2009-04-05, 12:42
Get the latest versions from FernFerret's site:
How-to
FAQ
Q1: Why do I still see question marks instead of my movie producers' logo?
A1: There are two possible explanations. Either the pack doesn't include the logo, or there's no info on film studio in the .nfo file for that film.
Q2: How do I add the producer's name to the .nfo file?
A2: The easiest way is to use Media Info Plus. Just install, run, scan your media and voila. Be sure to check the option named "Support Skin Based Flagging" (Settings/General tab).
Q3: Where do I request new labels to be added?
A3: Here. Posting a link to a logo to be used would simplify things a lot.
Q4: Why do I see two logos displayed, one over another?
A4: The MIP solution is kind of simplistic. What it does is to make Aeon display all flags that fit the keywords stored in the .nfo files. If there is more than one production company mentioned in the file, all will be displayed - one over another. To prevent that either edit the relevant .nfo file by hand and leave only one company there, or use MIP for that.
Q5: What if I need only one particular logo?
A5: No problem: just go to this site and look for it there\
Q6: Is there a way to make MediaInfoPlus show the media icons I chose for my films?
A6: Sure, just copy the flag pack to MIP's directory: ..\MediaInfoPlus\customimages\media\flags. That's it!
The names are, top to bottom, short name/full name:
Gutek / Gutek Film
Monolith / Monolith Films
Platige / Platige Image (Oscar nomination for The Cathedral)
Se-Ma-For / Se-Ma-For (two oscars, Perter and the Wolf and Tango)
WFDiF / Wytwórnia Filmów Dokumentalnych i Fabularnych
Zebra / Studio Filmowe Zebra
How-to
- Download the latest version of the pack
- Unzip it to your main directory for each skin (for example "..\XBMC\skin\Aeon\")
- When prompted to overwrite files chose yes. This mod doesn't delete any code, what it does is to add studio logos and some code to make them display properly
FAQ
Gutek / Gutek Film
