Vincent81 Wrote:...
I found that there was a problem with the character "&" delete it if you found in a field.
no '&' char found in my latest log.
Except for the "queryvideodatabase¶meter" every time, but that does not look like a field content or problem to me.
Update "Alvin & the chipmunks" no ?
Or try whith shortless plot.
there is no '&' in that title or plot.
only 'and'.
In the given path there what not one nfo file.
How do I generate those nfo's?
Maybe that tells you more about the problem.
New version 9.5.6.0
-Add : Management of Sets in multiple-edition : You can assign several movies to a Set and edit sort order.
-Add : best trailer management.
-Some bugs fixes.
Hi Vincent,
some other bug I've noticed:
When you reload your complete db via http, it seems that updating is not possible for some reason.
It's needed to restart xbne, after that updating works fine.
Probably this was also the main reason for my first problem mentioned before.
rgds
New version 9.6.0.0
Add :
- Country editor
- Multi downloading Trailers
- Flag "File missing"
- Some bugs fixes.
Just tested and getting this error.
Win7 32bit English selection
Erreur dans le traitement Fin d'initialisation de Table_Video.
La liste est vide.
Aucun indice n'est valide pour le champ Table_Video.
(Indice spécifié : 1).
----- Informations techniques -----
Projet : nfo_xbm
Appel WL :
Traitement de 'Fin d'initialisation de Table_Video' (FenetrePrincipale.Table_Video), ligne 65535, thread 0
Que s'est-il passé ?
La liste est vide.
Code erreur : 10060
Niveau : erreur fatale (EL_FATAL)
Dump de l'erreur du module 'wd150obj.dll' (15.00Lom).
Identifiant des informations détaillées (.err) : 10060
Informations supplémentaires :
EIT_PILEWL :
Fin d'initialisation de Table_Video (FenetrePrincipale.Table_Video), ligne 65535
EIT_DATEHEURE : 15/10/2010 13:26:54
Assistance
Oups, download the 9.6.1.0 version, bug corrected, sorry...
Hello,
When i search for a movie i must type P with shift and not p because just p want play the movie....
And in editing genre i can't change the picture of animation genre.
And columns resizing in app don't remind on next start.
With the last version of XBNE
See You.
OK, I should consider it for future releases. Memory columns resizing works for me?
Vincent81 Wrote:OK, I should consider it for future releases. Memory columns resizing works for me?
Sorry i don't say where... in the listview of fanart and in the listview for vignettes and in the listview for scrappers
See You
The install even starts under Windows 7 (64bits)
New version 9.7.0.0
- Add : DDS image & cache support :
