yes it crashes when the video ends for me too, using xbmc ppa.
(2014-03-15, 06:23)adolchristin Wrote: [ -> ]So I've been debugging a bit more and it appears that with vdpau radeon and arch linux 64 xbmc will crash if I stop playback. If i allow the video to end without stopping there is no crash. Is anyone else seeing this issue? I'm using xbmc-beta from AUR which is built from Gotham Beta1.
you mean this?
https://aur.archlinux.org/packages/xbmc-devel/
if yes, you won't get any support here, as it uses external ffmpeg
(2014-03-15, 10:27)deadite66 Wrote: [ -> ]yes it crashes when the video ends for me too, using xbmc ppa.
something must have gone wrong with mesa or kernel. on my kabini all was fine, then I upgraded to Ubuntu 14.04. When I stop a video it segfaults.
(2014-03-15, 14:26)FernetMenta Wrote: [ -> ] (2014-03-15, 10:27)deadite66 Wrote: [ -> ]yes it crashes when the video ends for me too, using xbmc ppa.
I have the same problem on some videos but not getting a stack trace with GDB. I am using Kernel 3.13.6, wsnipex's mesa repo per this guide, and unstable PPA on 13.10 64bit.
(2014-03-15, 14:26)FernetMenta Wrote: [ -> ]something must have gone wrong with mesa or kernel. on my kabini all was fine, then I upgraded to Ubuntu 14.04. When I stop a video it segfaults.
i'm still on saucy but running 3.14-rc6, wanted to see if 3.14 cured another problem i had with xbmc crashing and being unable to start up roughly every 2 weeks.
what kernel did you have with last working version?
not sure i updated as new 3.13 kernels came out, previously i was using 3.13.4 i think it was also doing the same thing though.
(2014-03-15, 10:59)wsnipex Wrote: [ -> ] (2014-03-15, 06:23)adolchristin Wrote: [ -> ]So I've been debugging a bit more and it appears that with vdpau radeon and arch linux 64 xbmc will crash if I stop playback. If i allow the video to end without stopping there is no crash. Is anyone else seeing this issue? I'm using xbmc-beta from AUR which is built from Gotham Beta1.
you mean this? https://aur.archlinux.org/packages/xbmc-devel/
Actually this:
https://aur.archlinux.org/packages/xbmc-beta/ but that also uses external ffmpeg it looks like. It seems like the problem is also occurring on ubuntu systems as well however.
(2014-03-15, 14:42)pyrodex Wrote: [ -> ] (2014-03-15, 14:26)FernetMenta Wrote: [ -> ] (2014-03-15, 10:27)deadite66 Wrote: [ -> ]yes it crashes when the video ends for me too, using xbmc ppa.
I'm having the same issue, I installed gdb but when xbmc crashes this way it doesn't produce a stack trace. I'm also using 3.13.6.
Linux Adol 3.13.6-1-ARCH #1 SMP PREEMPT Fri Mar 7 22:47:48 CET 2014 x86_64 GNU/Linux
I refound which option to enable in order to have vdpau working on debian sid. But I have a strange bug :
If I enable the vdpau mixer, the video is choppy. The subtitle continues normally but the movie only play 1/2s in loop until the next key-frame and replay only 1/2s in loop. But if I deactivate the vdpau mixer I don't have any issue.
I'm not sure where does the bug come. Missing dependencies ? Bad compilation ? Bad xorg configuratioin ?
If you have an idea and want a specific debug log feel free to ask. But for me, disabling vdpau mixer did the trick.
regressed back to 3.13.1 skipping through dvb-t2 recordings is much faster, something has changed for the worse in 3.14.
We informed ckoenig about it. UVD decoder needs nearly one second to open on 3.14-rc6 ...
Has anyone got a dedicated Southern Islands card to work with HDMI audio? Any tricks? My 7750 only outputs cyclical sounds, quiet voices like wrong channel, and echos. Setup PC to TV directly HDMI (2.0 audio selected). I am working with another member to try to get it to work on a 79xx. Note-Full Xubuntu Desktop + Pulse + this How-to works. I am trying to get alsa-only how-to to work (OP guide 100%). OE-gotham beta does the same.
Here is an OE log: (my how-to install has broken Realtek-drivers.. UG)
http://pastebin.com/3FXkNMDE
In case this helps others: I also noticed this Gotham Beta OE also *crashes stopping the video*, like noted above. Crashes on Kabini (on an AQ01 box)/Southern Islands 7750, but not on A4-3400. Same settings/thumb drive moved around.
I know this is not an OE guide. It is easier to debug with it. Any tips are appreciated.
The last one is known. Same for trusty and vdpau with mesa 10.1
