  • 106
  • 107
  • 108(current)
  • 109
  • 110
  • 210
v18 Aeon MQ 7 Leia Mod
@MB1968
When I press once to the right I get the scrollbar...twice I get the plot screen with the description only...three times I get just the channel's logo.
@shedrock
@"chrissix"
@Karellen
I have a fix for this on the Right List view. I'll have to scrub the rest of the views and fix them as well. It will be part of the next update for this Mod as well as the Krypton Mod and MQ 8 Multi-Mod.
@latts9923 - That sounds awesome! I look forward to the fix.
Thank you,
Shedrock
(2019-06-28, 02:40)latts9923 Wrote: @MB1968
Okay. You added an option lately to change the fontsize for the video description/ plot info, didn't you? Do you remember in which update you introduced that option?
Windows 11 Pro
Kodi 21 - Aeon MQ7/MQ9 Omega Mod
Kodi 20.5 - Aeon MQ9 Nexus Mod
Android - Beelink GT King
Kodi 21 - Aeon MQ7 Omega Mod
Kodi Maven Fork 21 - Aeon MQ7 Omega Mod
CoreELEC - Beelink GT King
@MB1968
It was in this update.
(2019-06-29, 00:10)latts9923 Wrote: @MB1968
Fixed. The solution was more simple than I thought. I had to change the view for my movies from KodiFlix into RightList. I knew you added a setting in the top menu for the fontsize. But there was no value set. The field was empty. Strange. I changed the fontsize to normal, and I can see the full description now. Thanks for helping.
Windows 11 Pro
@MB1968
Ah...OK. You're welcome...glad you got it working!
How do I change my Widget in TV Shows and Movie? Can't seem to get back to top menu. Is it the same in Aeon MQ 7 and 8?
(2019-06-30, 18:26)insync44 Wrote: How do I change my Widget in TV Shows and Movie? Can't seem to get back to top menu. Is it the same in Aeon MQ 7 and 8?
Click on the last right option in widget menu, to get flexible widget.
I upgraded Leia to version 18.3 on my Android box. When I open the music menu, the Aeon skin does not show the option "add music" anymore. The Estuary skin still does.
Something wrong on my side, or are there changes in the language strings?
EDIT 1:
Corrupt skin settings Sad
EDIT 2:
Not a corrupt skin setting. The List3D view was active for the this section (Files)
@latts9923, please remove this view for this section.
Windows 11 Pro
@latts9923
I'm currently busy translating English/American parts of the skin into Dutch. It concerns the MediaInfo Mod sections and extra's language strings you've added the last months. All is working fine, except for some texts in the second column (from the right) of topmenu. Do you have any idea what is causing this? I've marked the problematic parts, with a red square in the image. Below you'll find the part that is not being translated into Dutch. (starts at line 3936 if you open strings.po with Notepad++)
<!-- Media Info Mod -->
msgctxt "#32023"
msgid "AUDIO AND SUBTITLE FLAGS"
msgstr "AUDIO EN SUBS SYMBOLEN"
msgctxt "#32024"
msgid "LANGUAGE FLAGS STYLE"
msgstr "STIJL TAALSYMBOLEN"
msgctxt "#32025"
msgid "FULLSCREEN TOP ART"
msgstr "VOL SCHERM ART BOVEN"
msgctxt "#32026"
msgid "FULLSCREEN MIDDLE ART"
msgstr "VOL SCHERM ART MIDDEN"
msgctxt "#32027"
msgid "LOGO"
msgstr "LOGO"
msgctxt "#32028"
msgid "TEXT"
msgstr "TEKST"
msgctxt "#32029"
msgid "SQUARE"
msgstr "VIERKANT"
msgctxt "#32030"
msgid "RECTANGULAR"
msgstr "RECHTHOEKIG"
msgctxt "#32031"
msgid "ROUND"
msgstr "ROND"
msgctxt "#32032"
msgid "DETAILED"
