Edit or create file keyboard.xml in userdata/keymaps/ and past this code:
<keymap>
<global>
<keyboard>
<t>RunScript(script.audio.profiles,1)</t>
<a>RunScript(script.audio.profiles,2)</a>
</keyboard>
</global>
</keymap>
(2015-08-27, 13:24)Regss Wrote: [ -> ]Step 1
Go to Programs -> Audio profile -> not run it but choose from context menu -> Configure Add-on
Enable two profiles and add it names that you want
Step 2
Go to System -> Audio settings
Set settings for first profile for example TV by the analog output 2.0
Go to Programs -> Audio profile -> run it
Save settings as first profile
Step 3
Repeat Step 2 and set settings for digital like SPDIF or HDMI and save as second profile
Step 4
Now. You can switch between profiles using key map. I suggest to test it on keyboard keymap.
May you add it in first page ?
I tested on 16 alpha 2 (windows) and it works
Thank you again for this addon
Added and cleaned first post.
Instruction to add button in player OSD (confluence skin):
Edit file KODI/addons/skin.confluence/720p/VideoOSD.xml
Best backup this file to safe place.
Replace line:
<control type="button" id="255">
to:
<control type="togglebutton" id="299">
<left>-55</left>
<top>0</top>
<width>55</width>
<height>55</height>
<label>Audio Profiles</label>
<font>-</font>
<texturefocus>OSDAudioProfilesFO.png</texturefocus>
<texturenofocus>OSDAudioProfilesNF.png</texturenofocus>
<alttexturefocus>OSDAudioProfilesFO.png</alttexturefocus>
<alttexturenofocus>OSDAudioProfilesNF.png</alttexturenofocus>
<onleft>205</onleft>
<onright>255</onright>
<onup>1000</onup>
<ondown>1000</ondown>
<onclick>Close</onclick>
<onclick>XBMC.RunScript(script.audio.profiles,0)</onclick>
</control>
Replace:
to:
<onleft>299</onleft>
Replace:
to:
<onright>299</onright>
Download this two button images and extract to: KODI/addons/skin.confluence/media/
OSDAudioProfiles.zip
(2015-08-27, 14:06)Regss Wrote: [ -> ]Edit or create file keyboard.xml in userdata/keymaps/ and past this code:
Just one point, should that be key
map.xml ?
i think that name doesn't matter...mine is remote.xml (first was aaa.xml)
edit: on open elec
Hi guys,
Thanks for great add-ons.
I'm using Kodi 15 Isengard on Windows 8.1 and Audio Profiles Switcher worked well with two profiles option appear when opening new Video. But a little bit noise every time open new Video.
I already tried to create a new .xml file on keymaps folder with below code:
Quote:<keymap>
<global>
<keyboard>
</keyboard>
</global>
</keymap>
But I don't know how to use that function, press number 1 or 2 alway point me to seek time of video instead of switch audio profile.
My expectation is once I press a key (like F12), It will switch between 2 profiles created. How can I do that option?
Anyone can help me on this case, much appreciated.
(2015-08-27, 18:20)Regss Wrote: [ -> ]Instruction to add button in player OSD (confluence skin):
The above also works in CCM.
Great tool, thanks for your work.
Hi again,
I would like to reset the audio profile to a specific one when rebooting my HTPC machine. Is it possible to call the switch script with a specific profile at startup of kodi?
Best regards,
iCE
In your userdata folder create file autoexec.py and past this code:
import xbmc
xbmc.executebuiltin('XBMC.RunScript(script.audio.profiles,1)')
1 - is a number of profile
Hello,I´m a begginer to this, but love it!
I have done all the steps but I can´t figure out how to toggle betwen audiooutput with the remote, I use Yatse remote. Is it possible?
best regards
johan
install keymap editor and assign the command to a special character or whatever you want(like #,£ etc)
Or better:
Use keymap editor to catch the key of the button you want to use and edit your keymap files as described
