Hi all
So if I understand correct we not have any simple way to activate cases in widget like in other skins, until Aeon MQ6 will be ready ?
Correct - but I don't even know if it is included with MQ6.
how can I activate a wall view about films ?
thanks
Yeah mate looking great well done
(2015-07-31, 19:20)Skank Wrote: [ -> ] (2015-06-23, 14:52)Skank Wrote: [ -> ]Anyone know how to do this on android?
I cant get into the folder where these need to be
Anyone?
You need to create a .zip file of Skin, then install it in your Android Kodi application.
(2015-07-31, 20:44)movie78 Wrote: [ -> ] (2015-07-31, 19:20)Skank Wrote: [ -> ] (2015-06-23, 14:52)Skank Wrote: [ -> ]Anyone know how to do this on android?
Anyone?
Huh?
So i should install the skin on windows pc, add the media cases.. then recreate a zip of the skin with the added cases?
How do i do that?
(2015-08-03, 12:05)Skank Wrote: [ -> ] (2015-07-31, 20:44)movie78 Wrote: [ -> ] (2015-07-31, 19:20)Skank Wrote: [ -> ]Anyone?
Huh?
So i should install the skin on windows pc YES, add the media cases YES.. then recreate a zip of the skin with the added cases YES?
How do i do that?
Navigate to where the skin is,then create a zip of it.
Copy the zip into a thumb drive then install it it on your android box.
Done.
I am on Kodi Isengard (the latest version), with Aeon MQ6
I have downloaded the
Glass color flags R3.xbt from the first page.
The main reason i liked the Glass Color Flags R3 was mainly for the case, and the flags. Loved the setup But now, with the new MQ6 and the Isengard version, its not working the same, Upon installing the glass color flags R3, a couple of things are not looking right.
Please see below.
I love the case display and the flags as seen below.
But upon choosing this, the arrows and the options to choose various items in the settings go missing, see below.
Also, the menu texture becomes solid black.
Is there something i am missing? Is there a newer version of the XBT file, i have missed?
Just a page up i downloaded the new XBT file by Samurai "MQ6-Cases_by_Samu-rai.xbt"
Its good, but i still prefer the glass case r3 version as seen in the first page.
Please guide.
(2015-04-20, 22:00)Wanilton Wrote: [ -> ]discart is ok here in MQ6, skank...
Hello, how did you get the studio logo as seen here in the screenshot (regency) in the flags section?
(2015-09-14, 23:03)Wanilton Wrote: [ -> ]@MANswers, I am using mod devilshura.
I am sorry for asking to spoonfeed me, but can you please please point me to the thread where i can find this mod? Or any instructions please?
It´s mod for MQ6 Isengard, don´t available yet,
Can anyone help me with a problem I'm having?
Media and case flags aren't displaying properly. The media flags for resolution, ratio, audio channels, trailer and watched percentage are remaining the default ones, whilst cases are showing media flags rather than case flags on their tops.
How do I change this and use the desired media and case flags?
I'm using Kodi 15.2 Isengard and Aeon MQ6 3.2.0 (the current versions of both), I'm also using GlassboxR4 flags
