2014-05-21, 14:29
Nice - what do you think of the MADI quality? Is it worth it?
I think if we tune the architecture a little bit more - we could get it going.
(2014-05-21, 14:29)fritsch Wrote: [ -> ]Nice - what do you think of the MADI quality? Is it worth it?
(2014-05-21, 11:54)lewzer Wrote: [ -> ]Owners of Q1900-ITX or similar, what temperatures do you get on idle and full load? I've noticed that my Q1900-ITX gets quite hot even in idle - ~61C (after the night of XMBC on, idling) and after an hour of playing blue-ray movie to 80C+. The room temperature is about 21C and there isn't any of airflow going around the room since all windows are closed, however, to comensate that I keep the top lid of case open. The heatsink gets really hot to the touch. The case that I use: http://www.minicase.net/product_E-I5.html
Installed like so: http://i.imgur.com/JCburUF.jpg
Setup: 2x2gb 1.5V ram, 320gb HDD, pci-e wifi card (unused), 60W PSU.
I do not think it should be getting THAT HOT, how about your setups?
In other areas everything works beautifully, the performance is really awesome.
(2014-05-21, 14:54)Dougie Fresh Wrote: [ -> ](2014-05-21, 11:54)lewzer Wrote: [ -> ]Owners of Q1900-ITX or similar, what temperatures do you get on idle and full load? I've noticed that my Q1900-ITX gets quite hot even in idle - ~61C (after the night of XMBC on, idling) and after an hour of playing blue-ray movie to 80C+. The room temperature is about 21C and there isn't any of airflow going around the room since all windows are closed, however, to comensate that I keep the top lid of case open. The heatsink gets really hot to the touch. The case that I use: http://www.minicase.net/product_E-I5.html
With the Q1900B-ITX I got up to 60C after 15min of Prime95 FFT testing in the SH-55 case: http://www.ecosmartpc.com/sh55.html. In my experience, the E-i5 should have better temperatures than the SH-55. Try shifting the bracket away from the heatsink, even if you have to use only 2 of the 4 holes to secure the bracket to the case.
(2014-05-21, 14:45)Aquarius Wrote: [ -> ]Are we contamplateing an OE-specific improvement or would this also be possible on XBMC running under a normal distro ? (provided kernel, modules, libs, etc... are at the correct version).
(2014-05-21, 13:27)fritsch Wrote: [ -> ]Here is another test-image: https://dl.dropboxusercontent.com/u/5572...1fdec9.tar - That one should fix at least the tearing.
(2014-05-20, 19:25)Dougie Fresh Wrote: [ -> ]Don't be a NUClehead. DIY FTW!
Now stop messin' in my thread all of you!
(2014-05-21, 16:34)fritsch Wrote: [ -> ](2014-05-21, 14:45)Aquarius Wrote: [ -> ]Are we contamplateing an OE-specific improvement or would this also be possible on XBMC running under a normal distro ? (provided kernel, modules, libs, etc... are at the correct version).
You asked the very same back here: http://forum.xbmc.org/showthread.php?tid...pid1714206
(2014-05-21, 20:45)trsqr Wrote: [ -> ]There seems to be a J2900 motherboard on the market now:Twice the price of the J1800 ones might be justified since you end up with a quad core, but it seems expensive compared to the J1900 ones. Especially since you consider that the GPU is essentially the same. (i.e. a J2900 wont play movies significantly better than J1800 and J1900, as far as I can see).
http://www.legitreviews.com/intel-bay-tr...ard_141657
It's marketed as a Bay Trail Pentium this time.
(2014-05-22, 11:39)fritsch Wrote: [ -> ]Which "way did you mean"?