msgstr "GEDETAILEERD"
msgctxt "#32033"
msgid "REGULAR"
msgstr "REGULAR"
msgctxt "#32034"
msgid "WHITE"
msgstr "WIT"
msgctxt "#32035"
msgid "COLOURED"
msgstr "GEKLEURD"
msgctxt "#32036"
msgid "LEFT"
msgstr "LINKS"
msgctxt "#32037"
msgid "RIGHT"
msgstr "RECHTS"
msgctxt "#32038"
msgid "STATIC"
msgstr "STATISCH"
msgctxt "#32039"
msgid "SPINNING"
msgstr "DRAAIEND"
msgctxt "#32040"
msgid "DETAIL INFO"
msgstr "DETAIL INFO"
msgctxt "#32041"
msgid "CLEARART"
msgstr "CLEARART"
msgctxt "#32042"
msgid "DISCART"
msgstr "DISCART"
msgctxt "#32043"
msgid "NO ICON"
msgstr "GEEN ICOON"
msgctxt "#32044"
msgid "CHARACTER ART"
msgstr "CHARACTER ART"
msgctxt "#32045"
msgid "BASIC INFO"
msgstr "BASIS INFO"
Windows 11 Pro
@MB1968
I'll take a look at List3D.
I'll also fix all the Media Info Mod labels. The top menu file is not using the language file for those, it just has the text entered for each one in the file.
@latts9923
Are you familiar with the Library Node Editor? I'm trying to set up video node for the movie library to exclude documentaries from the main movie library. I created a rule: genre is not documentaries. However the documentaries still show up in the movie library.
Do you happen to know if this can be achieved in the Aeon skin? I read in the Library Node Editor thread that this issue could be caused by a restriction of the skin.
Windows 11 Pro
(2019-07-10, 13:28)latts9923 Wrote: @MB1968
Ah, that explains all. Just one file? If so which one? One file is easy to maintain for me.
Windows 11 Pro
(2018-03-06, 05:31)latts9923 Wrote: Aeon MQ 7 Mod v1.0.1.7 for Kodi v18 "Leia"You can now update the Aeon MQ 7 Leia Mod via my repo. The manual update process is no longer required. The following how-to video will walk you through installing my repo, and then installing/updating the Leia Mod. Installing my repo will begin the download process of v1.0.1.7, so make a backup of your skin if you have customized anything. This video is quite long, so there will be links provided in the video description that will allow you to skip to different portions of the video.DownloadsAeon MQ 7 Leia Mod v1.0.1.7Additional themes(You must first install the Aeon MQ Skin Themes Add-on, then you can copy the themes from this file into that Add-on.)Library Editor (Leia update)Skin Info Service (Leia update)Updates03/24/18 - Update for v1.0.0.1. Read here for more info.03/29/18 - Update for v1.0.0.2. Read here for more info.04/07/18 - Update for v1.0.0.3. Read here for more info.04/12/18 - Update for v1.0.0.4. Read here for more info.05/10/18 - Update for v1.0.0.5. Read here for more info.07/22/18 - Update for v1.0.0.6. Read here for more info.10/15/18 - Update for v1.0.0.7. Read here for more info.11/06/18 - Update for v1.0.0.8. Read here for more info.11/24/18 - Update for v1.0.0.9. Read here for more info.12/05/18 - Update for v1.0.1.0. Read here for more info.12/17/18 - Update for v1.0.1.1. Read here for more info.01/01/19 - Update for v1.0.1.2. Read here for more info.01/19/19 - Update for v1.0.1.3. Read here for more info.02/15/19 - Update for v1.0.1.4. Read here for more info.03/07/19 - Update for v1.0.1.5. Read here for more info.03/07/19 - Update for v1.0.1.6. Read here for more info.
Will there be support for Kodi Matrix in the long run?
  • 106
  • 107
  • 108(current)
  • 109
  • 110
  • 210
Aeon MQ 7 Leia Mod13
