Looks like a linker issue, couls very well have to do with the recent platform split. I don't think all addons have been adapted yet so that could be the reason.
(2015-05-09, 14:17)negge Wrote: [ -> ]Looks like a linker issue, couls very well have to do with the recent platform split. I don't think all addons have been adapted yet so that could be the reason.
OK thanks, yes things are still a bit fluid so maybe there's further changes planned for pvr.dvbviewer. Maybe circle back round to this in a week or so.
From the ipatches.dat:
=master PR7072 [pvr] bumps addons to use libplatform
Shouldn't it be
PR7069?
Yes, thanks - fricking moving target!
(2015-05-09, 13:30)popcornmix Wrote: [ -> ]60Hz is much smoother than 50Hz when playing 24fps content. In general if you can't choose an exact frequency multiple then the higher the refresh rate the better (the average error in displayed frame time is smaller). Additionally 60:24 gives a 5:2 ratio which allows a regular 3:2 pulldown. 50:24 is much more irregular so looks more juddery.
Thanks for the explanation, I'll make a note of that for future reference.
(2015-05-09, 05:30)doveman2 Wrote: [ -> ]Although since I got it home I haven't been able to get it to boot past the rainbow screen (just get a cursor top left after that) on my own TV, even after updating the files on the /flash and deleting most of the files from /storage (which I used Paragon ExtFS in Windows for, very handy utility).
I'll try another SD card I've got and hopefully will get it working again.
I had to write the SD card from an image to get it working again, don't know what went wrong but at least it's not the hardware
@milhouse: enabling in decoder settings helped showing the modules as playable.
however i still cant play any of them:
7:24:54 16701.896484 T:1968398336 NOTICE: ADDON: Loaded virtual child addon special://temp/audiodecoder.modplug-000.so
17:24:54 16701.898438 T:1968398336 ERROR: ADDON: Could not locate audiodecoder.modplug.so
17:24:54 16701.914062 T:1968398336 NOTICE: ADDON: Loaded virtual child addon special://temp/audiodecoder.modplug-000.so
17:24:54 16701.914062 T:1968398336 ERROR: ADDON: Could not locate audiodecoder.modplug.so
17:24:54 16701.914062 T:1968398336 ERROR: CAudioDecoder: Unable to Init Codec while loading file /storage/music/MITRAX.MOD
17:24:54 16701.914062 T:1968398336 WARNING: PAPlayer::QueueNextFileEx - Failed to create the decoder
17:24:54 16701.914062 T:1968398336 ERROR: Playlist Player: skipping unplayable item: 0, path [/storage/music/MITRAX.MOD]
17:24:55 16702.425781 T:1588589632 NOTICE: Thread PAPlayer start, auto delete: false
17:24:55 16702.654297 T:1968398336 NOTICE: ADDON: Loaded virtual child addon special://temp/audiodecoder.modplug-000.so
17:24:55 16702.654297 T:1968398336 ERROR: ADDON: Could not locate audiodecoder.modplug.so
17:24:55 16702.812500 T:1968398336 NOTICE: ADDON: Loaded virtual child addon special://temp/audiodecoder.modplug-000.so
17:24:55 16702.812500 T:1968398336 ERROR: ADDON: Could not locate audiodecoder.modplug.so
17:24:55 16702.812500 T:1968398336 ERROR: CAudioDecoder: Unable to Init Codec while loading file /storage/music/MITRAX.MOD
17:24:55 16702.812500 T:1968398336 WARNING: PAPlayer::QueueNextFileEx - Failed to create the decoder
17:24:55 16702.812500 T:1968398336 ERROR: Playlist Player: skipping unplayable item: 0, path [/storage/music/MITRAX.MOD]
17:24:56 16703.335938 T:1588589632 NOTICE: Thread PAPlayer start, auto delete: false
i use latest build
I suspect it's the way they've been built/installed, and the addon libraries haven't been added to the LD_LIBRARY_PATH as they would if they were downloaded and installed. It's not something I'm going to be able to fix any time soon, I'm afraid - probably one of the reasons why these addons shouldn't be shipped as part of the image...
Edit: Although saying that, all the shared libraries from the other addons (visualizations, pvrs, kodi libraries etc.) are being loaded, so maybe it's a problem with whatever addon is trying to load this audiodecoder - is it up to date with the latest binary addons/platform changes? Hmmm...
It seems to be failing to copy the shared library into .kodi/temp, I'll see if I can work out why and fix it..
