Full Version: TvTunes Addon - Retrieve & Play Soundtracks Whilst Browsing Your Library
Hi All,
First drop of the tvtunes.nfo file support. This will enable users to specify themes in other locations (or with non theme.mp3 names) the file has to be called tvtunes.nfo (no other name will be picked up). The format of the file is:
<tvtunes>
    <file>tvtunes.mp3</file>
    <file>C:\XBMC\SingleTheme\anothertvtunes.mp3</file>
    <directory>C:\XBMC\RemoteThemes</directory>
    <playlistfile>playlist.m3u</playlistfile>
</tvtunes>
You can have as many or few of the "file"/"directory"/"playlistfile" elements as you wish. (playlist is either local to the nfo file, or fill path to remote location)
Let me know how you get on.
Thanks, Rob
http://code.google.com/p/robwebset/source/detail?r=158
Updated the wiki: http://wiki.xbmc.org/index.php?title=Add...le_Support
Thanks, the nfo idea solved my problem with movies!
(2013-12-13, 23:29)tinybutstrong Wrote: [ -> ]Thanks, the nfo idea solved my problem with movies!
OK, but that wasn't my intension Big Grin
Wasn't quite sure what your setup was - the NFO was just a generic new feature to allow custom setups.
Rob
Here is my full log. I only open XBMC scan the theme for Banshee tvseries and it was saved in J:\SERIES\ , not in J:\SERIES\BANSHEE\ .Also, all series that had not theme before this moment, all have now banshee theme.
One more thing: Why with tvtunes vers. 3.0.6 everything works fine?
00:16:53 T:5320 NOTICE: -----------------------------------------------------------------------
00:16:53 T:5320 NOTICE: Starting XBMC (12.1 Git:20130317-0d373cc), Platform: Windows 7 SP1 64-bit, build 7601. Built on Mar 17 2013 (compiler 1600)
00:16:53 T:5320 NOTICE: AMD Phenom™ II X6 1055T Processor
00:16:53 T:5320 NOTICE: Desktop Resolution: 1920x1080 32Bit at 60Hz
00:16:53 T:5320 NOTICE: Running with administrator rights
00:16:53 T:5320 NOTICE: Aero is enabled
00:16:53 T:5320 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\XBMC
00:16:53 T:5320 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\XBMC
00:16:53 T:5320 NOTICE: special://masterprofile/ is mapped to: C:\Users\Aky\AppData\Roaming\XBMC\userdata
00:16:53 T:5320 NOTICE: special://home/ is mapped to: C:\Users\Aky\AppData\Roaming\XBMC\
00:16:53 T:5320 NOTICE: special://temp/ is mapped to: C:\Users\Aky\AppData\Roaming\XBMC\cache
00:16:53 T:5320 NOTICE: The executable running is: C:\Program Files (x86)\XBMC\XBMC.exe
00:16:53 T:5320 NOTICE: Local hostname: Aky-PC
00:16:53 T:5320 NOTICE: Log File is located: C:\Users\Aky\AppData\Roaming\XBMC\xbmc.log
00:16:54 T:5320 NOTICE: Found 2 Lists of Devices
00:16:54 T:5320 NOTICE: Enumerated DirectSound devices:
00:16:54 T:5320 NOTICE: Device 1
00:16:54 T:5320 NOTICE: m_deviceName : {B7949508-F8BB-4CB6-94D4-758AD4BF5B0B}
00:16:54 T:5320 NOTICE: m_displayName : Speakers - Altavoces (Dispositivo de High Definition Audio)
00:16:54 T:5320 NOTICE: m_displayNameExtra: DirectSound: Altavoces (Dispositivo de High Definition Audio)
00:16:54 T:5320 NOTICE: m_deviceType : AE_DEVTYPE_PCM
00:16:54 T:5320 NOTICE: m_channels : FL,FR,FC,BL,BR,LFE
00:16:54 T:5320 NOTICE: m_sampleRates : 44100
00:16:54 T:5320 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_AC3
00:16:54 T:5320 NOTICE: Device 2
00:16:54 T:5320 NOTICE: m_deviceName : {2C0B0D32-875F-43C6-8263-FA7E5858D12C}
