(2013-02-27, 19:11)Katch Wrote: [ -> ] (2013-02-27, 14:51)Koying Wrote: [ -> ]Quick status:
I'm waiting for an ODROID U2 (should come in 3-4 weeks). Once it is confirmed this one works ok (Exynos4), I suppose we could say the test is conclusive.
I'll then put the patch in shape and submit it to the scrutiny of the Team for inclusion in master.
Mine arrives tomorrow so I'll give it a test and drop some logs if you like.
I have one and 1080 hw decoding is working as bad as on my Note 2.
Hi Koying,
Thanks for your help. Just want to know of any progress has been made on the rk30xx. Or we still need help on the rockchip side?
Doing some tests with with 2013.02.19 build - with libstagefright that herman chen posted on my rk3066 device after full firmware reset.
Stability increased greatly where some 1080p files crashed the device completly before.
It seems that software fallback is too strict a bit.
As 2 samples that were perfectly fine before (before libstagefright update) now, have heavy framedrops - those samples are reported as dc:ff-h264, where everything fluid is reported as stf-h264 - so as i understand libstagefright is not being used for decoding those - and yes the files are not mod16 - but like i stated they never crashed vpu.
Otherwise great job and thank you for everything koying, it looks like its pretty close to be working very well.
I have also notified some rom makes about updated libstagrefright so i hope we may see some adoption before rockchip rolls out updated roms.
I am following this thread for about two weeks. It sounds very interesting, but I am not familiar with programming. Perhaps someone may help me:
Is there a way to get the modified libstagefright.so on my rk3066 - Device without root?
If yes - would someone be so kindly to explain, what we have to do?
Thanks for your patience with guys like me...
Wrong forum... Go to your hardware forum... I.e.minix forums...
Ask.your question there.. but u need to be root anyways..
Log URL:
http://xbmclogs.com/show.php?id=1514
Hardware: Samsung Galaxy Tab 2 10.1, SG-P5113.
Android: 4.2.2 via Cyanogenmod 10.1 Nightly from Feb 18
Video: 2305 kb/s bitrate, H264 MPEG-4 AVC (part 10) (avc1), 1920x864, Frame rate 23.976023, AAC mp4a.
Issue: Slight intermittent stuttering on playback of a video file. The stuttering seemed to worsen with audio peaks, and also on subtitle appearance.
Hi Guys,
I have tested this build with
DroidTV X1 set top box device(RK3066 Dual Core CPU with Android 4.1 Jelly Bean, Quad Core Mali400)
I can confirm that 720 videos works perfect!
Both from SD card and SMB share.
But 1080p is very choppy, although it looks better when I run it from SD or even better from internal flash.
19/02/2013 build works perfectly on my ODROID-U2 with todays Cyanogenmod Nighly with 1080p H.264 DTS 5.1 MKV. I will swich all my playback from Raspberry Pi to the ODROID now and will report problems should there be any.
I am using ODROID-U2 without fan only with the standard heat sink at 1800 Mhz max with ONDEMAND CPU govenour. It gets only slightly warm - so playback works without problem for hours now.
Great work!
Hi!
http://xbmclogs.com/show.php?id=1714
Hardware: HDMI Dongle with Cortex A9 RK3066 1gb RAM, 4gb Flash
Android 4.1.1.
Video: Format: MPEG-4 Visual; Codec ID: XVID;Bit rate: 2 092 Kbps;Width:720 pixels;Height:304 pixels;Frame rate: 23.976 fps
Can't see video, only horizontal stripes
So the issues im having with my Rikomagic MKIIIS are as follows:
All of my media on my main desktop computer so that means i am pulling all of the media files over WiFi. The device itself claims to have a 135 megabit connection with my router, so bandwidth should not be an issue. I should mention that the media is on a computer that is on a gigabit connection so bandwith isnt then issue there.
When i play a movie it is quite slow to play and often times skips.
Also, pulling up Movies or TV Shows can take up to 1 min. to display..
