2015-02-28, 17:04
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111
2015-02-28, 17:59
(2015-02-28, 12:22)Milhouse Wrote: [ -> ]@evanspae/@mylle: Any change in PVR behaviour with build #0227? This is a "clean" build (including ccache) which could conceivably make a difference, however build #0215 was also a clean build, so I'm just grasping at straws.
If anyone is able to describe an easy way to reproduce the PVR crashes (without tuners etc.) then I'm willing to give it a go, otherwise I'll have to put this aside until someone adds it to an official release and it becomes their problem...
I tried the PVR Demo client, but it worked perfectly (build #0225).
Sorry. Still crashing
Maybe @margro can help?
2015-02-28, 23:27
O, I thought I'm alone within this problem.
I will try to reproduce and describe that problem.
2015-03-01, 02:45
New OpenELEC Isengard build #0228: RPi / RPi2
(Supercedes previous build)
Based on tip of OpenELEC master (6c52ccc9, changelog) and tip of XBMC master (8bc58f45, changelog) with the following modifications:
# uname -a
Linux rpi512 3.19.0 #1 Sat Feb 28 23:39:27 GMT 2015 armv6l GNU/Linux
# vcgencmd version
Feb 28 2015 18:36:00
Copyright (c) 2012 Broadcom
version 8d7f19506c5d561e7db647e02281376e7e139269 (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20150228233837-#0228-g6c52ccc [Build #0228]
# vcdbg log msg 2>&1 | grep DTOK
001535.123: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
- Includes newclock4 patches
- Excludes the OpenELEC fernetmenta patches due to conflicts with newclock4
- Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-3.19.y
- Excludes the OpenELEC kodi-001-helix_rpb_backports patch in favour of sourcing these and possibly more recent patches directly from newclock4 branch
- Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Includes latest libnfs master (6da5bc1c)
- Includes latest libcec master (b3d938a5)
- Includes latest xbmc-pvr-addons master (4657d8ba)
- Includes latest xbmc-addon-xvdr master (3453f901)
- Includes commits from libcec-2.2.0 (popcornmix)
- Includes commits from libnfs/seq-read-example (PR:108)
- Exclude kodi-102-dont_really_depend_on_SDL_image.patch: No longer required
- Exclude kodi-999.95-backportPR6312PR6311PR6295.patch: Already merged in Kodi master
- Include patch: Add experimental splash video
- Include patch: Fix python optimize
- Include patch: Use our own texturepacker
- Include patch: Fix build patch for kodi-pvr-addons
- Include patch: hevcdsp: ARM NEON optimized deblocking filter (ffmpeg)
- Include patch: avcodec/hevcdsp: ARM NEON optimized qpel functions (ffmpeg)
- Include patch: hevcdsp: ARM NEON optimized transforms (ffmpeg)
- Include patch: [librtmp] Update with version from http://stream-recorder.com/forum/customi...16103.html (rtmpdump)
- Include PR:6418: Return correct playlist in Player.GetProperties
- Include PR:6484: [mysql] use compression protocol
- Include PR:6526: [video] getscraperforpath() once is enough
- New firmware
- Kodi 15.0alpha2
- Firmware (Feb 28):
- XBMC:
- FIX: [jni] Context:endBroadcast returns void (PR:6564, 1 commit, 2 files changed)
- Fix cec tv vendor override for values != CEC_MAX_VENDORID (PR:6569, 1 commit, 1 file changed)
- CTextureCacheJob: add fallback hash in case neither mtime/ctime nor size of an image are known (PR:6562, 1 commit, 1 file changed)
- update startup splash image (PR:6572, 1 commit, 1 file changed)
- bump version to 15.0alpha2 (PR:6533, 1 commit, 2 files changed)
- [android] remove Ouya platform as it doesn't meet our minimal android AP... (PR:6448, 1 commit, 3 files changed)
- [settings.xml] - changed several spinners to lists (PR:6176, 1 commit, 1 file changed)
- newclock4:
- New commits in this build:
- [mmalrender] Fix for hang on shutdown (089125ef)
2015-03-01, 08:57
Downloaded built #0228 for RPi2. Working well. After new boot, it greets me with a "splash screen download failed" message. Any thoughts?
2015-03-01, 11:34
Download over PC : http://milhouse.openelec.tv/other/splash.h264
and put this into Pi2:
/storage/.cache/splash.h264
I've install fresh openELEC 5.0.4 on my new Pi2 and after install a new build i had the same Problem.
