(2015-03-05, 02:26)Milhouse Wrote: [ -> ]@doveman2: are you sure you are installing the correct build (ie. RPi2 build on a Pi2, RPi build on a Pi1 etc.)?
Doh! I installed the RPi build on my B but then installed the same build on my RPi2
Thanks for the nudge. It'll be a lot simpler when I give the B to my sister and only have v2's in my house
Can you confirm that this line is correct for cmdline.txt please?
boot=/dev/mmcblk0p1 disk=/dev/mmcblk0p2 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 ssh quiet
After installing the correct build, the USB tuner still doesn't work on the v2 though and the 02_System.log
http://pastebin.com/3ZMpYGdf doesn't seem to have any reference to it, unlike on the B where it shows:
[ 2.296726] usb 1-1.3: new high-speed USB device number 4 using dwc_otg
[ 2.394884] usb 1-1.3: New USB device found, idVendor=1b80, idProduct=e409
[ 2.394913] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.394928] usb 1-1.3: Product: DVB-T TV Stick
[ 2.394943] usb 1-1.3: Manufacturer: ITE Technologies, Inc.
Although the 03_Hardware.log from my v2 seems to refer to it as a "Zolid Mini DVB-T Stick" (I need to check what the log from my B says):
http://pastebin.com/AWegQdT1
I know it's probably not a priority for you but I had the same experience as before updating this B from Gotham to #303, where it lost all the settings. I observed the state after booting, before going through the wizard and I noticed that Userdata\addon_data\service.openelec.settings was empty until I stepped through the wizard, so either that's getting wiped or it was previously located elsewhere. The other files (guisettings.xml) were still present though, so I don't know why it lost those settings (reset from Expert to Basic being the most obvious). Comparing guisettings.xml from immediately after booting and after completing the wizard, the only significant difference is that the latter has the <skinsettings> section populated with basic settings for Confluence, whereas the former has this section empty, so perhaps that is getting wiped when updating for some reason.
