2016-03-14, 22:43
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89
2016-03-14, 22:51
It works on kodi 16.
My setup: Windows 10, Kodi 16.1 RC1
2016-03-14, 23:03
(2016-03-14, 22:51)Slipass Wrote: [ -> ]It works on kodi 16.
Well, im on an android tv (M8S) and it does not work. I tried with Kodi 14.0 Helix and it still did not work so idk what is wrong
2016-03-14, 23:08
(2016-03-14, 23:03)TormDemoniax Wrote: [ -> ](2016-03-14, 22:51)Slipass Wrote: [ -> ]It works on kodi 16.
This is for Windows. Out of curiosity why would you want to launch steam on Android?
2016-03-14, 23:20
(2016-03-14, 23:08)TheBuz Wrote: [ -> ](2016-03-14, 23:03)TormDemoniax Wrote: [ -> ](2016-03-14, 22:51)Slipass Wrote: [ -> ]It works on kodi 16.
I use my android tv box to stream movies to my projector in my home theater ans i wanted to use steam to also play games on it but i guess i will have to buy a steam link.
2016-03-15, 08:53
You have the steam app installed and it runs ok outside of kodi? If yes, then enable the debug log (wiki) in kodi, attempt to run the addon, in the log file search for script.steam.launcher: attempting to launch: and run that command in a termnal app. BTW, the android app (atleast last time i tried) didnt run any games, and was only a thin steam client where you could chat, browse the store and some other things. If you want to stream games I think you need something called moonlight or limelight.
2016-03-15, 16:19
(2016-03-14, 23:20)TormDemoniax Wrote: [ -> ]There is no steam program to launch on Android TV, why would you expect this to do anything?(2016-03-14, 23:08)TheBuz Wrote: [ -> ](2016-03-14, 23:03)TormDemoniax Wrote: [ -> ]Well, im on an android tv (M8S) and it does not work. I tried with Kodi 14.0 Helix and it still did not work so idk what is wrong
There is an Android steam app but it doesn't stream any games, just lets you see your purchases and junk. You need to install moonlight and configure gamestream on your gaming box to launch the steam shortcut as a game. I've done it this way before with very good success. Of course if you have an AMD GPU you have to look elsewhere
2016-03-21, 19:18
Hello,
Steam Big Picture mode makes my games lagging when streaming.
I have no lags if i run from Non-Big-Picture mode.
Is there a way to launch the games wthout BP-Mode?
DocMAX
DocMAX
2016-03-21, 21:28
Try running Steam in desktop mode via the pre-steam script. Then in the addon setttings point the setting for the steam executable to a empty batch file or /bin/false.
2016-04-06, 23:36
Just installed and configured Kodi then came across this addon, Great work! Would love to have something like this for GOG's client. How hard you think would it be to adapt your addon for gog? If you point me in the direction of where to look in your code I can take a look at it as I am a software dev.
2016-04-09, 05:54
It really depends on the program you're launching and how far you want to take the add-on - you can launch a application from kodi with 2 lines of Python. A link to the source on github is in the first post.
2016-04-09, 12:17
Hello teeedubb,
Could you confirm this addon is not present in the official repo? Is there any reason why it is not?
Pierre
Pierre
2016-04-09, 12:28
No it's not in the official repo. Reason is that it contains a executable (a pre compiled ahk script, done so for ease of use) and that isn't allowed in the official repo.
2016-04-09, 15:40
ok thank you very much, I will give it a try shortly, keep up the good work :-)
2016-04-19, 04:58
Running Kodibuntu on my laptop. Tried following the guide at the top of page 44 but when i try to launch the steam add on from kodi it gives me a error and points me to this log. Any ideas?
