2020-01-18, 01:02
(2020-01-17, 23:07)sdsnyr94 Wrote: [ -> ]the tube felt sluggish.. slower than the 2015/2017 shields I have.Probably due to the fact it only has 2GB RAM whereas the 2015, 2017, and Pro all have 3GB RAM.
(2020-01-23, 13:49)Dr.Feelgood Wrote: [ -> ]Hi,
can someone confirm if 3840x2160 YCbCr 4:2:0 10-bit Rec. 2020 is optimal video output setting for Shield?
code:3840x2160 59.940 Hz
YUV 422 12-bit Rec. 709
Dolby Vision and HDR10 Ready
(2020-01-23, 14:17)Hitcher Wrote: [ -> ]Hmm, now i'm more confused.(2020-01-23, 13:49)Dr.Feelgood Wrote: [ -> ]Hi,
Mine's set to this -
with 'Match content colour space' enabled.
(2020-01-23, 15:13)Dr.Feelgood Wrote: [ -> ]Hi, he did say he has match content colour space enabled so the setting of rec709 is immaterial, it will automatically change to rec2020 as required.(2020-01-23, 14:17)Hitcher Wrote: [ -> ]Hmm, now i'm more confused.(2020-01-23, 13:49)Dr.Feelgood Wrote: [ -> ]Hi,
From what i could read Rec. 709 is not applicable to UHD / HDR which should be Rec. 2002, and 12-bit is not much better than 10-bit. Also, 10-bit is mainstream for UHD and the step between 8-bit to 10-bit is much more significant than 10-bit to 12-bit.
Further YUV is analog and YCbCr is digital which should be more applicable to UHD / HDR.
Any reason why you chose those settings. What is the brand/make of your TV?
I'm using Samsung JU7100 series TV which supports UHD 4K and i',m looking for optimal matching setting output for the 2019 Shield
(2020-01-23, 17:04)Hitcher Wrote: [ -> ]^ What he said.Ok, thanks, i'll try the same.
And I have an LG OLED65B7V.
(2020-01-23, 15:13)Dr.Feelgood Wrote: [ -> ](2020-01-23, 14:17)Hitcher Wrote: [ -> ]Hmm, now i'm more confused.(2020-01-23, 13:49)Dr.Feelgood Wrote: [ -> ]Hi,
(2020-01-26, 07:32)Dave_O Wrote: [ -> ]I am using the current Kodi release to play content from a Synology NAS, and it plays all content, including 4K HEVC without issues on both a 2019 Nvidia TV Tube and Fire TV. Recently, I’ve been using Plex for media library management with the Plex add on. The problem I have is that although Kodi can play the content without Plex, transcoding is triggered. HEVC 4K is transcoded to H264 4K, and Plex is transcoding the audio to AC3 instead of Kodi transcoding it.
The only custom settings is to set audio to 2ch, Passthrough enabled, and AC3 transcoding enabled. The MrMC fork does not have this issue. Is there a setting I’m missing? Perhaps the upcoming version of Plex which allows disabling transcoding will fix this as well.
(2020-01-23, 19:12)Dr.Feelgood Wrote: [ -> ](2020-01-23, 17:04)Hitcher Wrote: [ -> ]^ What he said.Ok, thanks, i'll try the same.
How about whitelist in Kodi? I'm not sure I understand what's best to use with Shield.
My feed is LiveTV DVB-S2 which is 1080p (interlaced I guess) and a lot of 1080p HD material 24p & 60p . Which ones should I whitelist if I want some of that AI upscaling?
(2020-01-26, 16:45)ozkhan1 Wrote: [ -> ]Thanks. Upon further investigation, the files metadata had an issue. I replaced it and all plays as expected.(2020-01-26, 07:32)Dave_O Wrote: [ -> ]I am using the current Kodi release to play content from a Synology NAS, and it plays all content, including 4K HEVC without issues on both a 2019 Nvidia TV Tube and Fire TV. Recently, I’ve been using Plex for media library management with the Plex add on. The problem I have is that although Kodi can play the content without Plex, transcoding is triggered. HEVC 4K is transcoded to H264 4K, and Plex is transcoding the audio to AC3 instead of Kodi transcoding it.
Although that sounds like a Plex issue and not Kodi, look for direct play and enable that. I am sure your settings can be tweaked to get it working correctly.
