(2015-01-06, 22:29)MARIOTELI Wrote: [ -> ] (2014-05-25, 18:53)vorace Wrote: [ -> ]hello I'm new I can offer you my zip file that I have extracted from XTB box mod by samu-rai for housings thumb box
download:
http://www.4shared.com/zip/qvL2pRQRba/media.html?
buenas me descargae tu archivo .zip, pero no me cambia nada, cual es el archivo de texturas? porque en mi carpeta creo q no sale ninguno, te lo agradeceria gracias
English only in this forum my friend. Sorry.
(2015-01-06, 23:47)Samu-rai Wrote: [ -> ] (2015-01-06, 22:29)MARIOTELI Wrote: [ -> ] (2014-05-25, 18:53)vorace Wrote: [ -> ]hello I'm new I can offer you my zip file that I have extracted from XTB box mod by samu-rai for housings thumb box
download:
good descargae me your .zip file, but I do not change anything, what is the texture file? because in my folder I believe q does not leave none, I appreciate thanks
What are you wanting to acheive? Which mod do you want to use?
(2015-01-08, 14:03)Samu-rai Wrote: [ -> ]What are you wanting to acheive? Which mod do you want to use?
because there are not that mod not understand much, I Download the the link you send, but good, and seen the samurai yours are fine, if serious kindly send me one of your own and that steps must I take to activate them because I use the skin aeon MQ5 with the type of right view list
(2015-01-08, 19:39)Samu-rai Wrote: [ -> ]If you want to use my cases, download the xbt with this link:
http://www.mediafire.com/download/8yexja...mu-rai.xbt
Then put it in the media folder of MQ5 (addons/skin.aeon.mq5/media) > Load Kodi > Settings > Appearance > and then under 'Theme' select my mod.
thanks brother, he is perfect! and have bluray audio logos and other colored and colored flags?
(2014-09-14, 01:05)Samu-rai Wrote: [ -> ]Just download the xbt file > place it in .....addons/skin.aeonmq5/media > load up Kodi > go to the appearance settings screen, and change the skin theme to the xbt you chose.
I've searched everywere in my iMac and i've also enabled hidden folders but i cannot find where put my .xbt file.
Can someone help me?
Thx in advance.
Zippi.
/Users/<your_user_name>/Library/Application Support/xbmc/addons/skin.aeon.mq5
(2015-01-10, 19:20)Samu-rai Wrote: [ -> ]/Users/<your_user_name>/Library/Application Support/xbmc/addons/skin.aeon.mq5
GREAT!!!!!
ALL OK!!!!!
I put
case_mod_by_samu-rai.xbt into: /Users/<your_user_name>/Library/Application Support/Kodi/addons/skin.aeonmq5.helixmod/media
Thanx a lot!!!!!!!
(2014-06-13, 10:19)devilshura Wrote: [ -> ]- Movie set artwork automator can use as standalone program add-on, via program--->movie set artwork automator. but you need to config it by context menu(press "C" ---> setting) before use.
- The collection name is depend on the name in xbmc library.
Devil. Can you make a ViewLeftList which is a vertical flip version of ViewRightList? With movies list on the left, disc case on the right, and discart slide from right to left. I tried but can't get the discart slide from left to right.
(2015-01-20, 04:56)Voodoo411 Wrote: [ -> ]Devil. Can you make a ViewLeftList which is a vertical flip version of ViewRightList? With movies list on the left, disc case on the right, and discart slide from right to left. I tried but can't get the discart slide from left to right.
That view is mod by adjust some value. So I'm not good in code to much. You will ask for that with view modder like "PosterLite for MQ5".
Hello everyone!
I followed your first page instructions and added the GLOW.XBT file to %appdata%/kodi/addons/skin.aeonmq5/media but when inside Kodi I go in Settings -> Skin -> Appearance the "theme" option is grey and I cannot select media case style...
I also followed this thread (
http://forum.kodi.tv/showthread.php?tid=185026&page=3) and I copied .png files manually (see post #40) but again nothing changed.
Can you help me please??
Win 8.1, Kodi 14.1
Many thanks in advance!
EDIT: I put .xbt file in "skin.aeonmq5" folder instead of "skin.aeonmq5.helixmod"...Thanks for your hard work.