20:15:45 T:139995238189056 NOTICE: special://profile/ is mapped to: special://masterprofile/
20:15:45 T:139995238189056 NOTICE: -----------------------------------------------------------------------
20:15:45 T:139995238189056 NOTICE: Starting Kodi (16.0 Git:a5f3a99). Platform: Linux x86 64-bit
20:15:45 T:139995238189056 NOTICE: Using Release Kodi x64 build
20:15:45 T:139995238189056 NOTICE: Kodi compiled Feb 20 2016 by GCC 4.8.4 for Linux x86 64-bit version 3.13.11 (199947)
20:15:45 T:139995238189056 NOTICE: Running on Ubuntu 14.04.4 LTS, kernel: Linux x86 64-bit version 3.13.0-85-generic
20:15:45 T:139995238189056 NOTICE: FFmpeg statically linked, version: 2.8.6-kodi-2.8.6-Jarvis-16.0
20:15:45 T:139995238189056 NOTICE: Host CPU: Intel(R) Core(TM) i5-3337U CPU @ 1.80GHz, 4 cores available
20:15:45 T:139995238189056 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
20:15:45 T:139995238189056 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
20:15:45 T:139995238189056 NOTICE: special://masterprofile/ is mapped to: /home/rooster/.kodi/userdata
20:15:45 T:139995238189056 NOTICE: special://home/ is mapped to: /home/rooster/.kodi
20:15:45 T:139995238189056 NOTICE: special://temp/ is mapped to: /home/rooster/.kodi/temp
20:15:45 T:139995238189056 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
20:15:45 T:139995238189056 NOTICE: Local hostname: Rooster-Tv-Box
20:15:45 T:139995238189056 NOTICE: Log File is located: /home/rooster/.kodi/temp/kodi.log
20:15:45 T:139995238189056 NOTICE: load settings...
20:15:45 T:139995238189056 [color=#FF0000]ERROR:[/color] PulseAudio: Failed to connect context
20:15:45 T:139995238189056 NOTICE: PulseAudio might not be running. Context was not created.
20:15:45 T:139995238189056 NOTICE: Found 1 Lists of Devices
20:15:45 T:139995238189056 NOTICE: Enumerated ALSA devices:
20:15:45 T:139995238189056 NOTICE: Device 1
20:15:45 T:139995238189056 NOTICE: m_deviceName : default
20:15:45 T:139995238189056 NOTICE: m_displayName : Default (HDA Intel PCH HDMI 0)
20:15:45 T:139995238189056 NOTICE: m_displayNameExtra:
20:15:45 T:139995238189056 NOTICE: m_deviceType : AE_DEVTYPE_PCM
20:15:45 T:139995238189056 NOTICE: m_channels : FL,FR,BL,BR,FC,LFE
20:15:45 T:139995238189056 NOTICE: m_sampleRates : 32000,44100,48000
20:15:45 T:139995238189056 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
20:15:45 T:139995238189056 NOTICE: Device 2
20:15:45 T:139995238189056 NOTICE: m_deviceName : @:CARD=PCH,DEV=0
20:15:45 T:139995238189056 NOTICE: m_displayName : HDA Intel PCH
20:15:45 T:139995238189056 NOTICE: m_displayNameExtra: ALC282 Analog
20:15:45 T:139995238189056 NOTICE: m_sampleRates : 48000
20:15:45 T:139995238189056 NOTICE: Device 3
20:15:45 T:139995238189056 NOTICE: m_deviceName : hdmi:CARD=PCH,DEV=0
20:15:45 T:139995238189056 NOTICE: m_displayNameExtra: SNY SONY TV on HDMI
20:15:45 T:139995238189056 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
20:15:45 T:139995238189056 NOTICE: m_dataFormats : AE_FMT_LPCM,AE_FMT_AC3,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_DTSHD,AE_FMT_TRUEHD,AE_FMT_EAC3,AE_FMT_DTS,AE_FMT_AAC
20:15:45 T:139995238189056 NOTICE: Device 4
20:15:45 T:139995238189056 NOTICE: m_deviceName : @:CARD=Device,DEV=0
20:15:45 T:139995238189056 NOTICE: m_displayName : USB Multimedia Audio Device
20:15:45 T:139995238189056 NOTICE: m_displayNameExtra: Analog
20:15:45 T:139995238189056 NOTICE: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE
20:15:45 T:139995238189056 NOTICE: Device 5
20:15:45 T:139995238189056 NOTICE: m_deviceName : iec958:CARD=Device,DEV=0
20:15:45 T:139995238189056 NOTICE: m_displayNameExtra: S/PDIF
20:15:45 T:139995238189056 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
20:15:45 T:139995238189056 NOTICE: m_sampleRates : 8000,16000,44100,48000