(think It was two builds before this)
btw: Internetconnexion existed, because Addons was updated after fresh start.
2015-03-01, 13:10
Not sure why you don't have an internet connection between the end of autostart.sh and beginning of kodi.bin, which is when the splash download/video runs... Enabling "Wait for network" should resolve this issue but apparently doesn't. Are you guys using a wired connection or Wifi? I've not seen any splash download problem with a wired connection.
2015-03-01, 13:27
I'm wired connected to a Fritz!Box7490@DSL16000 in germany.
On OSD from this Box my Pi2 appearce immediately - after 5 Seconds later this message appears.
All my devices on Network (15 pieces) have a static IP - no DHCP aktivated.
But it is no problem for me - solved with this little indirection over PC in the direction of "/storage/.cache/" - have fun with :-)
*See You any chance to "put in" this little 5mb h264 Vid in your builds in the future, Milhouse? ;-)
2015-03-01, 13:38
I am also with wired internet, also with static IP.
I tried to access remotely, but there is no storage folder. I assume I will need to mount the card in my PC to access it and cannot do remotely?
2015-03-01, 13:43
(2015-03-01, 13:27)doldi Wrote: [ -> ]*See You any chance to "put in" this little 5mb h264 Vid in your builds in the future, Milhouse? ;-)
It's not a good idea to include the video in every image when it only needs to be installed once... I'll see about adding a "wait for network" feature to the video download. Hopefully you can he'll test it in the next build (rename your existing video).
(2015-03-01, 13:38)steve1977 Wrote: [ -> ]I am also with wired internet, also with static IP.
Use ssh.
2015-03-01, 13:43
I put this video on a approved folder on my PC (Network).
The Pi have acsess to them -so i put from PC folder to the Pi cache folder over the Pi in person ;-)
no problem with ...it works fine for me
2015-03-01, 14:40
Thanks, it worked now. I would think it is much easier to have it as part of the image though. If it requires a 5MB download anyways, why not just download it together with the image?
Also, I actually very much like the animation, but the "cut" between the animation and the Isegard screen is quite harsh. Not sure how it can be done better, but maybe some creative minds have some ideas.
Lastly, I remain to have an issue, which I am not sure what it is related to. Some movie posters do not show properly. Actually, instead of the movie poster, a zoomed in version of the movie poster is being shown. In other words, a small part of it blown up. Not sure whether an error log would be helpful. I initially thought it is because of the texture file, but even after deleting it, it remains the same issue. Happens for around 10% of my movies, so it is quite annoying. This issue was already existent in Helix-stable and now still with Isegard-alpha. I am using mysql and this issue does not exist on my other non-rpi2 clients. I don't remember having the same issue with my RPi1, but I don't have it anymore, so cannot prove whether this is correct.
2015-03-01, 15:05
(2015-03-01, 14:40)steve1977 Wrote: [ -> ]Thanks, it worked now. I would think it is much easier to have it as part of the image though. If it requires a 5MB download anyways, why not just download it together with the image?Well, some users update virtually every day, so it's a choice of 5MB every day, or 5MB just once (the current scheme won't download the video if it's already present).
Not saying that 5MB every update is completely unreasonable, but it is an argument for continuing with the current scheme.
Quote:Also, I actually very much like the animation, but the "cut" between the animation and the Isegard screen is quite harsh. Not sure how it can be done better, but maybe some creative minds have some ideas.You probably also want to add:
"disable_splash=1" to config.txt
nosplash to cmdline.txt
<splash>false</splash> to advancedsettings.xml
to remove the other splash sceens and keep the boot clean.
2015-03-01, 15:12
My system works perfectly with your builds. Yesterday I had to look for an "script error" issue and i found this..
I'm getting 10MB of kodi.log and this keeps on and on.. Actually has 100k lines of log. My remote works perfectly and i'm using RCA output. Any idea for this?
