Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
(2015-02-28, 17:27)Poland Wrote: [ -> ]Please help. What am I wrong set ??
If you use the set arts in parent folder. That better to not use prefix. It must be wrong name of collection.
The problem is only in the name of the folder ??
Matrix.1999.BLURAY.1080p.DolbyTrueHD 5.1
it should be ??
(2015-02-28, 19:49)Poland Wrote: [ -> ]The problem is only in the name of the folder ??
it should be ??
It may be not,Just put its to parent folder of your collection movies folder, in simple name like logo,poster,fanart etc.
Still does not work. I already did everything I guess ...Why was inadvertently help ..........
Still not working
I got a question concerning case flags and media flags.
How can i set them correct ?
Case flags: can i get extra flags somewhere i need one for HD and Bluray.
Now some movies have wrong case flag...
Media flags.. How are they set? Some movies have 0 flags lol
I have movies with atmos.. Would love that flag too
Even 5.1 vs 7.1 how do i set this correctly?
I saw this
A: Ace use the 'tags' on the file name or folder to determine the type of case as follows:
bluray - blu-ray - bdrip (without 3d or 3dbd tag) = Bluray box
bluray - blu-ray - bdrip + 3d or 3dbd = 3D box
3d - 3dbd = 3D box
web = Web box
hdtv = HDTV box
dvd - .iso (without bluray or any other tag) - .ifo = dvd box
All others contents = default box + codec
A example for the bluray case:
filename = moviename.bluray.mkv
However those tags in folder dont work!
(2015-04-04, 17:42)Skank Wrote: [ -> ]I got a question concerning case flags and media flags.
I saw this
3d - 3dbd = 3D box
web = Web box
hdtv = HDTV box
Media flags at the bottom of the screen are taken from what your scrapper finds (does it have a trailer, how many stars rating etc) and what kodi can obtain from the video file (video/audio codec, resolution etc).
If some of your files have none than it would suggest that neither are able to gain any of the info MQ5 can display.
As for cases I can’t really help as the tagging system you have quoted works for me.
For example the following will display a Blu-Ray case:
Folder - Avatar.2009.1080p.BluRay
File - Avatar.2009.1080p.BluRay.mkv
Is there a way to make the media flags correct? Correct them somehow?
3d flag is working now
However the case flags are different than in the pics by you samurai.
Theres a small "icon" or something before each logo. How do i get rid of that?
Can a person filter collection by case tags?
And by media flags?
I'm not sure what you mean. Would you post a screenshot?
You can filter by lots of different categories and conditions with smart playlists.
For case tags you could use a rule like:
where 'filename' 'contains' bluray
Ill post a screen tomorrow
Any idea why my discart isnt showing?
I ran artwork downloader to get it, and its enabled in skin but i dont see it
I think it has to be local disc art to be picked up. Not sure why, may be a bug in AD or MQ5.