I should also mention that my media libs are also located on the same computer with all the media, and is running from a MySQL database,
ive installed and tried the latest builds as of today (today is 3/1/2013) and none of them seem to fix these issues. if you would like me to generate and make some kind of log i can, just let me know what you need that will help you help me!
(2013-03-03, 01:18)imported Wrote: [ -> ]So the issues im having with my Rikomagic MKIIIS are as follows:
ive installed and tried the latest builds as of today (today is 3/1/2013) and none of them seem to fix these issues. if you would like me to generate and make some kind of log i can, just let me know what you need that will help you help me! :)
:cool:
Somebody didn't read the first post :)
Few logs for this hardware:
Video from here:
http://thepiratebay.se/torrent/5155837/H...les_(v1.7)
Video 1.
http://xbmclogs.com/show.php?id=1921
Picture is damage with slow FPS
General
Complete name : N:\03.split.5.ts
Format : MPEG-TS
File size : 192 MiB
Duration : 45s 657ms
Overall bit rate mode : Variable
Overall bit rate : 35.2 Mbps
Maximum Overall bit rate : 35.5 Mbps
Video
Menu ID : 1 (0x1)
Format : VC-1
Format profile : Advanced@L3
Codec ID : 234
Duration : 44s 912ms
Bit rate : 31.4 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.505
Stream size : 168 MiB (88%)
Audio
Menu ID : 1 (0x1)
Format : DTS
Format/Info : Digital Theater Systems
Format profile : HRA / Core
Mode : 16
Format settings, Endianness : Big
Muxing mode : Stream extension
Codec ID : 134
Duration : 45s 717ms
Bit rate mode : Constant
Bit rate : 2 046 Kbps / 1 509 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Delay relative to video : -57ms
Stream size : 11.2 MiB (6%)
Text
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Video 2
http://xbmclogs.com/show.php?id=1889
Slow FPS. Lines on picture
General
Complete name : N:\00019.m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 116 MiB
Duration : 20s 520ms
Overall bit rate : 47.1 Mbps
Maximum Overall bit rate : 48.0 Mbps
Video
Menu ID : 1 (0x1)
Format : MPEG Video
Format version : Version 2
Format profile : Main@High
Format settings, BVOP : Yes
Format settings, Matrix : Default
Format settings, GOP : M=3, N=15
Codec ID : 2
Duration : 20s 721ms
Bit rate : 40.6 Mbps
Maximum bit rate : 40.0 Mbps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.653
Stream size : 100 MiB (87%)
Audio #1
Menu ID : 1 (0x1)
Format : PCM
Format settings, Sign : Signed
Muxing mode : Blu-ray
Codec ID : 128
Duration : 20s 720ms
Bit rate : 2 304 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Bit depth : 24 bits
Stream size : 5.69 MiB (5%)
Audio #2
Menu ID : 1 (0x1)
Format : PCM
Codec ID : 128
Bit depth : 24 bits
Video 3
Work fine
General
Unique ID : 204319814633281670082764629978273508137 (0x99B6909ED1B6FFDB93F78CCF25636B29)
Complete name : N:\720p16rf-001.mkv
Format : Matroska
File size : 10.5 MiB
Duration : 44s 95ms
Overall bit rate : 1 990 Kbps
Encoded date : UTC 2009-05-14 19:20:11
Writing application : mkvmerge v2.7.0 ('Do It Again') built on Apr 15 2009 00:27:10
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Attachment : Yes / Yes
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 16 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 44s 86ms
Nominal bit rate : 2 000 Kbps
Width : 1 280 pixels
Height : 720 pixels
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.091
Writing library : x264 core 65 r1029M cb3c213