13:01:57 55537.441406 T:1888482368 ERROR: OpenConnection - could not opening a connection to the CEC adapter
13:02:07 55547.445312 T:1888482368 ERROR: CecLogMessage - RegisterLogicalAddress - vc_cec_set_logical_address(E) returned invalid arg (8)
13:02:07 55547.445312 T:1888482368 ERROR: CecLogMessage - Open - vc_cec could not be initialised
13:02:07 55547.445312 T:1888482368 ERROR: CecLogMessage - could not open a connection (try 1)
13:02:08 55548.445312 T:1888482368 ERROR: CecLogMessage - RegisterLogicalAddress - vc_cec_set_logical_address(E) returned invalid arg (8)
13:02:08 55548.445312 T:1888482368 ERROR: CecLogMessage - Open - vc_cec could not be initialised
13:02:08 55548.445312 T:1888482368 ERROR: CecLogMessage - could not open a connection (try 2)
13:02:09 55549.449219 T:1888482368 ERROR: CecLogMessage - RegisterLogicalAddress - vc_cec_set_logical_address(E) returned invalid arg (8)
13:02:09 55549.449219 T:1888482368 ERROR: CecLogMessage - Open - vc_cec could not be initialised
13:02:09 55549.449219 T:1888482368 ERROR: CecLogMessage - could not open a connection (try 3)
13:02:10 55550.449219 T:1888482368 ERROR: CecLogMessage - RegisterLogicalAddress - vc_cec_set_logical_address(E) returned invalid arg (8)
13:02:10 55550.449219 T:1888482368 ERROR: CecLogMessage - Open - vc_cec could not be initialised
13:02:10 55550.449219 T:1888482368 ERROR: CecLogMessage - could not open a connection (try 4)
13:02:11 55551.453125 T:1888482368 ERROR: CecLogMessage - RegisterLogicalAddress - vc_cec_set_logical_address(E) returned invalid arg (8)
13:02:11 55551.453125 T:1888482368 ERROR: CecLogMessage - Open - vc_cec could not be initialised
13:02:11 55551.453125 T:1888482368 ERROR: CecLogMessage - could not open a connection (try 5)
13:02:12 55552.457031 T:1888482368 ERROR: CecLogMessage - RegisterLogicalAddress - vc_cec_set_logical_address(E) returned invalid arg (8)
13:02:12 55552.457031 T:1888482368 ERROR: CecLogMessage - Open - vc_cec could not be initialised
13:02:12 55552.457031 T:1888482368 ERROR: CecLogMessage - could not open a connection (try 6)
13:02:13 55553.457031 T:1888482368 ERROR: CecLogMessage - RegisterLogicalAddress - vc_cec_set_logical_address(E) returned invalid arg (8)
13:02:13 55553.457031 T:1888482368 ERROR: CecLogMessage - Open - vc_cec could not be initialised
13:02:13 55553.457031 T:1888482368 ERROR: CecLogMessage - could not open a connection (try 7)
13:02:14 55554.457031 T:1888482368 ERROR: CecLogMessage - RegisterLogicalAddress - vc_cec_set_logical_address(E) returned invalid arg (8)
13:02:14 55554.460938 T:1888482368 ERROR: CecLogMessage - Open - vc_cec could not be initialised
13:02:14 55554.460938 T:1888482368 ERROR: CecLogMessage - could not open a connection (try 8)
13:02:15 55555.460938 T:1888482368 ERROR: CecLogMessage - RegisterLogicalAddress - vc_cec_set_logical_address(E) returned invalid arg (8)
13:02:15 55555.460938 T:1888482368 ERROR: CecLogMessage - Open - vc_cec could not be initialised
13:02:15 55555.460938 T:1888482368 ERROR: CecLogMessage - could not open a connection (try 9)
13:02:16 55556.460938 T:1888482368 ERROR: CecLogMessage - RegisterLogicalAddress - vc_cec_set_logical_address(E) returned invalid arg (8)
13:02:16 55556.460938 T:1888482368 ERROR: CecLogMessage - Open - vc_cec could not be initialised
13:02:16 55556.460938 T:1888482368 ERROR: CecLogMessage - could not open a connection (try 10)
13:02:17 55557.460938 T:1888482368 ERROR: CecLogMessage - could not start CEC communications
13:02:17 55557.464844 T:1888482368 ERROR: OpenConnection - could not opening a connection to the CEC adapter
13:02:27 55567.464844 T:1888482368 ERROR: CecLogMessage - RegisterLogicalAddress - vc_cec_set_logical_address(E) returned invalid arg (8)
2015-03-01, 15:20
You probably just want to disable CEC in Settings -> System -> Input devices -> Peripherals -> CEC Adapter -> Enabled
