Hi.
Please help, I currently get the following error.
14:28:51 T:4032 NOTICE: -->Python Interpreter Initialized<--
14:28:51 T:4032 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.NameError'>
Error Contents: name 'sys' is not defined
File "C:\Users\XBMC\AppData\Roaming\XBMC\addons\screensaver.xbmc.slideshow\default.py", line 38, in <module>
import gui
File "C:\Users\XBMC\AppData\Roaming\XBMC\addons\screensaver.xbmc.slideshow\resources\lib\gui.py", line 22, in <module>
if sys.version_info < (2, 7):
NameError: name 'sys' is not defined
I've just switched back from v13 gotham alpha 4 to the latest v12.2 frodo release.
Cray
(2013-06-21, 15:32)Cray242 Wrote: [ -> ]Hi.
import gui
Cray
looks like a bad xbmc install.
if reinstalling xbmc doesn't fix it, please provide a full
Debug Log
Hi ronie.
Thanks for your response. I did a clean install now and it worked until I installed the 500PX add-on. I removed the add-on and the slideshow is working again.
THX
Cray242
(2013-06-21, 22:20)Cray242 Wrote: [ -> ]Hi ronie.
THX
Cray242
thanx for the report!
i was able to reproduce it and will check what the heck is going on.
Hello guys,
i'm having the same problem as Cray242 described but i didn't even upgrade to xbmc 13. I did a upgrade from 12.0 to 12.2 a few days ago and today i recoginzed the screensaver isn't working anymore.
My debug log can be found here
http://xbmclogs.com/show.php?id=30396
23:05:49 T:140230774466304 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
File "/home/eh/.xbmc/addons/screensaver.xbmc.slideshow/default.py", line 38, in <module>
import gui
File "/home/eh/.xbmc/addons/screensaver.xbmc.slideshow/resources/lib/gui.py", line 22, in <module>
23:05:49 T:140232057456512 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
23:05:49 T:140230774466304 INFO: Python script stopped
23:05:49 T:140230774466304 DEBUG: Thread XBPyThread 140230774466304 terminating
I'm running xbmc on a standalone htpc running ubuntu VERSION="13.04, Raring Ringtail" and installed xbmc via the xbmc stable repo:
#XBMC - stable
deb http://ppa.launchpad.net/team-xbmc/ppa/ubuntu raring main
deb-src http://ppa.launchpad.net/team-xbmc/ppa/ubuntu raring main
All other xbmc functionality is working fine
Thanks in advance and best regards,
Erik
(2013-06-21, 23:16)l0bster Wrote: [ -> ]i'm having the same problem as Cray242 described but i didn't even upgrade to xbmc 13. I did a upgrade from 12.0 to 12.2 a few days ago and today i recoginzed the screensaver isn't working anymore.
the 500PX picture addon (which you have installed as well) is causing issues.
i've just sent the author an email, so hopefully we can resolve this issue soon.
Oh... well
Great! Thanks for your fast reply! I love your screensaver, continue with this great job
an update for the 500px plugin is on it's way.
once you receive this update, the screensaver issue should be solved.
Great add-on!
I have tried searching the forum on this issue but have not had any luck, please forgive me if I have missed something. Screensaver does not seem to be able to stream pictures from a upnp server. It allows me to add the upnp folder OK but when the screensaver runs it just shows the waiting circle of dots.
The same upnp folder works OK when running slideshow from the pictures menu.
Is it something I'm doing wrong or a limitation of the add-on? Thanks.
Nope.. Xbmc doesn't support pictures over upnp. I don't think current gsoc involves picture / slideshow support over upnp.
Is there a way to limit what video fan art is displayed? I have a lot of movies rated from G, PG, PG-13,R, etc. some of the video fan art is scary for little kids. An option to only display rated G, PG would be great. If that is possible could a time limit be set so the limiting could only be from like 7am to 7pm?
(2013-07-15, 03:53)carl1jenn Wrote: [ -> ]Is there a way to limit what video fan art is displayed? I have a lot of movies rated from G, PG, PG-13,R, etc. some of the video fan art is scary for little kids. An option to only display rated G, PG would be great. If that is possible could a time limit be set so the limiting could only be from like 7am to 7pm?
negative, there's no such feature in the addon.
The closest you can get would be to create a "custom folder of images".
can the custom folder be on an smb share?
(2013-07-16, 04:50)carl1jenn Wrote: [ -> ]can the custom folder be on an smb share?
Yup