Edit: Grrrr... it's trying to copy the shared library from /usr/share/kodi/addons/audiodecoder.modplug/audiodecoder.modplug.so when the library is actually in /usr/lib/kodi/addons/audiodecoder.modplug/
Edit2: I'll include a fix in tonight's build.
All add-ons were updated. The problem is - most likely - libkodiplatform/libplatform split on some OSes. See
https://github.com/xbmc/xbmc/pull/7069
Milhouse, I checked pvr.dvbviewer like you asked and, AFAICT all pvr add-ons build correctly for RPi.
I might be missing something because my build env is somewhat moody right now.
My personal dependency hell, I tell you.
New OpenELEC Isengard build #0509:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.0.1 #1 Sat May 9 22:15:00 BST 2015 armv6l GNU/Linux
# vcgencmd version
May 1 2015 18:56:06
Copyright (c) 2012 Broadcom
version f5f5ba5f2423c3dff6ccd4ca4b832264cd33f12a (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20150509221412-#0509-g9db0648 [Build #0509]
# vcdbg log msg 2>&1 | grep DTOK
001530.052: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of
OpenELEC master (9db0648d,
changelog) and tip of
XBMC master (ebd3172c,
- Includes newclock4 patches
- Excludes the OpenELEC fernetmenta patches due to conflicts with newclock4
- Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.0.y
- Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Includes latest dcadec master (98fb3b60)
- Includes latest kodi-platform master (054a42f6)
- Includes latest libcec master (e39ec0fc)
- Includes latest libnfs master (77e3d80f)
- Includes latest platform master (7a54556b)
- Includes latest addons: audiodecoder.modplug (c7e8ca82), audiodecoder.nosefart (c77e5a12), audiodecoder.sidplay (f2e7d985), audiodecoder.snesapu (9fc775b1), audiodecoder.stsound (775c858d), audiodecoder.timidity (bf9ff93d), audiodecoder.vgmstream (0c3a51a2), audioencoder.flac (84acb141), audioencoder.lame (3eb59de9), audioencoder.vorbis (d556a687), audioencoder.wav (40aaedfa), pvr.argustv (2c8fd66f), pvr.demo (da6b9cb6), pvr.dvblink (7a246406), pvr.dvbviewer (cf13773a), pvr.filmon (933482c0), pvr.hts (e27bf37e), pvr.iptvsimple (48b11900), pvr.mediaportal.tvserver (ca7abf3e), pvr.mythtv (7c1f311f), pvr.nextpvr (c13e8e26), pvr.njoy (deea68bd), pvr.pctv (d80844ba), pvr.stalker (92cb0210), pvr.vbox (d5f4669b), pvr.vdr.vnsi (824a8a4c), pvr.vuplus (e47adee6), pvr.wmc (c25a7deb)
- Includes commits from shairplay/master (juhovh)
- Exclude kodi-995.01-add-dcadec-support.patch: Temporarily revert dcadec settings and use newclock4 version
- Include patch: Hack for addon libraries (link)
- Include patch: Enable dcadec on x86
- Include patch: Add experimental splash video
- Include patch: Enable audiodecoder, audioencoder, pvr and visualization addons
- Include PR:6: readd sockets/cdevsocket.h, needed by IMX6 and TDA995x (platform)
- Include PR:4136: bump libcec & kodi
- Include PR:6732: [pvr] fixed crash when multiple add-on instances get registered
- Include PR:6919: added: also hide thumbs for unwatched episodes if option to show plot is off
- Include PR:7048: videodb: Don't allow column value length to exceed key size of unique index
- Include PR:7069: [cmake] add libplatform to kodi-platform depends
- Include PR:7093: [AirTunes] - features
- Include PR:7104: [KeyMapping/Joystick] - fix regression introduced in https://github.com/xbmc/xbmc/pull/5624
- Revert e8cd8e8f: Stick with 4.0.1, wait for rpi-4.0.y sync
Build Highlights:
- Fix certificate error with curl https downloads
- Fix library issue with audiodecoders
- Bump libbluray 0.8.0
- Add AirPlay/AirTunes and libshairplay updates
Build Details:
- OpenELEC:
- [libressl] fix certificate name (PR:4138, 1 commit, 1 file changed)
- libressl: symlink cert.pem (9db0648d)
- XBMC:
- renderer: Use a structure for information passed from renderer to codec (PR:7087, 1 commit, 18 files changed)
- [mmalcodec] Remove dropping logic. It only seems to make things worse (PR:7090, 1 commit, 2 files changed)
- Add romanian keyboard layout (PR:7009, 1 commit, 1 file changed)
