nashant Wrote:You're thinking about that mention of buffer_size there is? It says write buffer though, so I doubt it.
What happens if you start it up and just leave it?
It does this:
Last login: Wed Nov 30 23:36:09 on ttys000
Macintosh:~ mc$ cd /users/mc/maraschino
Macintosh:maraschino mc$ sudo python maraschino.py
Password:
* Running on http://0.0.0.0:5000/
* Restarting with reloader
127.0.0.1 - - [30/Nov/2011 23:37:54] "GET / HTTP/1.1" 200 -
127.0.0.1 - - [30/Nov/2011 23:37:54] "GET /static/js/lib/less.js HTTP/1.1" 304 -
127.0.0.1 - - [30/Nov/2011 23:37:54] "GET /static/js/lib/jquery.js HTTP/1.1" 304 -
127.0.0.1 - - [30/Nov/2011 23:37:54] "GET /static/js/lib/jquery-ui.custom.min.js HTTP/1.1" 304 -
127.0.0.1 - - [30/Nov/2011 23:37:54] "GET /static/js/popups.js HTTP/1.1" 304 -
127.0.0.1 - - [30/Nov/2011 23:37:54] "GET /static/js/index.js HTTP/1.1" 304 -
127.0.0.1 - - [30/Nov/2011 23:37:54] "GET /static/less/base.less HTTP/1.1" 304 -
127.0.0.1 - - [30/Nov/2011 23:37:54] "GET /static/less/site.less HTTP/1.1" 304 -
127.0.0.1 - - [30/Nov/2011 23:37:54] "GET /static/images/backgrounds/grass.jpg HTTP/1.1" 304 -
127.0.0.1 - - [30/Nov/2011 23:37:54] "GET /static/images/alpha/000_70.png HTTP/1.1" 304 -
127.0.0.1 - - [30/Nov/2011 23:37:54] "GET /static/images/settings_icon.png HTTP/1.1" 304 -
127.0.0.1 - - [30/Nov/2011 23:37:54] "GET /static/images/alpha/000_80.png HTTP/1.1" 304 -
127.0.0.1 - - [30/Nov/2011 23:37:54] "GET /static/images/alpha/fff_10.png HTTP/1.1" 304 -
Then nothing works now.
If I quit terminal and restart it says this:
Last login: Wed Nov 30 23:41:19 on ttys000
Macintosh:maraschino mc$ python maraschino.py
File "maraschino.py", line 73, in <module>
app.run(debug=True, port=PORT, host='0.0.0.0')
File "/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site-packages/Flask-0.8-py2.7.egg/flask/app.py", line 703, in run
run_simple(host, port, self, **options)
File "/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site-packages/Werkzeug-0.8.1-py2.7.egg/werkzeug/serving.py", line 610, in run_simple
test_socket.bind((hostname, port))
File "/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/socket.py", line 224, in meth
return getattr(self._sock,name)(*args)
socket.error: [Errno 48] Address already in use
I have to reboot to start again.
T800 Wrote:If I quit terminal and restart it says this:
It seems you still have something running in that port. Do not quit terminal without finishing the process. Just press control+c on terminal and it should stop whatever it was doing. Otherwise, change the port number on settings.py (I believe that should work).
Regarding your other error : "[Errno 32] Broken pipe" it seems a connection was closed early, prob XBMC's, it shouldnt happen. Give it another go.
Your running CouchPotato @ port 5000 (probably).
At the end of Maraschino.py or in settings.py specify a different port. Best to use 7000.
karandras24 Wrote:Hi All,
Just a quick question for you.
Is it possible to change the page title for maraschino?
I currently have it running on my server but would like to add it to 3 other xbmc htpc's.
It would be nice to have a way to tell them apart other than IP address or host name in the address bar.
Open templates\base.html in text editor and modify line "<title>{% block page_title %}Marashino{% endblock %}</title>" where it says marashino, you can change that to whatever you would like.
N3MIS15 Wrote:Open templates\base.html in text editor and modify line "<title>{% block page_title %}Marashino{% endblock %}</title>" where it says marashino, you can change that to whatever you would like.
Cheers for the reply matey.
Would this not get overwritten (Sp?) everytime an update is pushed?
It's working much better for me know.
I completely re-installed it (only took a few minutes).
For some reason SABNZbd isn't being displayed. Some recently added thumbs aren't showing and I can't play anything from Maraschino.
File "/Users/mc/.maraschino/tools.py", line 29, in decorated
return f(*args, **kwargs)
File "/Users/mc/.maraschino/controls.py", line 13, in xhr_play_episode
xbmc.Playlist.Clear(playlistid=1)
File "build/bdist.macosx-10.6-intel/egg/jsonrpclib/jsonrpc.py", line 276, in __call__
return self.__send(self.__name, kwargs)
File "build/bdist.macosx-10.6-intel/egg/jsonrpclib/jsonrpc.py", line 225, in _request
check_for_errors(response)
File "build/bdist.macosx-10.6-intel/egg/jsonrpclib/jsonrpc.py", line 529, in check_for_errors
raise ProtocolError((code, message))
ProtocolError: (-32601, u'Method not found.')
192.168.0.5 - - [01/Dec/2011 21:06:16] "GET /xhr/currently_playing HTTP/1.1" 200 -
127.0.0.1 - - [01/Dec/2011 21:06:17] "GET /xhr/currently_playing HTTP/1.1" 200 -
192.168.0.5 - - [01/Dec/2011 21:06:21] "GET /xhr/sabnzbd HTTP/1.1" 200 -
192.168.0.5 - - [01/Dec/2011 21:06:21] "GET /xhr/currently_playing HTTP/1.1" 200
Which repo did you clone, and when? That message is saying that it's trying to use an invalid XBMC api function. My repo could have had that in a few pushes ago. All fixed now though.
nashant Wrote:Which repo did you clone, and when? That message is saying that it's trying to use an invalid XBMC api function. My repo could have had that in a few pushes ago. All fixed now though.
I did this:
git clone
https://github.com/mrkipling/maraschino.git /home/yourusername/.maraschino
About 5 hours ago.
EDIT:
Sorry just realized it needs Pre Eden nightly.
karandras, I'll look into an option to set the name.
Yeah, T800. Needs pre-eden. But you may as well upgrade now. It's pretty much perfectly stable. And when you do upgrade, I'd recommend cloning from me, DejaVu or gugahoi. I remember reading that MrKipling doesn't have much time at the mo, so the newer features are in the forks.
MrK is far too busy getting married at the moment.
I'm sure, once his life settles down a bit he'll bury his head into this for a few days.
Considering Maraschino seemed to spring from nowhere, I'm pretty certain the mods in the branches/forks are not going to take him a couple of days to perfect/add.
Lots of different features being added all over the place at the moment and I think all the Mods being worked on should be added together into a Testing Repo for others to try out before MrK's return...
Rather than keep cloning all over the place?
Thought?
DejaVu Wrote:MrK is far too busy getting married at the moment.
Thought?
+1 here
I'd certainly like to test a repo with all the features and mods you guys are working on rolled into one.
Yeah, I think that'd be a cracking idea.
nashant Wrote:karandras, I'll look into an option to set the name.
Thanks very much! It'll make life miles easier for me, it can get a bit confusing when you have 4 maraschino tabs open
nashant Wrote:Yeah, I think that'd be a cracking idea.
another +1 on the cracking idea.