Encoding settings : cabac=1 / ref=16 / deblock=1:-2:-2 / analyse=0x3:0x113 / me=umh / subme=9 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=16 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / keyint=140 / keyint_min=1 / scenecut=40(pre) / rc=2pass / bitrate=2000 / ratetol=1.0 / qcomp=0.80 / qpmin=15 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=0
Default : Yes
Forced : No
Audio #1
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Codec ID : A_MPEG/L3
Codec ID/Hint : MP3
Duration : 44s 95ms
Bit rate : 192 Kbps
Sampling rate : 44.1 KHz
Stream size : 1.01 MiB (10%)
Title : Russian NARUTOfilm
Language : Russian
Default : Yes
Forced : No
Audio #2
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : A_AAC
Duration : 44s 95ms
Title : Original
Language : Japanese
Default : No
Forced : No
Video 4
http://xbmclogs.com/show.php?id=1891
Good picture quality. Slow FPS (10fps)
General
Complete name : N:\Avalon.split.34.m2ts
Format : BDAV
File size : 235 MiB
Duration : 52s 480ms
Overall bit rate : 37.4 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format settings, ReFrames : 4 frames
Codec ID : 27
Duration : 52s 552ms
Bit rate mode : Variable
Bit rate : 35.3 Mbps
Maximum bit rate : 38.0 Mbps
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.710
Stream size : 221 MiB (94%)
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : 131
Duration : 52s 640ms
Bit rate : 640 Kbps
Bit depth : 16 bits
Delay relative to video : -98ms
Stream size : 4.02 MiB (2%)
Video 5
Work fine
General
Unique ID : 54816606533737725274285983388998414758 (0x293D4B5D9F1F787F812C96B83611B1A6)
Complete name : N:\Casino.21.mkv
Format : Matroska
File size : 54.1 MiB
Duration : 30s 280ms
Overall bit rate : 15.0 Mbps
Movie name : Avidemux
Writing application : Lavf51.12.1
Writing library : Lavf51.12.1
Video
Format : AVC
Bit rate : 14.2 Mbps
Height : 800 pixels
Display aspect ratio : 2.40:1
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.386
Stream size : 51.4 MiB (95%)
Writing library : x264 core 60 r899M f8428ed
Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=5 / brdo=0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=2 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / bime=0 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=cqp / qp=23 / ip_ratio=1,40 / pb_ratio=1,30 / aq=0
Default : Yes
Forced : No
Audio
Format : AC-3
Codec ID : A_AC3
Bit rate : 448 Kbps
Bit depth : 16 bits
Delay relative to video : -41ms
Stream size : 1.62 MiB (3%)
Default : Yes
Forced : No
Video 6
Work fine
General
Unique ID : 86247517243603099298346027128625483255 (0x40E2AAE869E56DBE74816420B9A6CDF7)
Complete name : N:\Casino.32.mkv
Format : Matroska
File size : 74.0 MiB
Overall bit rate : 20.5 Mbps
Video
Format : AVC
Bit rate : 19.6 Mbps
Height : 800 pixels
Frame rate mode : Variable
Original frame rate : 23.976 fps
Color space : YUV
Bit depth : 8 bits
Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=5 / brdo=0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=2 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / bime=0 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=cqp / qp=20 / ip_ratio=1,40 / pb_ratio=1,30 / aq=0
Default : Yes
Forced : No
Audio
Format : AC-3
Codec ID : A_AC3
Bit rate : 448 Kbps
Bit depth : 16 bits
Stream size : 1.62 MiB (2%)
Default : Yes
Forced : No
Video 7
Work fine
General
Unique ID : 235243925475334618587494201527763503611 (0xB0FA54FFF8B214F38C1D93E9D45889FB)
Complete name : N:\Casino.42.mkv
Format : Matroska
File size : 109 MiB
Duration : 30s 241ms
Overall bit rate : 30.3 Mbps
Encoded date : UTC 2009-07-08 20:42:11
