2019-11-25, 16:15
(2019-11-25, 11:40)nojoe Wrote: [ -> ]You can map a button on your remote with the Keymap addon. There is a gen.xml in /userdata/keymaps then.Thanks so much for this trick unfortunately I do not have any button in my remote to allow to this.. My remote have very limited button and I already use the keymap addon to allow the sound on/off button for checking the encoding movie codecs details... (TX8 remote) I saw a trick to switch automatically when a Bluetooth headset is on but I'm not sure this work for my box https://gist.github.com/witokondoria/8f6...47867dc859
Use runscript(script.audio.profiles,0). 0 switches between all save audio profiles. Or use 1, 2 or any profile you'll has saved with the audio Profile addon.
Settings/Profiles from Audio Profile are in /userdata/addon_data/script.audio.profiles.
And if you do a thread search here with "button" then you can find for what you are looking.
Don't need to read 19 pages!
For now Coreelec 9 work perfectly with this profile sound addon (TV or Bluetooth) but I have to click to choose my profile every time I start a movie this is good but menu button or automatic switch ishould be better ... any suggestions will be welcome ! Thx