00:16:54 T:5320 NOTICE: m_displayName : SPDIF - Audio digital (S/PDIF) (Dispositivo de High Definition Audio)
00:16:54 T:5320 NOTICE: m_displayNameExtra: DirectSound: Audio digital (S/PDIF) (Dispositivo de High Definition Audio)
00:16:54 T:5320 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
00:16:54 T:5320 NOTICE: Device 3
00:16:54 T:5320 NOTICE: m_deviceName : {9C31AC74-AD98-463E-87DA-C8F6ED83620A}
00:16:54 T:5320 NOTICE: m_displayName : Speakers - Altavoces (4- C-Media USB Audio Device )
00:16:54 T:5320 NOTICE: m_displayNameExtra: DirectSound: Altavoces (4- C-Media USB Audio Device )
00:16:54 T:5320 NOTICE: Device 4
00:16:54 T:5320 NOTICE: m_deviceName : {F67668A8-43C8-44F7-8C63-50B1BC80C6B5}
00:16:54 T:5320 NOTICE: Enumerated WASAPI devices:
00:16:54 T:5320 NOTICE: m_displayNameExtra: WASAPI: Audio digital (S/PDIF) (Dispositivo de High Definition Audio)
00:16:54 T:5320 NOTICE: m_sampleRates : 192000,96000,88200,48000,44100,32000
00:16:54 T:5320 NOTICE: m_dataFormats : AE_FMT_DTS,AE_FMT_AC3,AE_FMT_AAC,AE_FMT_S24NE4,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
00:16:54 T:5320 NOTICE: m_displayNameExtra: WASAPI: Altavoces (4- C-Media USB Audio Device )
00:16:54 T:5320 NOTICE: m_sampleRates : 48000,44100
00:16:54 T:5320 NOTICE: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
00:16:54 T:5320 NOTICE: m_displayNameExtra: WASAPI: Altavoces (Dispositivo de High Definition Audio)
00:16:54 T:5320 NOTICE: m_channels : FL,FR,FC,LFE,SL,SR,BL,BR
00:16:54 T:5320 NOTICE: m_sampleRates : 192000,96000,48000,44100
00:16:54 T:5320 NOTICE: m_dataFormats : AE_FMT_S24NE4,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_LPCM
00:16:54 T:5320 NOTICE: load settings...
00:16:54 T:5320 NOTICE: special://profile/ is mapped to: special://masterprofile/
00:16:54 T:5320 NOTICE: loading special://masterprofile/guisettings.xml
00:16:54 T:5320 NOTICE: Getting hardware information now...
00:16:54 T:5320 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
00:16:54 T:5320 NOTICE: Loaded playercorefactory configuration
00:16:54 T:5320 NOTICE: Loading player core factory settings from special://profile/playercorefactory.xml.
00:16:54 T:5320 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
00:16:54 T:5320 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
00:16:54 T:5320 NOTICE: Default DVD Player: dvdplayer
00:16:54 T:5320 NOTICE: Default Video Player: dvdplayer
00:16:54 T:5320 NOTICE: Default Audio Player: paplayer
00:16:54 T:5320 NOTICE: Disabled debug logging due to GUI setting. Level 0.
00:16:54 T:5320 NOTICE: Log level changed to 0
00:16:54 T:5320 NOTICE: Loading media sources from special://masterprofile/sources.xml
00:16:54 T:5020 NOTICE: Thread CSoftAE start, auto delete: false
00:16:54 T:5320 NOTICE: Running database version Addons15
00:16:54 T:4868 NOTICE: Thread XBMC Peripherals start, auto delete: false
00:16:54 T:5320 NOTICE: Problematic iMON hardware detected. Joystick usage: disabled.
00:16:54 T:5320 NOTICE: PERIPHERALS::CPeripheralBus::Register - new imon device registered on usb->\\?\usb#vid_15c2&pid_0038#5&17483028&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed}: iMON HID device (15C2:0038)
00:16:54 T:6412 NOTICE: Thread XBMC Peripherals start, auto delete: false
00:16:54 T:1456 NOTICE: Thread CRemoteControl start, auto delete: false
00:16:54 T:5320 NOTICE: Found screen: Monitor PnP genérico on NVIDIA GeForce GTX 770, adapter 0.
