2014-08-27, 20:48
Quote:thanx.
the next version of the screensaver will support .nef files.
That's great thanks. The Nikon cameras can save in either .RAW or .NEF I believe they are the same format.
Cheers
Spart
(2014-08-27, 20:41)ronie Wrote: [ -> ]disk is offline, for instance, I get a slideshow of my media (or is it just of my movies, don't know).
does it make a difference if you set the samba timeout to, let's say, 20 seconds?
http://wiki.xbmc.org/index.php?title=Adv...3Csamba.3E
<?xml version="1.0" encoding="UTF-8"?>
<window>
<zorder>5</zorder>
<controls>
<control type="group">
<animation type="Conditional" condition="StringCompare(Window.Property(SlideView.Splash),hide)">
<effect type="fade" start="0" end="100" time="500"/>
</animation>
<animation type="Conditional" condition="StringCompare(Window.Property(SlideView.Fade1),1)">
<effect type="fade" start="100" end="0" time="1000"/>
</animation>
<control type="largeimage" id="1">
<posx>0</posx>
<posy>0</posy>
<width>1920</width>
<height>1080</height>
<aspectratio>keep</aspectratio>
<fadetime>0</fadetime>
<colordiffuse>$INFO[Window.Property(SlideView.Dim)]</colordiffuse>
<animation type="Conditional" condition="StringCompare(Window.Property(SlideView.Slide1),0)" reversible="false">
<effect type="slide" tween="cubic" easing="inout" start="1920,0" end="0,0" time="500"/>
</animation>
<animation type="Conditional" condition="StringCompare(Window.Property(SlideView.Slide1),1)" reversible="false">
<effect type="slide" tween="cubic" easing="inout" start="0,0" end="-1920,0" time="500"/>
</animation>
</control>
</control>
<animation type="Conditional" condition="StringCompare(Window.Property(SlideView.Fade2),1)">
</animation>
<control type="largeimage" id="2">
<posx>0</posx>
<posy>0</posy>
<width>1920</width>
<animation type="Conditional" condition="StringCompare(Window.Property(SlideView.Slide2),0)" reversible="false">
</animation>
<animation type="Conditional" condition="StringCompare(Window.Property(SlideView.Slide2),1)" reversible="false">
</animation>
</control>
</control>
</animation>
<control type="largeimage" id="3">
<posx>0</posx>
<posy>0</posy>
<width>1920</width>
<aspectratio>scale</aspectratio>
</animation>
</animation>
</control>
</control>
</animation>
<control type="largeimage" id="4">
<posx>0</posx>
<posy>0</posy>
<width>1920</width>
</animation>
</animation>
</control>
</control>
<control type="grouplist">
<posx>1000</posx>
<posy>920</posy>
<itemgap>0</itemgap>
<orientation>vertical</orientation>
<control type="textbox" id="101">
<width>900</width>
<height>70</height>
<align>right</align>
<aligny>top</aligny>
<font>Font-Sublabel</font>
<textcolor>SubLabel2</textcolor>
</control>
<control type="label" id="99">
<width>900</width>
<height>35</height>
</control>
<control type="label" id="100">
<width>900</width>
<height>35</height>
</control>
</control>
<posx>20</posx>
<posy>920</posy>
<animation effect="fade" start="80" end="80" time="0" condition="true">Conditional</animation>
<visible>Player.HasAudio + StringCompare(Window.Property(SlideView.Music),show)</visible>
<control type="image">
<posx>0</posx>
<posy>0</posy>
<width>140</width>
<height>140</height>
<texture fallback="DefaultAlbumCover.png">$INFO[MusicPlayer.Cover]</texture>
</control>
<posx>160</posx>
<posy>0</posy>
<control type="label">
<width>900</width>
<align>left</align>
<height>35</height>
<label>$INFO[MusicPlayer.Title]</label>
<textcolor>MainLabel2</textcolor>
</control>
<width>900</width>
<align>left</align>
<textcolor>Highlight</textcolor>
<height>35</height>
<label>$INFO[MusicPlayer.Artist]</label>
</control>
<width>900</width>
<align>left</align>
<height>35</height>
<label>$INFO[MusicPlayer.Album]</label>
</control>
<width>900</width>
<height>35</height>
<align>left</align>
<label>$INFO[Player.Time(hh:mm:ss)]$INFO[Player.Duration(hh:mm:ss), / ,]</label>
</control>
</control>
</control>
</control>
<posx>409</posx>
<posy>129</posy>
<width>461</width>
<height>461</height>
<texture>splash.png</texture>
<animation effect="rotate" end="-360" center="auto" time="7000" loop="true" reversible="false" condition="True">Conditional</animation>
<animation type="WindowOpen">
<effect type="fade" start="0" end="100" time="1000" delay="500"/>
</animation>
<effect type="fade" start="100" end="0" time="500"/>
</animation>
</control>
</controls>
</window>
(2014-09-05, 16:32)eisbaer128 Wrote: [ -> ]I'm trying to skin the screensaver for my favorite skin (Eminence). It's my very first trial and I was able to adapt the positions, fonts..., but I'm not able to adapt the italic and bold style for the EXIF data as they are coded inside the script. Wouldn't it make sense to put this into the skin instead ? In addition the tags have some animation which I really coudn't figure out where this is coded ?
Any help appriciated
(2014-09-08, 17:40)richardb70 Wrote: [ -> ]Hi,
Strange issue yesterday with my folks' Pi. I've installed OpenElec (latest stable version), all is well and I've got a working SMB link to their Windows 7 PC housing their photos. I can browse this link via the "Pictures" main menu, works a treat. Pi is wired to the router, the PC is wifi.
I installed the screensaver and pointed it to the same source. The only other thing I did was to disable the cache in the settings menu.
Whenever the screensaver kicks in, there is the large spinning circle which goes on forever. If you interrupt with a key, the spinning circle remains in the background, and eventually XBMC restarts.
Any suggestions?
(2014-09-11, 17:01)Dark Hunter Wrote: [ -> ]Hello. I am using this plugin for a while and I've got problem to do one thing :
I need to play both images and videos on TV screen in a shop and this plugin works perfectly for images, but now I need to mix videos with images. And it doesn't work. I searched the forum but didnt find a solution, could you help me? Is this even possible with this plugin or I need different solution?
I use remote folder to store files.
Any suggestions?