20:15:45 T:139995238189056 NOTICE: m_dataFormats : AE_FMT_AC3,AE_FMT_DTS,AE_FMT_S16NE,AE_FMT_S16LE
20:15:45 T:139995238189056 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
20:15:45 T:139995238189056 NOTICE: Loaded settings file from special://profile/advancedsettings.xml
20:15:45 T:139995238189056 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<useddsfanart>true</useddsfanart>
<cputempcommand>cputemp</cputempcommand>
<gputempcommand>gputemp</gputempcommand>
<samba>
<clienttimeout>30</clienttimeout>
</samba>
<network>
<disableipv6>true</disableipv6>
</network>
</advancedsettings>
20:15:45 T:139995238189056 NOTICE: Default DVD Player: dvdplayer
20:15:45 T:139995238189056 NOTICE: Default Video Player: dvdplayer
20:15:45 T:139995238189056 NOTICE: Default Audio Player: paplayer
20:15:45 T:139995238189056 NOTICE: Disabled debug logging due to GUI setting. Level 0.
20:15:45 T:139995238189056 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
20:15:45 T:139995238189056 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
20:15:45 T:139995238189056 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
20:15:45 T:139995238189056 NOTICE: Loaded playercorefactory configuration
20:15:45 T:139995238189056 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
20:15:45 T:139995238189056 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
20:15:45 T:139995238189056 NOTICE: Running database version Addons20
20:15:45 T:139995238189056 NOTICE: ADDONS: Using repository repository.exodus
20:15:45 T:139995238189056 NOTICE: ADDONS: Using repository repository.shani
20:15:45 T:139995238189056 NOTICE: ADDONS: Using repository repository.team.expat
20:15:45 T:139995238189056 NOTICE: ADDONS: Using repository repository.podgod
20:15:45 T:139995238189056 NOTICE: ADDONS: Using repository repository.xbmc.org
20:15:45 T:139995238189056 NOTICE: ADDONS: Using repository repository.tknorris.release
20:15:45 T:139995238189056 NOTICE: ADDONS: Using repository repository.xunitytalk
20:15:45 T:139995238189056 NOTICE: ADDONS: Using repository superrepo.kodi.helix.all
20:15:45 T:139995238189056 NOTICE: ADDONS: Using repository repository.xbmchub
20:15:45 T:139995238189056 NOTICE: ADDONS: Using repository repository.k3oni.xbmc
20:15:45 T:139995238189056 NOTICE: ADDONS: Using repository repository.metalkettle
20:15:45 T:139995238189056 NOTICE: ADDONS: Using repository xbmc.repo.elmerohueso
20:15:45 T:139995238189056 NOTICE: Setup SDL
20:15:46 T:139995238189056 NOTICE: Checking resolution 16
20:15:46 T:139995238189056 NOTICE: Using visual 0x20
20:15:46 T:139995238189056 NOTICE: GL_VENDOR = Intel Open Source Technology Center
20:15:46 T:139995238189056 NOTICE: GL_RENDERER = Mesa DRI Intel(R) Ivybridge Mobile
20:15:46 T:139995238189056 NOTICE: GL_VERSION = 3.0 Mesa 10.1.3
20:15:46 T:139995238189056 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.30
20:15:46 T:139995238189056 NOTICE: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_copy_texture GL_EXT_polygon_offset GL_EXT_subtexture GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip GL_ARB_point_parameters GL_EXT_draw_range_elements GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_framebuffer_sRGB GL_ARB_multitexture GL_EXT_framebuffer_sRGB GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat GL_3DFX_texture_compression_FXT1 GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_blend_func_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_INGR_blend_func_separate GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_S3_s3tc GL_SUN_multi_draw_arrays GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_texture_compression_s3tc GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_ARB_depth_texture GL_ARB_occlusion_query GL_ARB_shadow GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_ATI_envmap_bumpmap