there is no hdmi audio device coming up. Are you using the xbmc.conf the howto provides?
(2014-01-22, 23:24)fritsch Wrote: [ -> ]there is no hdmi audio device coming up. Are you using the xbmc.conf the howto provides?
I had the old startxbmc.sh version. Just updated, rebooted, and same issue. Although, I'm not using hdmi audio, I'm using 3.5mm audio jack.
Quote:12:55:49 T:140262939977600 NOTICE: m_deviceName : @
12:55:49 T:140262939977600 NOTICE: m_displayName : Default (HD-Audio Generic ALC887-VD Analog)
12:55:49 T:140262939977600 NOTICE: m_displayNameExtra:
12:55:49 T:140262939977600 NOTICE: m_deviceType : AE_DEVTYPE_PCM
12:55:49 T:140262939977600 NOTICE: m_channels : FL,FR
12:55:49 T:140262939977600 NOTICE: m_sampleRates : 48000
12:55:49 T:140262939977600 NOTICE: m_dataFormats : AE_FMT_S32NE
12:55:49 T:140262939977600 NOTICE: Device 2
12:55:49 T:140262939977600 NOTICE: m_deviceName : @:CARD=Generic,DEV=0
12:55:49 T:140262939977600 NOTICE: m_displayName : HD-Audio Generic
12:55:49 T:140262939977600 NOTICE: m_displayNameExtra: ALC887-VD Analog
All there. Sadly that device only support exactly one sample rate 48000. In Audio settings try to set it to Fixed 48000. Make sure it's not muted (alsamixer -c0 or amixer)
Post:
amixer | pastebinit
aplay -l | pastebinit
Take your iphone and make a screenshot of your audio settings.
And remove that other card, it's drivers are highly problematic.
Edit2: Why the hell did you force Deinterlace to On? .... keep that one Auto for all files. It terribly bails out.
(2014-01-22, 23:55)fritsch Wrote: [ -> ]Post:
amixer | pastebinit
XBMC audio settings?
Other card removed, and was messing with deinterlace and forgot to revert it.
Logs:
amixer:
http://paste.ubuntu.com/6799752/
aplay:
http://paste.ubuntu.com/6799753/
EDIT: XBMC audio settings:
http://i.imgur.com/1SAVctN.png
speaker-test -c2 -D plughw:0,0
speaker-test -c2 -D plughw:0,0 -r 48000
And play some mp3 in xbmc and post the logfile, thx.
(2014-01-23, 00:16)fritsch Wrote: [ -> ]speaker-test -c2 -D plughw:0,0
No audio output with speaker-test
Here's the log after failed mp3 playback
xbmc log:
http://paste.ubuntu.com/6799849/
fritsch: when I resume my system from suspend, my screen is black requires a hard reset. Is there something I should edit in the suspend/resume scripts in "/etc/pm/sleep.d/" to get the video drivers to load properly?
@beschmid: No idea - i did not see any logfiles and my crystalball is away for repair.
(2014-01-23, 09:52)fritsch Wrote: [ -> ]@jaymax: Besides that it's still full of deinterlacing errors, It seems vdpau does not like your system :-)
Please whipe your .xbmc directory, don't install that "trackt" thing for now and get me a clean logfile when doing playback of
a) https://dl.dropboxusercontent.com/u/5572...lannad.mkv (has no sound)
and b) https://dl.dropboxusercontent.com/u/55728161/fail.flac
Only redo the settings the howto wants.
Alright, I'll do this tonight. I live with roommates, so I have to do it when nobody is watching anything. Just wanted to say thanks for all the help!
@beschmid: The modelines are totally broken on resume, furthermore your imon device goes nuts. Try overwriting the EDID (as shown in the audio workaround, perhaps that helps).
