2023-11-14, 22:14
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77
2023-12-28, 00:18
Almost one year and no solution offered. I have confirmed all versions of Kodi 19.X have this bug and 20.x as well. I even tested Kodi 21.0 "Omega" Beta 2 which does the same.
Do I need to report this bug somewhere else?
Larry
Larry
2023-12-28, 00:35
(2023-12-28, 00:18)n326595 Wrote: [ -> ]Almost one year and no solution offeredYou need to clarify what solution you need. It can't be what I reported as that was only last month, so which problem is it?
2023-12-28, 01:03
I tried to reply to a post I made #1,056 on 2022-03-12, 18:42. I apologize for the confusion.
https://forum.kodi.tv/showthread.php?tid...pid3090570
2023-12-28, 01:46
From what I can tell the label on the left is made up of the Title and Subject.
2024-01-15, 23:01
love the addon. can it be made to pause a slideshow? don;t post much here (thats how little trouble I have with kodi on 2 nvidia units over last 2.5 years) so unsure the protocol about asking for feature request stuff.
2024-01-16, 00:20
nope, such a thing is not possible. as soon as you press any key, kodi will exit the screensaver... just like you'd expect from a screensaver.
2024-03-24, 12:04
Found some issues with this add-on
Logs can be found here
kodi.log
kodi.old.log
there are 3 issues
1. the log is flooded by this error generated by this add-on
2. apparently the add-on has problems with supporting .arw and .heic format images - or at least some of them
3. I have found a problem with displaying a jpg image which was shot in fisheye mode
DoWork - Direct texture file loading failed for nfs://192.168.184.240/volume1/photo/byYear/2018/10/20181015_173905.jpg
the image has 20181015_173905.jpg 31.6 MP 8192 x 3856 20.5 MB
and this is the exif info data
kodi.log
kodi.old.log
there are 3 issues
Quote:T:1693 error <general>: WARNING: problems with charset recognition (b'\x1b')- it seems that it is popping up at almost all images
Quote:ExifTool Version Number : 11.18
File Name : 20181015_173905.jpg
Directory : /volume1/photo/byYear/2018/10
File Size : 20 MB
File Modification Date/Time : 2024:01:22 11:03:23+01:00
File Access Date/Time : 2024:03:23 23:55:26+01:00
File Inode Change Date/Time : 2024:01:22 11:03:23+01:00
File Permissions : rwxrwxrwx
File Type : JPEG
File Type Extension : jpg
MIME Type : image/jpeg
JFIF Version : 1.01
Resolution Unit : cm
X Resolution : 59
Y Resolution : 59
Exif Byte Order : Little-endian (Intel, II)
Image Width : 0
Image Height : 0
Make : samsung
Camera Model Name : SM-N950F
Orientation : Horizontal (normal)
X Resolution : 72
Y Resolution : 72
Resolution Unit : inches
Software : N950FXXU5CRHA
Modify Date : 2018:10:15 17:39:05
Y Cb Cr Positioning : Centered
F Number : 1.7
Exposure Program : Program AE
Exif Version : 0220
Date/Time Original : 2018:10:15 17:39:05
Create Date : 2018:10:15 17:39:05
Max Aperture Value : 1.7
Metering Mode : Average
Flash : Off, Did not fire
Focal Length : 4.3 mm
Color Space : sRGB
Exif Image Width : 0
Exif Image Height : 0
Exposure Mode : Auto
White Balance : Auto
Focal Length In 35mm Format : 26 mm
Scene Capture Type : Landscape
Image Unique ID : G
GPS Latitude Ref : North
GPS Latitude : 39 deg 13' 24.00"
GPS Longitude Ref : East
GPS Longitude : 9 deg 7' 4.00"
Image Width : 496
Image Height : 280
XMP Toolkit : XMP Core 4.4.0-Exiv2
Subject : Cagliari, Italy
Current IPTC Digest : d88926d2d4e69ad6005abd5a11806418
Coded Character Set : UTF8
Keywords : Cagliari, Italy
Image Width : 8192
Image Height : 3856
Encoding Process : Baseline DCT, Huffman coding
Bits Per Sample : 8
Color Components : 3
Y Cb Cr Sub Sampling : YCbCr4:2:0 (2 2)
Surround Shot Video Name : Motion_Panorama_MP4_000
Surround Shot Video : (Binary data 9339656 bytes, use -b option to extract)
Time Stamp : 2018:10:15 17:39:05+02:00
Aperture : 1.7
GPS Latitude : 39 deg 13' 24.00" N
GPS Longitude : 9 deg 7' 4.00" E
GPS Position : 39 deg 13' 24.00" N, 9 deg 7' 4.00" E
Image Size : 8192x3856
Megapixels : 31.6
Scale Factor To 35 mm Equivalent: 6.0
Circle Of Confusion : 0.005 mm
Field Of View : 69.4 deg
Focal Length : 4.3 mm (35 mm equivalent: 26.0 mm)
Hyperfocal Distance : 2.19 m
2024-04-05, 19:52
@larieu
thanx for reporting your issues.
#1 the errors in your log come from a third party python addon.
i've created a pull request for that addon to get rid of those messages
https://github.com/xbmc/repo-scripts/pull/2600
as for #2 and #3, this screensaver addon is not responsible for actually displaying your images, that's Kodi's job.
all this addon basically does, is create a 'playlist' of your image files and hand over that list to Kodi.
all further image processing is outside of the hands of this addon.
2024-04-06, 10:03
@ronie
thanks for 1.
For 2&3 I'll try to see if manually I can go to those picture and see them in Kodi and pick it up from there to report it or add the appropriate patches to my install.
thanks for 1.