GL_EXT_stencil_two_side GL_EXT_texture_cube_map GL_NV_depth_clamp GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_vertex_program GL_ARB_vertex_shader GL_ATI_draw_buffers GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_MESA_pack_invert GL_NV_primitive_restart GL_ARB_depth_clamp GL_ARB_fragment_program_shadow GL_ARB_half_float_pixel GL_ARB_occlusion_query2 GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_sync GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ATI_blend_equation_separate GL_EXT_blend_equation_separate GL_OES_read_format GL_ARB_color_buffer_float GL_ARB_pixel_buffer_object GL_ARB_texture_compression_rgtc GL_ARB_texture_float GL_ARB_texture_rectangle GL_EXT_packed_float GL_EXT_pixel_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_ARB_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_packed_depth_stencil GL_APPLE_object_purgeable GL_ARB_vertex_array_object GL_ATI_separate_stencil GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_gpu_program_parameters GL_EXT_texture_array GL_EXT_texture_integer GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_OES_EGL_image GL_AMD_performance_monitor GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_texture_rg GL_ARB_texture_swizzle GL_ARB_vertex_array_bgra GL_EXT_separate_shader_objects GL_EXT_texture_swizzle GL_EXT_vertex_array_bgra GL_NV_conditional_render GL_AMD_conservative_depth GL_AMD_draw_buffers_blend GL_AMD_seamless_cubemap_per_texture GL_ARB_ES2_compatibility GL_ARB_blend_func_extended GL_ARB_debug_output GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_provoking_vertex GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_shader_texture_lod GL_ARB_texture_cube_map_array GL_ARB_texture_gather GL_ARB_texture_multisample GL_ARB_texture_query_lod GL_ARB_texture_rgb10_a2ui GL_ARB_uniform_buffer_object GL_ARB_vertex_type_2_10_10_10_rev GL_EXT_provoking_vertex GL_EXT_texture_snorm GL_MESA_texture_signed_rgba GL_ARB_get_program_binary GL_ARB_robustness GL_ARB_shader_bit_encoding GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_ARB_conservative_depth GL_ARB_internalformat_query GL_ARB_map_buffer_alignment GL_ARB_shader_atomic_counters GL_ARB_shading_language_420pack GL_ARB_shading_language_packing GL_ARB_texture_storage GL_ARB_transform_feedback_instanced GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_transform_feedback GL_AMD_shader_trinary_minmax GL_ARB_ES3_compatibility GL_ARB_clear_buffer_object GL_ARB_invalidate_subdata GL_ARB_texture_query_levels GL_ARB_texture_storage_multisample GL_ARB_vertex_attrib_binding GL_KHR_debug GL_ARB_texture_mirror_clamp_to_edge GL_ARB_vertex_type_10f_11f_11f_rev GL_EXT_shader_integer_mix
20:15:46 T:139995238189056 [color=#FF0000]ERROR:[/color] Unable to load libcec.so.3.0, reason: libcec.so.3.0: cannot open shared object file: No such file or directory
20:15:46 T:139995238189056 [color=#FF0000]ERROR:[/color] Initialise - failed to initialise bus cec
20:15:46 T:139995238189056 NOTICE: Running database version Addons20
20:15:46 T:139995238189056 NOTICE: Running database version ViewModes6
20:15:46 T:139995238189056 NOTICE: Running database version Textures13
20:15:46 T:139995238189056 NOTICE: Running database version MyMusic56
20:15:46 T:139995238189056 NOTICE: Running database version MyVideos99
20:15:46 T:139995238189056 NOTICE: Running database version TV29
20:15:46 T:139995238189056 NOTICE: Running database version Epg11
20:15:46 T:139995238189056 NOTICE: start dvd mediatype detection
20:15:46 T:139995238189056 [color=#FFD700]WARNING:[/color] JSONRPC: Could not parse type "Setting.Details.SettingList"
20:15:46 T:139995238189056 NOTICE: ActiveAE DSP - starting
20:15:46 T:139995238189056 NOTICE: initialize done
20:15:46 T:139995238189056 NOTICE: Running the application...
