wuppertroll Wrote:Is it possible to add the videos from the new ct'tv page to the PlugIn?
http://www.heise.de/ct-tv/
Would be very nice if I could watch the videos in the future on my Xbox.
Gruß,
wuppertroll
pr0m Wrote:Same probleme here I have Atlantis Beta 2, i install all but when i try to load the plugin from source, i have a crash. (xbmc on a mac)
Can you please check the newest version...
Nigggo Wrote:is it my fault or is joox not working? i can see all directiories and files but if i click a stream to play nothing happens. i use newest xbmc on xbox. thx
I just removed Joox
It is broken.
bye,
sfaxman
where do i get the latest version`?
shizzle Wrote:where do i get the latest version`?
The first post of
the user thread
EDIT: I updated the dowload links in the first post of this thread
sfaxman...
Anyone else having trouble getting xhamster to load in videomonkey now?
Yesterday I couldnt get videos to play now I cant even get xhamster to load it just goes back to my lists.
slappymcgee Wrote:Anyone else having trouble getting xhamster to load in videomonkey now?
xhamster is not included in the plugin
If anyone share the archiv one more time i will add it to the adult pages. The download link in this thread does not work for me
BTW i just fixed most of the adult sites
The rest will follow
Enjoy
bye,
sfaxman
Yes thats the script but for some reason I cant get it to run correctly anymore. I click to load it from video monkey and it brings up a dialog then closes and takes me back to the site list in video monkey.
The sites layout has has changed or someting. It stoped working a day or 2 ago.
If I knew how to write
these scripts I would try and change it.
Ok looks like xhamster works now.
When I load Videomonkey in XBMC, it isn't listing all of the resources in the actual folder. I only see clipfish, dailymotion, google video, metacafe, myspass and youtube. Where are all of the other ones, like redtube, pornhub, etc? The list and cfg files are showing in the resources folder,, but not when i load it thru xbmc. Also, how do you access the settings of Videomonkey? Sorry if these are noob questions, but I am very new to the modding scene.
rybanv Wrote:When I load Videomonkey in XBMC, it isn't listing all of the resources in the actual folder. I only see clipfish, dailymotion, google video, metacafe, myspass and youtube. Where are all of the other ones, like redtube, pornhub, etc? The list and cfg files are showing in the resources folder,, but not when i load it thru xbmc. Also, how do you access the settings of Videomonkey? Sorry if these are noob questions, but I am very new to the modding scene.
You need to enable adult content in the script settings,witch is in the context menu I believe.You can get to it with the white button on your controller while at Video Plugings/Video Monkey if your using XBMC for xbox.
Rookie Wrote:You need to enable adult content in the script settings,witch is in the context menu I believe.You can get to it with the white button on your controller while at Video Plugings/Video Monkey if your using XBMC for xbox.
Thank you, that was exactly what I needed.
