(2021-10-01, 22:38)Dimension Wrote: [ -> ] (2021-10-01, 22:33)M89SE Wrote: [ -> ] (2021-10-01, 22:31)Dimension Wrote: [ -> ]Here is a dropbox DL Link: https://www.dropbox.com/s/m86ib6eelu1opuw/kodi.log?dl=0
Ok, I see an error in the log.
EDIT:
Seems to be some sort of SSL Certificate error, there is something on your computer blocking access to download epg and upload log.
I'm not following you on this one. I am downloading the EPG from m34u and I do not get any error messages when the download takes place.
Then something is blocking Kodi.
Dimension It seems to me that something is blocking Kodi to download/upload content, not sure what it can be. Check your Firewall settings in Windows maybe. I will create a debug version for you tomorrow.
(2021-10-01, 23:05)M89SE Wrote: [ -> ]@Dimension It seems to me that something is blocking Kodi to download/upload content, not sure what it can be. Check your Firewall settings in Windows maybe.
I disabled Kaspersky and tried but still was receiving the same message. I wonder why the data is getting blocked for both the EPG and M3U are files and not URL links. Both exist on my system so I'm not sure what Kodi is trying to go outside for.
(2021-10-01, 23:08)Dimension Wrote: [ -> ] (2021-10-01, 23:05)M89SE Wrote: [ -> ]@Dimension It seems to me that something is blocking Kodi to download/upload content, not sure what it can be. Check your Firewall settings in Windows maybe.
Disabled both Kaspersky and Windows Defender which should bypass the firewall and I am still getting the same message.
Here is the latest log file and I am only seeing 1 SSL cetificate error message and that is back at 16:58 which was now about 15 mins ago so the latest message is taking place without any SSL certificate errors in the log file.
Ok, now I see, check your settings if the EPG is set to File and not Url!
I am seeing this message being reported at 17:09:32 in the log: " ERROR <general>: XFILE::CDirectory::GetDirectory - Error getting D:\Applications\Kodi\addons\skin.estuary\fonts\skin.default"
(2021-10-01, 23:13)M89SE Wrote: [ -> ] (2021-10-01, 23:08)Dimension Wrote: [ -> ] (2021-10-01, 23:05)M89SE Wrote: [ -> ]@Dimension It seems to me that something is blocking Kodi to download/upload content, not sure what it can be. Check your Firewall settings in Windows maybe.
It is set to file. Would you like for me to export the settings?
(2021-10-01, 23:14)Dimension Wrote: [ -> ]I am seeing this message being reported at 17:09:32 in the log: " ERROR <general>: XFILE::CDirectory::GetDirectory - Error getting D:\Applications\Kodi\addons\skin.estuary\fonts\skin.default"
This error is not important, is a minor bug.
(2021-10-01, 23:15)Dimension Wrote: [ -> ] (2021-10-01, 23:13)M89SE Wrote: [ -> ] (2021-10-01, 23:08)Dimension Wrote: [ -> ]I disabled Kaspersky and tried but still was receiving the same message. I wonder why the data is getting blocked for both the EPG and M3U are files and not URL links. Both exist on my system so I'm not sure what Kodi is trying to go outside for.
Yes please send it on PM.
Ok, I will run some tests tomorrow, maybe I need to correct something for file reading.
Just to be clear, the epg you provided is in xmltv format?
(2021-10-01, 23:20)M89SE Wrote: [ -> ]Ok, I will run some tests tomorrow, maybe I need to correct something for file reading.
Yes, I am using the xmltv link provided by m34u's website.
Thanks for looking into this.
(2021-10-01, 23:24)Dimension Wrote: [ -> ] (2021-10-01, 23:20)M89SE Wrote: [ -> ]Ok, I will run some tests tomorrow, maybe I need to correct something for file reading.
I suspect the epg is not cooperating with the addon, could you send me this epg or a fragment of it on PM and I will see if I need to add support for it?
The first rows of the EPG should look like this:
xml:
<?xml version="1.0" encoding="UTF-8"?>
<tv generator-info-name="WebGrab+Plus/w MDB & REX Postprocess -- version V2.1.5 -- Jan van Straaten" generator-info-url="http://www.webgrabplus.com">
<channel id="SVT1 SE">
<display-name lang="sv">SVT1 SE</display-name>
<icon src="http://m-tvguide.pl/ikony/SE/22.06.2021/svt1_se.png" />
<url>http://www.tv.nu</url>
</channel>
EDIT:
Are there any strange characters in the epg that might call an utf-8 decode error?