20:15:46 T:139995238189056 NOTICE: starting zeroconf publishing
20:15:46 T:139995238189056 NOTICE: WebServer: Started the webserver
20:15:46 T:139995238189056 NOTICE: starting upnp client
20:15:46 T:139993829852928 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
20:15:46 T:139993829852928 NOTICE: UDP: Listening on port 9777
20:15:46 T:139995238189056 NOTICE: Enabled Joystick: Microsoft X-Box 360 pad
20:15:46 T:139995238189056 NOTICE: Details: Total Axis: 6 Total Hats: 1 Total Buttons: 11
20:15:47 T:139994345867008 NOTICE: Stream All The Sources: Service: Installed Version: 2.0.28
20:15:47 T:139994345867008 NOTICE: Stream All The Sources: Service: starting...
20:22:52 T:139993964074752 [color=#FF0000]ERROR:[/color] EXCEPTION: Non-Existent Control 1
20:23:08 T:139995238189056 [color=#FF0000]ERROR:[/color] Control 50 in window 10001 has been asked to focus, but it can't
20:23:30 T:139993431312128 NOTICE: script.steam.launcher: ****Running Steam-Launcher v3.1.4....
20:23:30 T:139993431312128 NOTICE: script.steam.launcher: running on osAndroid, osOsx, osLinux, osWin: 0 0 1 0
20:23:30 T:139993431312128 NOTICE: script.steam.launcher: System text encoding in use: UTF-8
20:23:30 T:139993431312128 NOTICE: script.steam.launcher: usr scripts are set to be checked for updates...
20:23:30 T:139993431312128 NOTICE: script.steam.launcher: usr scripts are not set to be deleted, running version check
20:23:30 T:139993431312128 NOTICE: script.steam.launcher: sys "steam.launcher.script.revision=": 014
20:23:30 T:139993431312128 NOTICE: script.steam.launcher: usr "steam.launcher.script.revision=": 014
20:23:30 T:139993431312128 NOTICE: script.steam.launcher: userdata script are up to date
20:23:30 T:139993431312128 NOTICE: script.steam.launcher: skipping deleting userdata scripts, option disabled: delUserScriptSett = false
20:23:30 T:139993431312128 NOTICE: script.steam.launcher: script file already exists, skipping copy to userdata: /home/rooster/.kodi/userdata/addon_data/script.steam.launcher/scripts/steam-launch.sh
20:23:30 T:139993431312128 NOTICE: script.steam.launcher: wmctrl present, checking if a window manager is running...
20:23:30 T:139993431312128 NOTICE: script.steam.launcher: [color=#FF0000]ERROR:[/color] A window manager is NOT running - unless you are using the SteamOS compositor Steam BPM needs a windows manager. If you are using the SteamOS compositor disable the addon option "Check for program wmctrl"
20:25:08 T:139993980860160 [color=#FFD700]WARNING:[/color] Attempt to use invalid handle -1
20:28:43 T:139993821460224 [color=#FFD700]WARNING:[/color] Previous line repeats 11 times.
20:28:43 T:139993821460224 NOTICE: Kodi Log Uploader: started
20:28:43 T:139993821460224 NOTICE: Kodi Log Uploader: settings: len(email)=21
20:28:43 T:139993821460224 NOTICE: Kodi Log Uploader: settings: skip_oldlog=True
20:28:46 T:139993821460224 NOTICE: Kodi Log Uploader: reading log...