00:16:54 T:5320 NOTICE: Primary mode: 1920x1080 @ 60.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 640x480 @ 60.00 - Full Screen
00:16:54 T:5320 NOTICE: Previous line repeats 2 times.
00:16:54 T:5320 NOTICE: Additional mode: 640x480 @ 59.94 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 640x480 @ 61.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 640x480 @ 50.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 720x480 @ 60.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 720x480 @ 59.94 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 720x576 @ 50.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 800x600 @ 60.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1024x768 @ 60.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1152x864 @ 60.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1176x664 @ 50.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1176x664 @ 60.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1176x664 @ 59.94 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1176x664 @ 61.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1280x720 @ 60.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1280x720 @ 59.94 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1280x720 @ 61.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1280x720 @ 50.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1280x768 @ 60.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1280x800 @ 60.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1280x960 @ 60.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1280x1024 @ 60.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1360x768 @ 60.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1366x768 @ 60.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1366x768 @ 59.94 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1366x768 @ 30.00i - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1366x768 @ 29.97i - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1366x768 @ 50.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1366x768 @ 25.00i - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1366x768 @ 24.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1366x768 @ 23.98 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1366x768 @ 25.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1366x768 @ 30.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1366x768 @ 29.97 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1600x900 @ 60.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1600x900 @ 59.94 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1600x900 @ 30.00i - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1600x900 @ 29.97i - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1600x900 @ 50.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1600x900 @ 25.00i - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1600x900 @ 24.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1600x900 @ 23.98 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1600x900 @ 25.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1600x900 @ 30.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1600x900 @ 29.97 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1600x1024 @ 60.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1600x1024 @ 59.94 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1600x1024 @ 30.00i - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1600x1024 @ 29.97i - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1600x1024 @ 50.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1600x1024 @ 25.00i - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1600x1024 @ 24.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1600x1024 @ 23.98 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1600x1024 @ 25.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1600x1024 @ 30.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1600x1024 @ 29.97 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1680x1050 @ 60.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1680x1050 @ 59.94 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1680x1050 @ 30.00i - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1680x1050 @ 29.97i - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1680x1050 @ 50.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1680x1050 @ 25.00i - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1680x1050 @ 24.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1680x1050 @ 23.98 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1680x1050 @ 25.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1680x1050 @ 30.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1680x1050 @ 29.97 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1768x992 @ 25.00i - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1768x992 @ 30.00i - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1768x992 @ 29.97i - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1920x1080 @ 60.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1920x1080 @ 59.94 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1920x1080 @ 30.00i - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1920x1080 @ 29.97i - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1920x1080 @ 50.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1920x1080 @ 25.00i - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1920x1080 @ 24.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1920x1080 @ 23.98 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1920x1080 @ 25.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1920x1080 @ 30.00 - Full Screen
00:16:54 T:5320 NOTICE: Additional mode: 1920x1080 @ 29.97 - Full Screen
00:16:54 T:5320 NOTICE: Checking resolution 16
00:16:54 T:5320 NOTICE: Running database version ViewModes4
00:16:54 T:5320 NOTICE: Running database version Textures13
00:16:54 T:5320 NOTICE: Running database version MyMusic32
00:16:54 T:5320 NOTICE: Running database version MyVideos75
00:16:54 T:5320 NOTICE: Running database version TV22
00:16:54 T:5320 NOTICE: Running database version Epg7
00:16:54 T:5320 NOTICE: initializing playlistplayer
00:16:54 T:5320 NOTICE: DONE initializing playlistplayer
00:16:55 T:5316 NOTICE: Thread XBPyThread start, auto delete: false
00:16:55 T:5320 NOTICE: CApplication::UpdateLibraries - Starting video library startup scan
00:16:55 T:5316 NOTICE: -->Python Interpreter Initialized<--
00:16:55 T:5240 NOTICE: Thread CVideoInfoScanner start, auto delete: false
00:16:55 T:5320 NOTICE: initialize done
00:16:55 T:5320 NOTICE: Running the application...
