2022-12-07, 06:37
2022-12-07, 10:15
2023-01-23, 17:50
I've installed epg and m3u from m3u4u correctly and after start the tv-guide appears on the screen correctly; however there is one problem: when i push on a channel for livestream, the program won't play (no livestream) when i does the same on pvr simple client the tv-guide works correctly and when i push on aa channel then kodi plays the livestream thus the m3u-links seems working perfectly, now my question is what could be the reason that there are no livestreams despite a correct tv-grid ?
2023-02-04, 23:27
I 've changed some settings at EPG and ... my issue is solved Two minor problems : I 've set display channellogos on , but on the screen and at the tv-guide appear no logos (but on pvr simple client they do appear) and how installing recording applications (where do I find the download_record_app ?)
thanks for your help !
2023-02-05, 17:12
@reneverlinden Might be that the channel icons are missing in the EPG. If you have custom channel icons you can add them yourself, please see:
https://github.com/Mariusz89B/script.mtv...ogo_folder
You can download the record app in m-TVGuide settings.
https://github.com/Mariusz89B/script.mtv...record_app
2023-02-09, 18:46
Thanks! I 've solved the problem of record_app and I 'm able to record a stream perfectly. Next days I 'll try to solve the problem about external channel logos.
2023-02-10, 22:55
I tried this addon using my iptv service m3u and xml urls.
It wont load anything outside of polish channels. One group, all polish, no other category or channel.
Is there a setting I am missing? The region category is unchecked and i have deleted the database a few times and restarted, but get the same result.
2023-02-11, 12:02
(2023-02-10, 22:55)caseguy Wrote: [ -> ]I tried this addon using my iptv service m3u and xml urls.
Seems to be some sort of misconfiguration, did you read the setup guide? Check your EPG and the M3U playlist if it's contains other channels than polish and if the channel names matches the channel names provided in the EPG.
https://github.com/Mariusz89B/script.mtv...wiki/Setup
For instance I've configured swedish channels, see screenshot below.
2023-05-06, 08:59
Good day. I am currently using the addon and I really love it. However, I an having these 3 problems:
1 I can’t get catchup to work using the addon. I am on the latest version that you released last month. My iptv service does provide 2-day catchup. I have tried with all the settings in the addon but none works
2 I have also not been able to record with the app. I downloaded the recording application in the settings and also set a valid recording destination but recording never works
3 I have not been able to remove added channels from favorite groups. All I usually get when I try to do so is a empty bar with no channels to remove
Of note, I am using the addon on Kodi 19.5 on Buzz TV box and Kodi 20 on Formuler Z8
Can you kindly address these issues I am having please?
Thanks a lot
Thanks a lot
