Is there a path for MAC/OSX?
I don't have the folder for aeonmq5
Can somone let me know how I can install
Gloss_color flags_R3 from
here
into my Aeon MQ5 skin
many thanks
Just download the xbt file > place it in .....addons/skin.aeonmq5/media > load up Kodi > go to the appearance settings screen, and change the skin theme to the xbt you chose.
(2014-09-14, 01:05)Samu-rai Wrote: [ -> ]Just download the xbt file > place it in .....addons/skin.aeonmq5/media > load up Kodi > go to the appearance settings screen, and change the skin theme to the xbt you chose.
all sorted - thanks for the quick tip Samu-rai
(2014-05-31, 06:28)devilshura Wrote: [ -> ]Sory with my fault.May be i confuse about "cine alta" in 4k logo.There are new images for fix it(right click to save).
Devilshura is it possible for you to repack these two new images in a glass colour flags .xbt file, I can find where the mispelt one goes but not the other. Also could you add pcm_s24be and pcm_s24be as a lot of my blu-rays use this codec and they are needed for at least 30 movies and concerts in my collection. I have added them to the audiocodec folder by renaming the pcm_s16be and pcm_s16be in your media.zip file, but the flags seem different to the PCM flag in the glass colour flags R3, i.e. No small icon in front of the PCM and very plain.
Thanks so much.
Is anybody using OpenElec with this Aeon MQ5
I can't find where the MEDIA folder where is located.
I have some banned/not rated movies. Is it in some way possible to make own icons for this ratings? I mean, i can make them and i also can include them into the .xbt file. But i dont know how i can activate them..
buenas soy nuevo en kodi, y estoy interesado en esto que haceis de cambiar las cajas y logo y demas, pero ... no tengo ni idea de como hacerlo, seria de mal gusto pedir que me pasarais el archivo .zip con tods las cajas echas y los logos de audio y demas con color, pero lo agradeceria un monton, gracias de todas formas, un saludo
(2014-05-25, 18:53)vorace Wrote: [ -> ]hello I'm new I can offer you my zip file that I have extracted from XTB box mod by samu-rai for housings thumb box
download:
http://www.4shared.com/zip/qvL2pRQRba/media.html?
buenas me descargae tu archivo .zip, pero no me cambia nada, cual es el archivo de texturas? porque en mi carpeta creo q no sale ninguno, te lo agradeceria gracias