00:16:55 T:6780 NOTICE: Thread XBPyThread start, auto delete: false
00:16:55 T:6780 NOTICE: -->Python Interpreter Initialized<--
00:16:55 T:3284 NOTICE: Thread Jobworker start, auto delete: true
00:16:55 T:6780 NOTICE: StorageServer Module loaded RUN
00:16:55 T:6780 NOTICE: StorageClient-2.5.2 Starting server
00:16:55 T:6780 NOTICE: StorageServer-2.5.2 Storage Server starting C:\Users\Aky\AppData\Roaming\XBMC\cache\commoncache.db
00:16:55 T:5204 NOTICE: Thread Background Loader start, auto delete: false
00:16:55 T:732 NOTICE: Thread XBPyThread start, auto delete: false
00:16:55 T:5320 NOTICE: ES: Starting event server
00:16:55 T:1224 NOTICE: Thread CEventServer start, auto delete: false
00:16:55 T:1224 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
00:16:55 T:1224 NOTICE: UDP: Listening on port 9777
00:16:55 T:4648 NOTICE: Thread CTCPServer start, auto delete: false
00:16:55 T:5240 NOTICE: VideoInfoScanner: Starting scan ..
00:16:55 T:732 NOTICE: -->Python Interpreter Initialized<--
00:16:55 T:3848 NOTICE: Thread Jobworker start, auto delete: true
00:16:55 T:5428 NOTICE: Previous line repeats 2 times.
00:16:55 T:5428 NOTICE: Thread XBPyThread start, auto delete: false
00:16:55 T:5428 NOTICE: -->Python Interpreter Initialized<--
00:16:59 T:7116 NOTICE: Thread Background Loader start, auto delete: false
00:17:05 T:6100 NOTICE: Previous line repeats 1 times.
00:17:05 T:6100 NOTICE: Thread CFileCache start, auto delete: false
00:17:06 T:6172 NOTICE: Thread PAPlayer start, auto delete: false
00:17:08 T:5240 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:13
00:17:08 T:4844 NOTICE: Thread Background Loader start, auto delete: false
00:17:13 T:6544 NOTICE: Previous line repeats 1 times.
00:17:13 T:6544 NOTICE: Thread XBPyThread start, auto delete: false
00:17:13 T:6544 NOTICE: -->Python Interpreter Initialized<--
00:17:13 T:6156 NOTICE: Thread XBPyThread start, auto delete: false
00:17:13 T:6156 NOTICE: -->Python Interpreter Initialized<--
00:17:13 T:6480 NOTICE: Thread CFileCache start, auto delete: false
00:17:13 T:1608 NOTICE: Thread PAPlayer start, auto delete: false
00:17:16 T:2304 NOTICE: Thread XBPyThread start, auto delete: false
00:17:16 T:2304 NOTICE: -->Python Interpreter Initialized<--
00:17:16 T:6712 NOTICE: Thread XBPyThread start, auto delete: false
00:17:16 T:6712 NOTICE: -->Python Interpreter Initialized<--
00:17:27 T:6712 ERROR: XFILE::CFile:Big Grinelete - Error deleting file J:\SERIES\theme.mp3
00:17:32 T:5164 NOTICE: Thread Background Loader start, auto delete: false
00:17:33 T:2788 NOTICE: Thread CFileCache start, auto delete: false
00:17:33 T:6252 NOTICE: Thread PAPlayer start, auto delete: false
00:17:41 T:3892 NOTICE: Thread Background Loader start, auto delete: false
00:17:50 T:6372 NOTICE: Previous line repeats 1 times.
00:17:50 T:6372 NOTICE: Thread CFileCache start, auto delete: false
00:17:50 T:6660 NOTICE: Thread PAPlayer start, auto delete: false
00:17:53 T:6836 NOTICE: Thread Background Loader start, auto delete: false
00:18:01 T:5320 NOTICE: Previous line repeats 1 times.
