Full Version: Bay Trail-D motherboards
I'd like to start a thread to talk about the new Bay Trail-D mini-ITX motherboards that are supposed to be coming out any day now. We've all seen the press releases from last November so I don't want to include those here. What I'd like to see is real product pages from manufacturer websites and hopefully soon retailers. Once we start actually using them it'd be nice to know what everyone's experiences are, where they found them, good and the bad, etc.
Updated 9-May
ASRock
ASRock Q1900-ITX, Q1900B-ITX, Q1900DC-ITX, etc.
E.g.
Intel® Quad-Core Processor J1900 + Mini-ITX Motherboard
All Solid Capacitor design
Supports DDR3/DDR3L 1333 memory, 2 x SO-DIMM slots
1 PCIe 2.0 x1, 1 mini-PCIe
Graphics Output Options : D-Sub, DVI-D, HDMI
Built-in Intel® 7th generation (Gen 7) graphics, DirectX 11.0, Pixel Shader 5.0
7.1 CH HD Audio with Content Protection (Realtek ALC892 Audio Codec)
2 SATA3, 2 SATA2, 4 USB 3.0 (2 Front, 2 Rear), 4 USB 2.0 (2 Front, 2 Rear)
1 x Print Port Header, 1 x COM Port Header
Supports A-Tuning, XFast LAN, XFast RAM, USB Key
ASRock IMB-150
ASRock IMB-151
There are from ASRock's "IPC" series so no idea if they will be available to retailers. I'd like to see the IMB-151 since it has on-board power.
Gigabyte
Gigabyte GA-J1800N-D2H
Built-in Intel® Celeron™ J1800 (2.41 GHz) Dual-Core processor
GIGABYTE Ultra Durable™ Technology
All Solid Capacitors with Humidity Protection New Glass Fabric PCB design
LAN with high ESD Protection
HDMI, D-SUB ports on rear panel
USB 3.0 port with GIGABYTE 3x USB power
GIGABYTE On/Off Charge™ for USB devices
Mini PCI-E expansion slot supports wireless networking cards
MSI
MSI J1800I
Intel® Celeron J1800 Processor Onboard
DDR3-1333 Memory
USB 3.0 + SATA 3Gb/s
Military Class 4: Top Quality & Stability
Military Class Essentials: Total Protection for Military Class Motherboards
HDMI: High-Definition Multimedia Interface
Fast Boot: Quickly Boot Up & Enter OS in A Few Seconds
M-Flash: Simply Update & Backup Your BIOS
Live Update 5: Easily Update The Latest BIOS & Drivers
ECS
ECS BAT-I
Applied Solid Capacitor for CPU VRM to ensure a longer lifespan for system
ECS Durathon Technology ensure the stability, reliability and performance of system.
(Triple Density PCB; Extreme Temp Resistance; 1.5K Marathon Test; Superior Solid CAPs)
Dual Display design for multiple output support
Integrated Printer (LPT) port / header to expand functionality
Microsoft Windows 8 Certified
Intel ® VRD 12 Ready
Supports DirectX® 11 to enhance graphical performance
Supports HDMI 1.4a Technology ( resolution up to 1920X1200 ) and HDCP function
ECS Intelligent EZ Utility : eBLU, eDLU, eSF
Free Bundle: Norton Internet Security ,CyberLink PowerDVD, CyberLink PowerDirector 9,
Muzee, Google Chrome, Magix with trial version
Biostar
Biostar J1800NH Ver. 6.x
On board Intel Dual-core Celeron J1800 processor
Supports 1 SO-DIMM of DDR3L(1.35V) 1333/1066MHz up to 8G maximum capacity
Intel HD Graphics
Mini size (17*17cm ) for flexible use
Supports BIO-Remote 2 Technology
Supports Charger Booster Technology
ASUS
J1800I-C
All of the manufacturers now have BIOS updates (or didn't need them) and driver support for Windows 7.
All the boards (except the MSI) are available at retailers all over the globe.
Some gotchas to watch out for:
- Some boards require low-voltage (1.35V) RAM so pay attention to the specs
- Intel's driver control panel for these motherboards is missing adjustable scaling for removing overscan
- Testing with the ASRock Q1900B-ITX in Windows 7 shows HD bitstreaming formats not supported by audio driver (might apply to other as well?)
Subscribed!!
Now we just need some retailers to start selling these babies. I have some worries though from what I've been reading in the BayTrail NUC thread around OpenELEC and Windows 7.
@ Dougie can you elaborate a bit, or link to the thread? I'm keen on the BayTrail NUC as a possible upgrade soon. Thanks
(2014-01-31, 00:05)nooz Wrote: [ -> ]@ Dougie can you elaborate a bit, or link to the thread? I'm keen on the BayTrail NUC as a possible upgrade soon. Thanks
All the bay trail threads are on page 1 of this section. Hard to miss really!
A pre-order listing at an actual US retailer!
http://www.directron.com/j1800nh.html
Biostar J1800NH $55.99 + shipping
Any Asus ones yet?
This should be the same platform as the Baytrail NUC am I right? There are so many Intel CPUs I have no idea what is what anymore.
Since I already have a case and everything I just want to know if I will get the same performance as with the DN2820 NUC.
I have the IMB151, been running it for a couple of weeks now with TBS6981
Only supports Win8, BIOS doesn't seem to like booting reliably with Win7
Limited drivers around and no new BIOS as yet
Seems pretty stable
Idles at around 7-8w without Sat Card, 1 SODIM and a mSATA card. No KB, Mouse or HDMI connected just Ethernet
I'm hoping there are a decent amount of options with the Celeron J1900. I want to use that for my server build.
I've been thinking about using an embedded solution like this one to run a simple NAS with 4 or 5 drives connected, but I'm not sure if I should go for something more powerful. Do you guys think these BayTrail boards would be enough to run FreeNAS with a PCI-express SATA card? I would really only need it to run a few things like Samba, Transmission, and maybe Couchpotato.
The Gigabyte board is now available for order at Amazon.com for US$69.99 with a lead time of 2-4 weeks.
http://www.amazon.com/Gigabyte-Dual-Core...B00IFE4VF8
The Gigabyte board is now available at Newegg.com for US$74.99 + shipping
http://www.newegg.com/Product/Product.as...6813128688
I plan to hold off until the Windows 7 issues are resolved.
Gonna be an issue for openELEC use?
Any news of Asus boards yet? Me likes them ones. Rofl