- [mmal] Fix issues related to mmal buffer reference counts (PR:7092, 11 commits, 8 files changed)
- [skin.confluence] fix overlapping mute-bug in FullscreenVideo/OSD (PR:7091, 1 commit, 2 files changed)
- platform:
- pvr.vdr.vnsi:
- [debian] fix packaging with multi-arch (PR:8, 1 commit, 2 files changed)
- shairplay/master (juhovh):
- New commits in this build:
- Prevent a memory leak in digest.c (06582fec)
- Clean up a series of ifs, remove redundant processing. (51114600)
- Double the RAOP_BUFFER_LENGTH to avoid stuttering (590c2b20)
- Make password authentication work on iTunes again, fixes #20. (8e679577)
- Add a clarifying comment to the last commit (8c3f8f7a)
- Do not give IPv4 any special treatment in httpd code (1e8b64fd)
- Add some compatibility defines to dnssd.c. (53aa6852)
- Update README (193138f3)
- Add DLL building support to autotools scripts (aeed166b)
- IPV6_V6ONLY set by default on win32 (64d59e30)
- Update alac to a newer version, hopefully fixes #24. (82bd213d)
- [raop] - also forward png data to the coverart callback (71bae68d)
- [DACP] - add callback for dacp remote control meta data (audio_remote_control_id) (2fe2599c)
- Merge pull request #36 from Memphiz/add_png_coverart (8744cb5b)
- Merge pull request #37 from Memphiz/add_dacp_callback (4881e378)
- Remove unnecessary casts from raop_rtp. (5be4c19d)
- Add support for passing the progress values to raop callbacks. (3cce6768)
- Merge pull request #38 from Memphiz/progress (0f41ade2)
- newclock4:
- Commits no longer in build:
- renderer: Use a structure for information passed from renderer to codec (58171c82)
- [mmalcodec] Remove dropping logic. It only seems to make things worse (2c1c4fb3)
- [mmalcodec] Return mmal buffers explicitly (98aa45a4)
- [mmalcodec] Handle resolution change from callback (ebe2127c)
- [mmal] Enable zero copy (acb6be21)
- [mmal] Add some sanity checks to mmal flags (fc154f29)
- [mmal] Move the image pool from decoder to renderer (02fa7a2b)
- [mmalrenderer] Separate mmal and renderer configured flags (19eef8e3)
- [mmal] Separate the buffers from the decoder so decoder can be destroyed first (a90fc0ad)
- [mmalcodec] Remove DVDVideoCodecMMAL wrapper (edb6a3ee)
- [mmalcodec] Add shared lock around MMAL operations (79a43061)
- [mmalrenderer] Add shared lock around MMAL operations (b4b9bff0)
- [mmalrenderer] Remove release thread - shouldn't be required (b0a00bad)
- [RBP] Fix for cachemembuffersize initialisation and multiple profiles (0bd0fd66)
- [cec] Allow repeat delay to be increased higher (c518545c)
(2015-05-09, 23:57)h.udo Wrote: [ -> ]All add-ons were updated. The problem is - most likely - libkodiplatform/libplatform split on some OSes. See https://github.com/xbmc/xbmc/pull/7069
Thanks. I've included PR7069 this time around which had a change to project/cmake/addons/depends/common/kodi-platform/deps.txt, but other than that I'm not seeing anything which would make a difference.
Hopefully @
startv can confirm by testing #0509, but if there's no change I'm outta ideas...
Sadly, I have to confirm that the VU+/Enigma2 add-on is still not functioning.
Kodi gets into a continuous loop again. A quick fix for me is to revert to #0504 and it just works.
If Kodi gets stuck in a loop, just use the manual update method. Open file explorer, go to \\[IP from raspberry]\update and transfer the #0504 .tar file.
Saved me some re-imaging. I hope the PVR add-ons will work in the near future.
Thanks for the effort though.
p.s. The PVR IPTV Simple Client still works perfectly!
-EDIT- It took a bit longer this time to get things working again.
(I use 2 PVR add-ons simultaneously, IPTV Simple Client and VU+/Enigma2)
If you revert to #0504, the VU+ addon says DISABLED, but in #0509 it isn't.
I tried to upgrade to #0509 again and Kodi goes into the loop.
Reverted back to #0504, disabled the TV service and upgraded to #0509 again.
Now the VU+ add-on says ENABLED and I have to disable it.
After just selecting the IPTV Simple Client, I can enable the TV service again and all is good. Sort of...