00:18:01 T:5320 NOTICE: Storing total System Uptime
00:18:01 T:5320 NOTICE: Saving settings
00:18:01 T:5320 NOTICE: stop all
00:18:01 T:5320 NOTICE: ES: Stopping event server
00:18:01 T:5320 NOTICE: stopping zeroconf publishing
00:18:02 T:1224 NOTICE: ES: UDP Event server stopped
00:18:02 T:5320 NOTICE: stop sap announcement listener
00:18:02 T:5320 NOTICE: clean cached files!
00:18:02 T:5320 NOTICE: unload skin
00:18:02 T:5320 WARNING: CGUITextureManager::Cleanup: Having to cleanup texture button-focus.png
00:18:02 T:5320 WARNING: CGUITextureManager::Cleanup: Having to cleanup texture button-nofocus.png
00:18:02 T:6780 NOTICE: StorageServer-2.5.2 Closed down
00:18:02 T:5320 NOTICE: stop python
00:18:02 T:5320 NOTICE: stopped
00:18:02 T:5320 NOTICE: destroy
00:18:02 T:5320 NOTICE: closing down remote control service
00:18:02 T:5320 NOTICE: unload sections
00:18:03 T:5320 NOTICE: destroy
00:18:03 T:5320 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
00:18:03 T:5320 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
00:18:03 T:5320 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
00:18:03 T:5320 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
00:18:03 T:5320 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
00:18:03 T:5320 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
00:18:03 T:5320 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
00:18:03 T:5320 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
00:18:03 T:5320 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
00:18:03 T:5320 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
00:18:03 T:5320 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
00:18:03 T:5320 NOTICE: closing down remote control service
00:18:03 T:5320 NOTICE: unload sections
00:18:03 T:5320 NOTICE: application stopped...
Aky
(2013-12-14, 02:21)aky75 Wrote: [ -> ]Here is my full log. I only open XBMC scan the theme for Banshee tvseries and it was saved in J:\SERIES\ , not in J:\SERIES\BANSHEE\ .Also, all series that had not theme before this moment, all have now banshee theme.
Hi aky75,
A couple of things:
Is the location you are trying to save the file write-able? I can see an error:
00:17:27 T:6712 ERROR: XFILE::CFile::Delete - Error deleting file J:\SERIES\theme.mp3
Rob
Hi Rob,
Thanks for the info about pasting...
I'll post the debug log,
Other way, I think that the question not matters with file permissions (I can read,write,etc in this folders), because when I roll back to 3.0.6 version of addon, everything works fine...
Thanks,
Aky
Here is my log:
http://xbmclogs.com/show.php?id=98086
Aky
(2013-12-16, 14:24)aky75 Wrote: [ -> ]Here is my log:
Aky
Please can you try the following patch and let me have a copy of the log?
http://robwebset.googlecode.com/svn/trun...scraper.py
Rob
Is there any way to ignore .nfo files when updating library? I added a tvtunes.nfo for a movie before to add in library. Then I updated the library, but this movie was ignored in auto scraping.
(2013-12-16, 19:36)tinybutstrong Wrote: [ -> ]Is there any way to ignore .nfo files when updating library? I added a tvtunes.nfo for a movie before to add in library. Then I updated the library, but this movie was ignored in auto scraping.
That's strange - I'm not seeing that.
The tvtunes.nfo file should be ignored as it does not match the naming standards. That is unless you have a Film called "tvtunes"?
Which Movie scrapper is this? - Is it the default themoviedb.org?
Rob
I'm using Universal Movie Scaper. In next movie I'll take the log to share here.
(2013-12-16, 21:15)tinybutstrong Wrote: [ -> ]I'm using Universal Movie Scaper. In next movie I'll take the log to share here.
Sounds like a bug in that scrapper - you may want to post on their forum thread and see what they say.
Looks like they are picking up nfo files that do not match the required naming requirements.
Rob
(2013-12-16, 15:46)rob_webset Wrote: [ -> ]
Aky
Rob
Hi Rob,
Here is my new log after patching:
http://xbmclogs.com/show.php?id=98401
Still not works...
