(2015-05-06, 16:10)Milhouse Wrote: [ -> ]"noram" is always the case now, as loading SYSTEM into RAM is no longer supported - the benefit is negligible but wastes over 100MB RAM (not that loading into RAM ever worked on a 256MB Pi).
For swap, try ruunning configrpi256.sh to enable swap and increase swappiness.
cachemembuffers sounds like an old/deprecated setting. Try not to include settings in advancedsettings.xml unless you are sure you need them - trust the defaults, as old settings are likely to make performance worse than better.
Thnx for the explanation. Ran the configrpi256.sh (ran it before succesfully on one of your Jan. builds) but with #505, both the swap.conf and autostart.sh files are created/modified but the swapfile itself isn't. Done some testing (delete both swap.conf and autostart.sh) and it seems like you don't need to create a swapfile anymore. Without it performance is very much OK, considering it's a 256 MB Pi.
Hi, I have a more or less reproducible error with 3D movies.
If "Use full HD HDMI Modes for 3D" isn't disabled some movies won't start,
I only have HDMI sync until I press stop and other movies start but have HDMI resync while playing.
If function is turned of at moment everything is running. Then a second thing, if I activate the function
to select 2D or 3D visualisation before movie starts I only get sound and video is still in main menu with 2D or 3D.
This problem I have with every Testbuild so far!
Giz
Quote:If better button repeat is still needed in 3.0.0, then let us know.
Quote:Yes it's still needed, otherwise browsing results too slow.
slack3r
Are you aware that with many lists in Kodi interface you can utilize horizontal arrows on remotes/keyboards as well as the vertical arrows in order to switch "between" stepping vertically through individual items, to paging through items lists and vise-versa. I only mention this as I found it recently almost by chance and find it very useful and much quicker with long listings.
MikeKL
Thank you for reply.
Yes I am, but it's not the same thing. CEC remote control is not usable without popcornmix's commits.
No pvr update for TVHeadend.?
(2015-05-06, 20:55)MortUK74 Wrote: [ -> ]No pvr update for TVHeadend.?
pvr.hts is an update to TVHeadened frontend and Milhouse has also kindly provided updates to the TVHeadend backend service, you just need to read back through some posts in this thread
i.e. within
#503 for TVHeadend backend (download relevant additional available addon zip) and then
#505 for pvr.hts (see updates mentioned within #505 text)
(2015-05-06, 22:42)MikeKL Wrote: [ -> ] (2015-05-06, 20:55)MortUK74 Wrote: [ -> ]No pvr update for TVHeadend.?
i.e. #503 for TVHeadend backend (download relevant additional available addon zip) and then #505 for pvr.hts (see updates mentioned in #505)
Awesome.. Thank you for the reply..
I actually only use the front end for TVHeadend on the Pi as my tuners are elsewhere.
(2015-05-06, 17:23)charlieroot Wrote: [ -> ]Ran the configrpi256.sh (ran it before succesfully on one of your Jan. builds) but with #505, both the swap.conf and autostart.sh files are created/modified but the swapfile itself isn't.
The swapfile (default 128MB) is automatically created when you reboot. What is the output of the "free" command after you run configrpi256.sh and reboot?
(2015-05-06, 17:08)Gregoire Wrote: [ -> ]As a plus; pvr iptv simple works like it's a real tv. Switching is smooth and fast. No trouble with kodi rebooting.
That's great, thanks for confirming at least one of the PVR addons is working!
For anyone experiencing Kodi restarts - crashlogs are the minimum required to investigate further.
A crashlog from a debug-enabled build is best as the standard crashlog doesn't always contain the required information, but these debug-enabled builds require a FAT partition of 380MB or so - if you can resize your FAT partition please do so. I've uploaded debug builds based on #0505 here:
RPi /
RPi2
New OpenELEC Isengard build #0506:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.0.1 #1 Wed May 6 21:12:00 BST 2015 armv6l GNU/Linux
# vcgencmd version
May 1 2015 18:56:06
Copyright (c) 2012 Broadcom
version f5f5ba5f2423c3dff6ccd4ca4b832264cd33f12a (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20150506211111-#0506-gd91e2fc [Build #0506]
# vcdbg log msg 2>&1 | grep DTOK
001522.612: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of
OpenELEC master (d91e2fc6,
changelog) and tip of
XBMC master (d6a7472b,
- Includes newclock4 patches
- Excludes the OpenELEC fernetmenta patches due to conflicts with newclock4
- Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.0.y
- Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Includes latest dcadec master (98fb3b60)
- Includes latest libcec master (e39ec0fc)
- Includes latest libnfs master (77e3d80f)
