(2013-10-03, 18:51)locomot1f Wrote: [ -> ]i just get a whole lot of tearing...
here's my debug log -- http://pastebin.com/EBqDiDZ5
fresh install.
A6-6400
Well it works fine on my a6-3500 which is alot slower...
Did you forget to enable vsync? Got any sample video that is tearing?
Great guide!
Is there any way to get a similar minimal install without using the Raring mini.iso?
I'm asking becaue I'm a victim of
this ancient and still-unfixed bug, and thus can't install the minimal version of Ubuntu without a convoluted workaround (that will break again with every future kernel update). According to the bug report, most other non-Ubuntu minimal systems are also affected since it's a Linux kernel bug, and I seem to remember Ubuntu Server suffering from the same (although I could be wrong, I only tried the mini.iso this time).
Could one go the opposite route? Paring down Xubuntu/Lubuntu to a pseudo-minimal install after the fact? Or could I just go for the existing XBMCbuntu and update kernel and remove fglrx? My current system (the XBMCbuntu based on 12.04 LTS) was unaffected by the bug when I installed it.
In general: yes. You can for example use Lubuntu 13.04 64 bit installation, but then skip the /etc/init/xbmc.conf as this will interfer with your login manager.
The rest should be straight forward.
The only reason I started with a minimal iso is, that some think they have to use unity ;-) and complain about vsync later on.
Edit: If you choose xbmcbuntu, which is 32 bit - you cannot install the linked kernel.
Thanks for the quick response! I'll try Lubuntu 64 bit then.
Hello,
I think I have a problem with my vdpau
vdpauinfo
display: :0.0 screen: 0
Failed to open VDPAU backend libvdpau_nvidia.so: cannot open shared object file: No such file or directory
Error creating VDPAU device: 1
No package with "nvidia" in its name is installed at all.
Which package is mising?
When I try to install nvidia-current aptitude wants to remove two packages. I said "n".
sudo aptitude install nvidia-current
Die folgenden NEUEN Pakete werden zusätzlich installiert:
nvidia-304{a} nvidia-current nvidia-settings-304{a} python-xkit{a} screen-resolution-extra{a}
Die folgenden Pakete werden ENTFERNT:
libllvm3.2{u} libwayland0{u}
0 Pakete aktualisiert, 5 zusätzlich installiert, 2 werden entfernt und 0 nicht aktualisiert.
70,0 MB an Archiven müssen heruntergeladen werden. Nach dem Entpacken werden 187 MB zusätzlich belegt sein.
fyi
lspci | grep -i radeon
01:00.0 VGA compatible controller: Advanced Micro Devices [AMD] nee ATI Thames XT [Radeon HD 7670M]
Edit: I removed the two packages with "sudo apt-get autoremove"
But which nvidia-package is missing?
_don_t install any nvidia binary blob - that is 100% wrong.
You are probably missing:
sudo apt-get install libg3dvl-mesa vdpauinfo linux-firmware
Hello, i have still a problem with my VGA. Could someone help me ?
xbmc@XBMC-NAS:~$ lspci | grep -i radeon
00:01.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Wrestler [Radeon HD 6320]
xbmc@XBMC-NAS:~$ vdpauinfo
vdpauinfo: cannot connect to X server
DISPLAY=:0 vdpauinfo
Please, use basic linux knowledge when typing commands :-)
and provide the logs that I requested in the first post.
I am sorry. Linux is not very friendly for me.
xbmc@XBMC-NAS:~$ DISPLAY=:0 vdpauinfo
display: :0 screen: 0
"and provide all the logs that I requested in the first post".
Revove your /etc/X11/xorg.conf
and remove nomodeset from /etc/default/grub and run sudo update-grub afterwards
It is all full of fglrx traces.
Do this and post dmesg | pastebinit again.
@bibibo: For you even the kernel radeon driver is not loaded. I think it is blacklisted by an old fglrx installation - Start a new installation following the howto on page 1.
Ressurecting a broken install is not topic of this thread.
Okay. I understand. Thanks
