2020-01-31, 05:32
(This post was last modified: 2020-01-31, 05:55 by melons2.)
Thank you for the answers above!
SOLVED
New question:
I needed to re-order my main menu selections. So I went; settings, skin settings, main menu, customize main menu, and then I would select Concerts and then Copy properties to storage. Then when reordering I would choose a selection such as music and apply properties from storage to reorder the main menu order.. Everything seemed fine except for as a sub menu of concerts (down arrow)there is "concerts recently added", "concerts recently played"......these are sub-menus of the main menu "concerts" but they are under music now instead of down under concerts. How do I move the down arrow sub-menus from concerts to concerts in the down arrow sub-menus from Music under Music?
Thank you
MB1968
Posting Freak
Thanks for the improvements.
Windows 11 Pro
Kodi 21 - Aeon MQ7/MQ9 Omega Mod
Kodi 20.5 - Aeon MQ9 Nexus Mod
Android - Beelink GT King
Kodi 21 - Aeon MQ7 Omega Mod
Kodi Maven Fork 21 - Aeon MQ9 Omega Mod
CoreELEC - Beelink GT King
2020-02-17, 22:23
(This post was last modified: 2020-02-20, 21:54 by Steel99.)
i have a few issues since the last update ....or maybe the one before:
- I don't see the watched flags in right list view
- During movie playback in the info menu i don't see informations on top left side (Movie name, year and so on .....
Any ideas?
Edit: The first of the issues i could solve.....found the solution in the MQ8 Multi-Mod thread....just enabled SKIN SETTINGS > OPTIONS MENU > PUT PROGRESS INFORMATION IN VIEW
Edit2: Ha! Solved the second issue.....the setting of "Show title on top as" in the "Collection/ Change view" menu was empty...
Maybe these settings should be enabled by default and not disabled after an update ....
wags1
Posting Freak
I think this issue started after Artist Slideshow was updated to the new version. When listening to music I typically use Layout 7 (but I have tried other layouts and it they act the same way). If, using the Settings menu, I select "Slideshow" I just get 1 background picture and it never changes. If I select "Skinhelper Script" the background picture changes as it should. One of the odd things is if I bring up the Settings menu and select "Slideshow", as long as I keep the menu on the screen I can see the background changing but as soon as I dismiss the menu it goes back to the single background and never changes. One other thing I noticed is that within the Artist Slideshow addon settings I have "Use fallback slideshow" enabled and have it pointed to a folder that has a bunch of pictures. In the past when Artist Slideshow could not locate artist pictures it would display images from that folder. That is no longer working either. All this was working fine previously.
I was hoping someone could try this so I could determine if it's just an issue unique to me or if their is something not working correctly. Thanks!
