(2017-02-09, 14:18)Regss Wrote: [ -> ]Guys maybe I add one more automatic switch option - "Force to enable profile when KODI start/wake up". This helps when we do some manual change in audio settings and restart KODI then force to switch to choosen profile.
At Kodi start or wake-up, shouldn't be the profile set to the one used for the GUI? From my perspective, the profile used for the GUI is the "default profile"...
Cheers!
Where does it show 1.2.2?
No Sorry was talking about my setup
(Italian: Mi riferivo a me che fino a 1 secondo fa non trovava la 1.2.3)
(2017-02-09, 21:36)Roby77 Wrote: [ -> ] (2017-02-09, 15:24)Regss Wrote: [ -> ]Fast fix. Check 1.2.3
Can't find 1.23 in your repo
Btw now with 1.22 problem disappeared ...strange
Yes, could happened if the addon settings It was not yet saved after update.
(2017-02-09, 23:50)axlt2002 Wrote: [ -> ]Hi,
Just want to notify the following missing label in the settings (version 1.2.3):
Ciao!
heh, I delete label but not delete setting option. This option is no needed.
(2017-02-09, 18:37)candrian Wrote: [ -> ]Wow - Regss, seems that your activity level is really high - is it raining outside?
One minor thing: I start Kodi with "Continue on last channel on startup" to jump directly into the last PVR channel.
So when I left Kodi e.g. with the audio profile he doesn't switch to the video profile after startup. Need to change channel then it works.
Probably solved with your "Force to enable profile when KODI start/wake up".
Once again: minor thing
I do not what to do at work
(2017-02-09, 23:57)axlt2002 Wrote: [ -> ] (2017-02-09, 14:18)Regss Wrote: [ -> ]Guys maybe I add one more automatic switch option - "Force to enable profile when KODI start/wake up". This helps when we do some manual change in audio settings and restart KODI then force to switch to choosen profile.
Cheers!
GUI profile is set always when: start/wake up kodi and on stop playing any content.
Someone maybe want to set some profile when kodi start/wakeup but don't want change to this profile every stop playing.
I think what to do:
GUI profile will be enabled always when stop playin any content
Default or Start profile will enabled when kodi start/wake up
If you enable and set both GUI and Default to the same profile you will get same thing what is now when you enable GUI
or you can adjust it differently to suit your needs
(2017-02-10, 10:07)Regss Wrote: [ -> ]I think what to do:
Agree!
Waiting for the next update then! Thanks!
(2017-02-10, 12:37)Regss Wrote: [ -> ]Done. Waiting for translate https://www.transifex.com/movielib/audio.../stringspo
I 've taken a look, but it seems that there are no new labels to be translated...Am I wrong?
Edit: Just noticed that someone else translated to italian the new strings! Good job!
Just wait for the release now...
lots of italian guys love this project
New releace in repository. v. 1.2.4
Nice - works perfect from my side!
@Reggs
Using latest version from your repo (1.2.4) I have a problem with manual switch, namely the loop between the two profiles. If profile 1 is set in autodetection for TV Shows (or any other content), I can't swith manually to profile 2, it switches back in two seconds to profile 1. I think we had this problem in the first release you sent me, but then you sent me a new version where manual override was working fine.
Sent from Tapatalk from my Z5 Compact
Enable loging in system -> debuging and send me kodi.log when this happens.
