2014-02-10, 15:00
Sorry Schumi, no progress yet. I've been really busy with another project, which I hope to finish this week.
As soon as I do I will get the cases out I promise.
(2014-02-10, 13:30)sonic Wrote: [ -> ]Thank you devilshura: Great work on the themes, looks very nice!
(2014-02-18, 02:21)ricardosunnie Wrote: [ -> ]@devilshura:
I really like your work, using it on both my XBMC installs.
I got one request, can you post gloss color flags file without the cd with the music tekst?
Problem is that it shows at the bottom of the screen even when I choose another cd art with the currently watching tv channel.
Thanks in advance!
(2014-01-29, 19:51)devilshura Wrote: [ -> ]I have 2 style to share.For uses new cases,move the download .xbt to your Aeon MQ5 media folder.
(2014-01-21, 23:55)SeedyEvil Wrote: [ -> ]Some nice case designs here. Instead of replacing the textures.xbt file with the new one, rename the new one (I.e. Simplecase.xbt or highqualitycase.xbt) and place alongside the original textures.xbt in aeonmq5's media folder. You can then go to "Appearance" under "Settings" (where you change skins) and change the "Theme" setting from "Default" to whatever you called your new xbt file. After a slight pause you'll find your new cases loaded. This allows you to have several case designs (simply add another xbt) and keeps the original xbt in place aswell.
Glass_R2
Gloss_R2
*update cases with new case flag and bottom color media flags.
Gloss_color flags
optional:to not include default albumcover and cdart.
Gloss_color flags_lt
(2014-02-18, 05:36)devilshura Wrote: [ -> ](2014-02-18, 02:21)ricardosunnie Wrote: [ -> ]@devilshura:
Thanks in advance!
I have update a new link in 1st page without option for music.If you want to uses it separately.This is a zip of all images for use to replace an original in the skin.
Media.zip
(2014-02-18, 14:17)devilshura Wrote: [ -> ]It easy to re-pack a new theme.So i have update it on the 1st page. i think to resize or remake some icon to more smooth with a skin.But that will take period of time.Perfect. Thank you very much.
