Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
discart is ok here in MQ6, skank...
I must be doing something wrong then but what.. I dunno
(2015-04-20, 21:49)Skank Wrote: [ -> ]Im using mq6 lol
Well vice versa.
(2015-04-20, 23:24)Samu-rai Wrote: [ -> ] (2015-04-20, 21:49)Skank Wrote: [ -> ]Im using mq6 lol
Well vice versa.
You have same problem then?
Disc art works so it seems, guess there are a lot that dont have it.
Anyway,
Samurai, you see what i mean with the "sign" ebfore 3d and bluray?
How do i get rid of it?
Oh I see. It looks like it’s using MQ5’s media flags instead of the case flags.
MQ6’s naming of the .png files must have changed. What texture are you using? Have you created a new one for MQ6 with my cases/case flags?
(2015-04-21, 10:43)Samu-rai Wrote: [ -> ]Oh I see. It looks like it’s using MQ5’s media flags instead of the case flags.
No, i just took your files.
Willing to make the change for me pls, so can use them?
Media cases and textures are the same i thought?
Media cases are part of the textures as a whole.
Generally skins come with all the image files packed into a textures.xbt.
Here is a repack of my cases in MQ6's textures. Two things to note though:
1) I literally just did this in 2 mins. It hasn't been checked or tested.
2) From a quick scan I can see that MQ6 has an extra colored case thar MQ5 does not. This may cause some issue and there may be other differences as well.
When I get some time I'll do a proper update for MQ6, but hopefully this will do you for now.
Thanks mate!
Let me know when you do offical repack
Ill test tomorrow
It's work perfect.
You can addon color media flags?
Glad to hear it.
I think media flags will take a bit more time as the names appear to have change from MQ5.
If I get a chance I'll have a look.
Yeah they work, thx a lot samurai!
Ive seen some builds where the Case opens and the disk comes out.. Where do I look to find this option?