- Includes latest addons: audiodecoder.modplug (c7e8ca82), audiodecoder.nosefart (c77e5a12), audiodecoder.sidplay (f2e7d985), audiodecoder.snesapu (9fc775b1), audiodecoder.stsound (775c858d), audiodecoder.timidity (bf9ff93d), audiodecoder.vgmstream (0c3a51a2), audioencoder.flac (84acb141), audioencoder.lame (3eb59de9), audioencoder.vorbis (d556a687), audioencoder.wav (40aaedfa), pvr.argustv (2c8fd66f), pvr.demo (da6b9cb6), pvr.dvblink (7a246406), pvr.dvbviewer (cf13773a), pvr.filmon (933482c0), pvr.hts (e27bf37e), pvr.iptvsimple (48b11900), pvr.mediaportal.tvserver (ca7abf3e), pvr.mythtv (7c1f311f), pvr.nextpvr (c13e8e26), pvr.njoy (deea68bd), pvr.pctv (d80844ba), pvr.stalker (92cb0210), pvr.vbox (d5f4669b), pvr.vdr.vnsi (153fb125), pvr.vuplus (e47adee6), pvr.wmc (c25a7deb)
- Include master...stefansaraev:0ead3dff: Add platform package, libCEC 3.0.0 support
- Include patch: Add experimental splash video
- Include patch: Enable audiodecoder, audioencoder, pvr and visualization addons
- Include PR:6732: [pvr] fixed crash when multiple add-on instances get registered
- Include PR:6919: added: also hide thumbs for unwatched episodes if option to show plot is off
- Include PR:7048: videodb: Don't allow column value length to exceed key size of unique index
- Include PR:7061: addons: pvr and audiodecoder are optional addons, disable by default
- Include PR:7065: [pvr] Bump pvr.hts to version 2.1.8
- Include PR:7072: [pvr] bumps addons to use libplatform
Build Highlights:
- sdhost driver support added in OpenELEC
- dcadec updates
- Two more GLES screensavers - Ball and Spiral
Build Details:
- OpenELEC:
- projects/imx6/linux: Enable HIGHMEM (549555f6)
- linux: update to linux-cuboxi-3.14-ea83bda for imx6 project (5059817d)
- u-boot: update to u-boot-imx6-144b1e9 for imx6 project (5f9d1a9a)
- projects/RPi*/patches/linux: update RPi support patches (d91e2fc6)
- XBMC:
- [strings] fix capitalized second/third word (PR:7054, 1 commit, 1 file changed)
- [strings] Fixed msg 31117 to match 31116 (PR:7076, 1 commit, 1 file changed)
- dcadec:
- Factor out X96 decoder allocation routine. (68ba36ec)
- Define and use macros for bit-swapping integer constants. (9067bfbe)
- Avoid using GCC-specific statements-as-expressions syntax. (0b343fd3)
- Prefer inline dca_popcount() implementation. (c1069c62)
- Avoid using __builtin_bswap32/64() before GCC 4.3. (7dcdfa3f)
- Add fallback implementations of dca_clz32/64(). (4007ab34)
- Move some defines and includes. (663c3206)
- Make the library buildable by MSVC. (6c0b31eb)
- Disable debugging by default, check for _DEBUG. (4c3191d2)
- Move compiler-specific cruft into compiler.h. (e54330ed)
- Add replacement getopt() from musl libc. (d7336620)
- Add Visual Studio 2013 project files. (98fb3b60)
- pvr.vbox:
- fixed include path in VBox.h (closes #40) (aa929bf9)
- fixed wrong library name for Android (closes #38) (f96cf1c1)
- bump version to 1.0.2 (d5f4669b)
- pvr.vdr.vnsi:
- fix leftover from moving to platform (153fb125)
- newclock4:
- New commits in this build:
- fixup! renderer: Allow an opaque pointer to be passed from renderer to codec (30ef9a6b)
- fixup! [screensavers] Couple more... (8e6ed05c)
- squash: Move renderinfo into a structure (7aa22258)
I just installed the last one. It's a little faster, the boot is faster. Really cool Milhouse.
(2015-05-06, 23:25)Milhouse Wrote: [ -> ] (2015-05-06, 17:08)Gregoire Wrote: [ -> ]As a plus; pvr iptv simple works like it's a real tv. Switching is smooth and fast. No trouble with kodi rebooting.
A crashlog from a debug-enabled build is best as the standard crashlog doesn't always contain the required information, but these debug-enabled builds require a FAT partition of 380MB or so - if you can resize your FAT partition please do so. I've uploaded debug builds based on #0505 here: RPi / RPi2
I'm using DVBLink at the moment, (Looking to switch back to TVHeadend)
I was getting crashes and freezes while watching live TV when i upgraded to build 505.. I had OMXplayer disabled but when I enabled it, it appears to have fixed the issue.. PVR works fine at the moment.
Mort..
(2015-05-06, 23:55)MortUK74 Wrote: [ -> ]I was getting crashes and freezes while watching live TV when i upgraded to build 505.. I had OMXplayer disabled but when I enabled it, it appears to have fixed the issue.. PVR works fine at the moment.
Mort..
Enabling OMXPlayer hasn't fixed the issue at all, you've just found a way to avoid it. Upload your crashlog so that the issue has a chance of being fixed.
(2015-05-06, 23:07)Milhouse Wrote: [ -> ] (2015-05-06, 17:23)charlieroot Wrote: [ -> ]Ran the configrpi256.sh (ran it before succesfully on one of your Jan. builds) but with #505, both the swap.conf and autostart.sh files are created/modified but the swapfile itself isn't.
Ran the configrpi256.sh rebooted and "free" reports:
OpenELEK:~ # free
total used free shared buffers
Mem: 139176 111416 27760 4716 12320
-/+ buffers: 99096 40080
Swap: 133448 304 133144
Swap seems to be enabled but I can't find the swapfile. #0506 behaves the same. The GUI (System, System info, Hardware) reports 69MB free memory (was about 80MB without swap configured on #0505).
The filename of the swapfile will be: /storage/.cache/swapfile
# ls -la /storage/.cache/swapfile
-rw------- 1 root root 134217728 Jan 1 1970 /storage/.cache/swapfile
or check with "cat /proc/swaps":
# cat /proc/swaps
Filename Type Size Used Priority
/storage/.cache/swapfile file 131068 20 10000
