not sure if it's been mentioned but fanart/thumbs aren't showing up proper with xbmc frodo beta
(2012-11-24, 21:50)gotoman00 Wrote: [ -> ]not sure if it's been mentioned but fanart/thumbs aren't showing up proper with xbmc frodo beta
working fine for me..
Ok, this may sound nuts, but I'd love to have some of this info displayed on my desktop PC (via some kind of web based wallpaper or something). Not sure if anyone's tried that, done it successfully, etc.? (I have a server setup, so it'd run on the WHS2011 server and the displays would be on a Win7 desktop).
I wonder if this can be installed in RT-N16 with tomato firmware, any tried? so far I have lighttpd and mySQL running well, and a centralized database for XBMC in the same router, could maraschino be add it?
thanks for replay
hi
im trying to get the search function to work, but when it displays the search results from nzbmatrix, and i click the sab icon - i get API key invaild.
Any idea where i have to set the SAB API key? cannot find it anywhere!
Cheers
(2012-11-28, 00:12)were55 Wrote: [ -> ]Hi,
thanks for replay
Thats is an interesting idea! Dont know of anyone who has tried it but if you can run python then you most likely will be able to run Maraschino.
(2012-11-28, 00:53)selspiero Wrote: [ -> ]hi
Cheers
This is a known bug that has been introduced with the revamp of the search feature we are looking into a fix.
thanks for replay
Have you tried doing this? I'm running openwrt with extroot on a tp-link router and would like to do the same
thanks for replay
It's technically possible. I had Sickbeard running on 1 of those routers a while back so i see no reason Maraschino wouldn't work.
I think this needs a place in Maraschino somewhere. Not quite sure where, but stumbled on it and was very impressed!
http://www.movieboot.com/
Hello all,
I just installed Maraschino on a Windows 7 computer by following the post "How to Install Maraschino on Windows 7" in the Maraschino forums.
When I run the command: python.exe "C:\webapps\maraschino\maraschino.py" everything looks fine but when I enter localhost:7000 in the browser window all I get is the following page:
Internal Server Error
The server encountered an internal error and was unable to complete your request. Either the server is overloaded or there is an error in the application.
Any help would be appreciated!!
Getting the same issue as ADA2D and was just trying to figure out the cause...
(2012-12-06, 03:33)ADA2D Wrote: [ -> ]Hello all,
Should be fixed now, please update and all should be fine. Sorry for the inconvenience.
(2012-12-06, 06:26)lrusak Wrote: [ -> ]Has Frodo JSON support been added to Maraschino yet?
Edit: Should've just looked for me self, https://github.com/mrkipling/maraschino/pull/249
For the most part everything works. Its mainly music that is lacking full frodo support at the moment. That PR adresses any existing frodo requirements as well as a complete rewrite of how the library module works.
Does anyone go to the trouble of making their server secure apart from passwords?
Should I be running this as https? I'm not to clued up on server security so forgive my simple question, just wondering if it is something I should be worrying about...
Niietzshe
