Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
Looking forward to it. Looks really great. Let me also know how to install it?
Sorry guys. I didn't get a chance to tinker yesterday.
I'll post them up as soon as I can.
I have 2 style to share.For uses new cases,move the download .xbt to your Aeon MQ5 media folder.
Glass
Gloss
Thanks they look great will give them a try
Tried them they look cool,
For anyone wanting to try different cover, retrieved this info from another thread
(2014-01-21, 23:55)SeedyEvil Wrote: [ -> ]Some nice case designs here. Instead of replacing the textures.xbt file with the new one, rename the new one (I.e. Simplecase.xbt or highqualitycase.xbt) and place alongside the original textures.xbt in aeonmq5's media folder. You can then go to "Appearance" under "Settings" (where you change skins) and change the "Theme" setting from "Default" to whatever you called your new xbt file. After a slight pause you'll find your new cases loaded. This allows you to have several case designs (simply add another xbt) and keeps the original xbt in place aswell.
The media folder is in userdata/addons/mq5 skin folder
Hope this helps
Check out MQ's thread
here.
Sorry about my miss info.thank m0v1em4n and Samu-rai to point for how to.
I include .xbt by anything i changed.Not at all in textures.xbt for small file size.
e.g.
For this to be easier for users, I edited your first post in this topic. Please, put your changes and informations by there. Thanks for the good work.
The cases look great. This skin is great. Everything is good.
(2014-01-31, 15:07)MarcosQui Wrote: [ -> ]Dear users,
I had a new idea and I will change the format of this feature. The new format will bring back the themes of texture as it was in Aeon MQ 2, this will allow each one to change all the textures you want, including, boxes, flags and everything.
Soon I will give more news about it, stay tuned.
This sounds very good..
I have update links for my cases in 1st page.with new flag style include.
Thanks some great work there, will check them out
Great work!!
Where do i put the glass/gloss files on mac/osx? I cant figure it out.
Thank you devilshura: Great work on the themes, looks very nice!
Samu-rai
Any progress made on your cases?
