Yea, it works only with windows drives
I'll have a look at NFS.
In TEST repo:
v3.12
- Small fixes
- Option to check broken sources
- Support for NFS
- Translations
v3.2
- Small fixes
- Support for NFS
- Translations
Great work with this addon, a must have for many low rom android version.
I've got a question:
Although I ticked the ignore prewash scrub option my database backup files from the Video Database Cleaner located in the database subfolder are deleted everytime I run KCleaner - did I miss something here?
There might be a bug concerning prewash.... just took a look at the source and I think I found it. Give me a few days and I'll post a possible fix for you to test in test repo.
(2019-01-07, 15:50)DaLanik Wrote: [ -> ]There might be a bug concerning prewash.... just took a look at the source and I think I found it. Give me a few days and I'll post a possible fix for you to test in test repo.
Ok, thanks a lot
In the TEST repo:
v3.3
- Small fix for prewash
please let me know if it works
D.
(2019-01-10, 11:03)DaLanik Wrote: [ -> ]In the TEST repo:
v3.3
D.
Works for me - database backups aren't deleted anymore when prewash is ticked to ignore.
Thank you very much!
Cool, so I'll move it shortly to normal repo.
v3.3
On Kodi 18 for Android the two following options don't work anymore:
-Check for unused repositories
-Check for addons without repo
Nothing happens. Let me know if you need more info.
And a big thank you for still maintaining this nice addon. Imho the best cleaning addon for Kodi.
Can you turn on debugging, exit Kodi, then run Kodi again and run these 2 options, then quit Kodi, and post the log?
Just checked, and "addons w/o repo" is working for me....
(2019-02-05, 16:51)DaLanik Wrote: [ -> ]Just checked, and "addons w/o repo" is working for me....
I've sent you the logfile in Tapatalk chat.