So much thanks for your work
Aky
(2013-12-17, 11:31)aky75 Wrote: [ -> ]Hi Rob,
Still not works...
Aky
Unfortunately I can see why TvTunes is putting it in the incorrect directory, it is because the call to find the directory (to XBMC) on your system returns the wrong directory. On my system (windows) it returns the correct directory. (And on everyone elses system as well I guess as there haven't been any other reports of this issue)
The only thing I can think to suggest is to check your hooks, as they do seem a bit of a mess from your previous post.
They should be exactly as detailed on the following page:
http://wiki.xbmc.org/index.php?title=Add...in_Changes
Please let me know how you get on.
Rob
(2013-12-12, 20:59)rob_webset Wrote: [ -> ]
(2013-12-12, 20:31)aky75 Wrote: [ -> ]The begining of Dialogvideoinfo.xml:
<window>
<defaultcontrol always="true">8</defaultcontrol>
<allowoverlay>no</allowoverlay>
<onload condition="Skin.HasSetting(ActivateTvTunes) + System.HasAddon(script.tvtunes)">
XBMC.RunScript(script.tvtunes,backend=True)</onload>
<controls>
<control type="group">
<visible>!Window.IsVisible(FileBrowser)</visible>
<animation effect="slide" start="1100,0" end="0,0" time="400" tween="quadratic" easing="out">WindowOpen</animation>
<animation effect="slide" start="0,0" end="1100,0" time="400" tween="quadratic" easing="out">WindowClose</animation>
The begining of MyvideoNav.xml:
<window>
<defaultcontrol always="true">50</defaultcontrol>
<views>50,51,500,550,551,560,501,508,504,503,515,505,511</views>
<controls>
<include>CommonBackground</include>
<include>ContentPanelBackgrounds</include>
<include>Window_OpenClose_Animation</include>
The end of MyvideoNav.ml:
<control type="radiobutton" id="11">
<description>Unlock Shares</description>
<textwidth>170</textwidth>
<include>ButtonCommonValues</include>
<label>20336</label>
<onclick>xbmc.mastermode</onclick>
<selected>system.ismaster</selected>
<visible>system.haslocks</visible>
</control>
<control type="button" id="100">
<description>Fetch TvTunes stuff</description>
<include>ButtonInfoDialogsCommonValues</include>
<label>31127</label>
<onclick condition="Container.Content(TVShows)">
mode=solo&amp;name=$INFO[Listitem.Title]&amp;path=$INFO[ListItem.FilenameAndPath])
</onclick>
<onclick condition="Container.Content(movies)">
mode=solo&amp;path=$INFO[ListItem.FilenameAndPath]&amp;name=$INFO[ListItem.TVShowTitle])
</onclick>
<visible>Skin.HasSetting ActivateTvTunes) + System.HasAddon(script.tvtunes) +
[Container.Content(TVShows) | Container.Content(movies)] </visible>
</control>
<include>CommonNowPlaying_Controls</include>
</control>
</control>
<include>Clock</include>
</controls>
</window>
The bit in red should be:
Is this something you have changed yourself?
If this is a bug with the latest skin - may be worth you posting on the Confluence forum thread.
Rob
@aky75: have you noticed you are placing a whole instruction supposed to be for DialogVideoInfo.xml at the footer of your MyVideoNav.xml? That is no good. On top of that, you are truncating it. You must use the extended instruction Rob created so the download of themes on a video-by-video basis can be executed:
<visible>Skin.HasSetting(ActivateTvTunes) + System.HasAddon(script.tvtunes) +
    [Container.Content(TVShows) | Container.Content(movies)] +
    IsEmpty(Window(movieinformation).Property("TvTunes_HideVideoInfoButton"))</visible>
Now, in the same xml, you are using an old extended <onclick> instruction that we no longer use. You should use:
<onclick>XBMC.RunScript(script.tvtunes,mode=solo)</onclick>
Make sure you use exactly what the wiki says in the right order, just as Rob has pointed out to you. If things do not work out properly after editing the xml files and restarting XBMC, do a fresh installation of your XBMC (backing up your user data folder).
Let us know if it works for you now.
