Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
Hello All
How can I add cases in main window to widget
(2015-05-14, 01:00)bvainrub Wrote: [ -> ]Hello All
Mod skin file IncludesMenuWidgets.xml as desired.
scott s.
Hello Scott.
I know how change to case view in Aeon , but before, I spend a lot of time to found this option in Aeon MQ 5 skin. Suddenly I found this in movie on youtube.
Can you please add couple words or upload updated IncludesMenuWidgets.xml ?
I found here :
<control type="label">
<posx>280</posx>
<posy>20</posy>
<width>600</width>
<height>330</height>
<align>left</align>
<aligny>top</aligny>
<font>Font_17A</font>
<textcolor>FFFFFAF0</textcolor>
<label>[LOWERCASE]$VAR[SkinVersion][CR]$INFO[System.BuildVersion][COLOR=80FFFFFF] | [/COLOR]$INFO[System.BuildDate][CR]$VAR[value_skinstatus_theme][CR]$VAR[value_skinstatus_style][CR]$VAR[value_skinstatus_texturecolor][CR]$VAR[value_skinstatus_headercolor][CR]$VAR[value_skinstatus_homeglass][CR]$INFO[System.FPS][CR]$INFO[System.ScreenWidth]x$INFO[System.ScreenHeight] pxl[CR]$INFO[System.CpuFrequency][CR]$INFO[System.FreeMemory][CR]$INFO[System.BatteryLevel][CR]$INFO[System.FreeSpace][COLOR=80FFFFFF] | [/COLOR]$INFO[System.FreeSpacePercent][CR]$INFO[Network.IPAddress][CR]$INFO[System.InternetState][CR]$INFO[System.Uptime][/LOWERCASE]</label>
</control>
What I need change? or its wrong control
Please help with my case problem
From looking at your screenshot, it seems like textures are being used for the cases that aren't part of MQ5. So first thing would be to get those textures. Suggest finding out who did the MOD and see if they are uploaded anywhere. But I think what needs to be changed is the layout and focusedlayout sections of the panel control found in
<include name="panel_layout">
in the file.
scott s.
scott967, Aeon MQ6 skin, video mentioned is mine, about integration emby with kodi via video addon. In this case don´t need change anything in skin for have cases at home (addon in action).
OK so it is using Kodi as the Media Browser / Emby client.
scott s.
Yes, but using kodi databases.
(2015-05-15, 23:54)Wanilton Wrote: [ -> ]scott967, Aeon MQ6 skin, video mentioned is mine, about integration emby with kodi via video addon. In this case don´t need change anything in skin for have cases at home (addon in action).
Some questions
You have 2 info screens? one at 2:40 the old info screen and one at 5:00 you have a new info screen?
What is this "emby?"
Nope...info is provide by skin. This is only a shortcut (addon have files and arts for second video info).
About cases, you need use emby and plugin.video.emby for sync
Anyone know how to do this on android?
I cant get into the folder where these need to be