Writing application : mkvmerge v2.3.0 ('Freak U') built on Sep 8 2008 18:32:16
Video
Format : AVC
Format settings, ReFrames : 2 frames
Duration : 30s 239ms
Bit rate : 29.3 Mbps
Nominal bit rate : 39.0 Mbps
Height : 800 pixels
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.795
Stream size : 106 MiB (97%)
Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=5 / brdo=0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=2 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / bime=0 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=abr / bitrate=39000 / ratetol=1,0 / rceq='blurCplx^(1-qComp)' / qcomp=1,00 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1,40 / pb_ratio=1,30 / aq=2:1,00
Default : Yes
Forced : No
Audio
Format : AC-3
Codec ID : A_AC3
Bit rate : 448 Kbps
Bit depth : 16 bits
Delay relative to video : 1ms
Stream size : 1.62 MiB (1%)
Title : Rus - AC3 448Kbps
Language : Russian
Default : Yes
Forced : No
Video 8
Slow FPS (18-24fps)
http://xbmclogs.com/show.php?id=1894
General
Complete name : N:\Casino.50.m2ts
Format : BDAV
File size : 143 MiB
Duration : 30s 154ms
Overall bit rate : 39.7 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Codec ID : 27
Bit rate : 37.7 Mbps
Height : 800 pixels
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 1.024
Stream size : 136 MiB (95%)
Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=5 / brdo=0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=2 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / bime=0 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=cqp / qp=13 / ip_ratio=1,40 / pb_ratio=1,30 / aq=0
Audio
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Duration : 30s 208ms
Bit rate : 448 Kbps
Bit depth : 16 bits
Stream size : 1.61 MiB (1%)
Video 9
http://xbmclogs.com/show.php?id=1896
Low FPS (18-24fps)
General
Unique ID : 7889764161085931452029369052477881220 (0x5EF8367F831FC3C1EE51A40EDC57B84)
Complete name : N:\Casino.50.mkv
Format : Matroska
File size : 137 MiB
Overall bit rate : 37.9 Mbps
Video
Format : AVC
Bit rate : 36.7 Mbps
Height : 800 pixels
Color space : YUV
Bit depth : 8 bits
Default : Yes
Forced : No
Audio
Format : AC-3
Codec ID : A_AC3
Bit rate : 448 Kbps
Bit depth : 16 bits
Default : Yes
Forced : No
Video 10
Work good
General
Unique ID : 230974184978964122130642553199829495258 (0xADC4028A52B3DDBBA20E468CC628ADDA)
Complete name : N:\Casino.Royale.BDrip.1080p.SPLIT-004.mkv
Format : Matroska
File size : 92.4 MiB
Duration : 30s 251ms
Overall bit rate : 25.6 Mbps
Encoded date : UTC 2008-11-22 15:00:15
Writing application : mkvmerge v2.4.0 ('Fumbling Towards Ecstasy') built on Oct 11 2008 20:13:15
Video
Format : AVC
Format settings, ReFrames : 5 frames
Duration : 30s 256ms
Height : 800 pixels
Frame rate : 23.962 fps
Color space : YUV
Bit depth : 8 bits
Default : Yes
Forced : No
Audio #1
Format : AC-3
Codec ID : A_AC3
Bit rate : 448 Kbps
Bit depth : 16 bits
Language : Russian
Default : Yes
Forced : No
Audio #2
Format : FLAC
Format/Info : Free Lossless Audio Codec
Codec ID : A_FLAC
Bit depth : 16 bits
Delay relative to video : 44ms
Title : Eng - FLAC 1515Mbps
Writing library : libFLAC 1.2.0 (UTC 2007-07-15)
Language : English
Default : No
Forced : No
Video 11
http://xbmclogs.com/show.php?id=1901
Low FPS(10fps)
General
Complete name : N:\Deinterlace.m2ts
Format : BDAV
File size : 7.30 MiB
Duration : 4s 589ms
Overall bit rate : 13.3 Mbps
Maximum Overall bit rate : 18.0 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format settings, GOP : M=3, N=12
Codec ID : 27
Duration : 4s 720ms
Bit rate : 12.4 Mbps
