New feature with birthday actor in Home
and on click search actor on youtube
great skin! how do I get the movie dvd disc art? That's a very cool feature
With artwork downloader, but there is no many disq actualy
New feature, support for music playlist in widget, extrafanarts, cdarts and logo with widget info
hmmm unable to update skin ? using Passion Repo
Why you can't update? no problem for me and other user this morning
It's strange because I'm currently upgrading Glass to version 0.9.26.161 and downloading is in progress (downloading is very slow but I'm at the office behind a firewall so ...).
I've just modifie a little bit the custom view Resolution case.
Now, on movieset thumbnail, if you have checked "Hide movieset case" option, CDArt won't be displayed and case can't be opened with Down arrow.
I have made this because, for my moviesets, I use custom box instead of case.
In th left side menu, you have to check those 2 options :
Hide Movie CDart : by default active movie case is closed
Hide Movieset Case : to not display a case for movieset thumbnail
Adding support for music playlist in every custom menu
Movie set case looking good..& audio playlist support on every widget .. excellent... I'll check on whats with the updating later on tonight & let you Know
marked broken in repo ? is it becuase of using nightly?
I just tried to install the svn from a zip file and got an "dependencies not met" error. Any ideas?
have updated and all is well , thanks
