same.
- searched for the add on in the user folder it is deleted when add on deletes.
- added add on again, restarted the system. Still no coloured studio icons, not in library not in full screen.
I get ERROR: DoWork - Direct texture file loading failed for resource://resource.images.mediaicons.coloured/studios/
in the log.
ok i uninstalled the addon resource image colored studio icons first got to estuary and disabled aeon m7 add on, then uninstalled it,
then enabled aeon mq 7 add on and got back to the skin. Then i looked and see the imdb icon in gold/yellow. Then i installed the resource studio icons again and all is disappeared again. Then i try to deselect all colored studio icons and use the skins default, but also these are not showing. And in library i do have set media labels always on....
ok i will go search and try
well install deinstall reinstall restart full restart deinstall restart full install restart , i just do not know what is going on, the only thing i know is that there is always a problem with these coloured icons when it is a fresh install.
did:
in the log.