Maximum bit rate : 16.8 Mbps
Width : 1 440 pixels
Frame rate : 25.000 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.319
Stream size : 6.98 MiB (96%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Duration : 4s 736ms
Bit rate : 384 Kbps
Bit depth : 16 bits
Delay relative to video : -16ms
Stream size : 222 KiB (3%)
Video 12
Low FPS (10fps)
http://xbmclogs.com/show.php?id=1905
General
Complete name : N:\H264_TrueHD.m2ts
Format : BDAV
File size : 37.1 MiB
Duration : 8s 64ms
Overall bit rate : 37.5 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Codec ID : 27
Duration : 8s 258ms
Bit rate : 35.6 Mbps
Maximum bit rate : 34.0 Mbps
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.716
Stream size : 35.1 MiB (94%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 131
Duration : 8s 192ms
Bit rate : 384 Kbps
Bit depth : 16 bits
Delay relative to video : -29ms
Stream size : 384 KiB (1%)
Video 13
Low FPS (8-10)
http://xbmclogs.com/show.php?id=1906
General
Unique ID : 252669262603146818545696960851879550900 (0xBE1654737F90CB15AAF43A883FC65FB4)
Complete name : N:\hns-fc-new-002.mkv
Format : Matroska
File size : 7.48 MiB
Duration : 11s 234ms
Overall bit rate : 5 586 Kbps
Movie name : -=HANSMER=-
Encoded date : UTC 2008-02-16 23:12:52
Writing application : mkvmerge v2.1.0 ('Another Place To Fall') built on Aug 19 2007 13:40:07
Video
Format : AVC
Duration : 11s 220ms
Bit rate : 5 027 Kbps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.101
Stream size : 6.72 MiB (90%)
Title : Fight.Club.1080p.HDTV.x264
Language : English
Default : Yes
Forced : No
Audio
Format : AC-3
Codec ID : A_AC3
Bit rate : 448 Kbps
Bit depth : 16 bits
Delay relative to video : 2ms
Stream size : 614 KiB (8%)
Title : AC3, 6ch 448 kbps
Language : English
Default : Yes
Forced : No
Video 14
http://xbmclogs.com/show.php?id=1907
Low FPS (10-14fps)
General
Unique ID : 251536001131757557771204856671400384866 (0xBD3C1258C68A4774BF133C0739FC5962)
Complete name : N:\Satoyama.II.Japan.Secret.Water.Garden.1080p.rus.-002.mkv
Format : Matroska
File size : 26.8 MiB
Duration : 16s 853ms
Encoded date : UTC 2008-11-03 17:21:28
Video
Format : AVC
Duration : 16s 850ms
Bit rate : 12.6 Mbps
Height : 1 072 pixels
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.205
Stream size : 25.4 MiB (95%)
Title : SATOYAMA 1080P HDBRiSe
Language : English
Default : Yes
Forced : No
Audio
Format : AC-3
Codec ID : A_AC3
Bit rate : 448 Kbps
Bit depth : 16 bits
Delay relative to video : 21ms
Stream size : 922 KiB (3%)
Title : DD 2.0 448 Kbps
Language : Russian
Default : Yes
Forced : No
@chen
anything important that changed in the RK3 v 2.0 sdk for libstagefright ?
did you integrate the patch in the next release (it doesn't seem to made it into the 2.0 SDK yet)
btw the newer libstagefrights are more stable they don't crash the Kernel so fast only the old ones in the 15xx range did
v 1650/1739 shows artifcating but doesn't crashed once yet
you do great work despite the fact that it reaches most user in the RK Ecosystem to late or never @ all
even the yoon yoon sample works now, (of course its a slideshow due to the render path, and 60 fps seems a little to heavy for the RK3066 VPU overall (i get on the fast path around 28-30 fps), probably RK3188 will have no issues with this test sample especialy on the fast direct framebuffer path)
though the birds sample is still not loading right
v 1650/1739
v 1689 (chens fix, seems not yet to have reached clients)
@ Koying
how does the Tegra 3 (Nexus 7) survives here with the yoon yoon sample ?
