(2020-11-01, 08:52)xxxnelly Wrote: [ -> ]Here is the build I did yesterday. I will spend more time on it this week but just quickly hacked it in.
Its using libreelec master (as off 31/10) with media_import_19.0a2-Matrix branch.
https://www.dropbox.com/s/vg7wlf9ra0ujtb...0.tar?dl=0
I had to manually add the skin change for Estuary. I will workout how to include it in the build - its likely Libreelec changes the skin in the build.
https://www.dropbox.com/s/i1h3snjrggk2sn...y.zip?dl=0
If you just copy the unzip skin to /storage/.kodi/addons/skin.estuary then restart it will pickup the changes to set the media sources etc.
I noticed one other small (likely expected issue). I have a MySQL database set in the AdvancedSettings. This caused the provider to not be added but no real error message was provided.
I removed the MySQL settings and boom it worked as expected from then.
Thanks for your interest and posting your build.
I've never tested MediaImport with MySQL so I'm not sure if it is working or not. If you can see any errors in Kodi's log please let me know so I can fix them.
No problem - I will re-add in the MySQL config and get the log message. There was enough of a hint for me to guess at the MySQL config.
Its MySQL I am wanting to get rid of and I have tested I can resume movies/tv shows from my 3 Libreelec + server setup that I have - so all good with my testing so far.
thanks
This is the error/warning messages when using MySQL.
When adding the Media Importer Provider...
WARNING <CMediaImportManager>: source "1684470b81be" (emby://62b2788a6dd046efb0168e73724b1f10/) couldn't be added to any import repository
When scanning a movie/tvshow directory
ERROR <general>: CGUIWindowVideoBase::GetResumeItemOffset - Cannot open VideoDatabase
(2020-11-01, 11:11)xxxnelly Wrote: [ -> ]This is the error/warning messages when using MySQL.
That sounds like something went wrong during the database upgrade process and now Kodi can't properly open the video database anymore. So the error would have been somewhere at the beginning of the log or in a previous log when you first started your media import build.
auto library update dosnt work.. i always must restart kodi to update the LIBS
and can i update to alpha 3 ?
A MediaImport build based on Alpha 3 has not been made yet. So unfortunately you won't be able to upgrade yet.
There is a lot of activity in Master now so it may not be the best time for a build. Montellese time is limited so maybe Beta 1 may be a better time for a new build.
Let's see how it goes.
With regards to live updates, it is kind of a known bug. I can't remember if it was in Kodi or the addon.
Edit:
Updates on the server are only synchronized on Kodi startup
(2020-11-08, 02:15)Gee11 Wrote: [ -> ] (2020-11-08, 01:32)LongMan Wrote: [ -> ]A MediaImport build based on Alpha 3 has not been made yet. So unfortunately you won't be able to upgrade yet.
Edit: Updates on the server are only synchronized on Kodi startup
ok i understand, thanks
LongMan thanks for answering for me. I'm currently stuck in a room with Covid-19 to protect the rest of my family.
Unfortunately the issue @
Gee11 ran into is based in Kodi (master) itself and needs to be fixed there. It seems to happen to some users but not others which makes it harder to track down. It doesn't happen on my dev machine but it also happens to @
sualfred. It also affects other add-on scripts / services and not just media import add-ons.
Last I worked on this project I was stuck on a weird database behavior which I haven't figured out yet. It is the last step in resolving issues when removing tvshows / seasons or a full import from Kodi resulting in zombie entries in the database.
(2020-11-11, 11:44)Montellese Wrote: [ -> ]@LongMan thanks for answering for me. I'm currently stuck in a room with Covid-19 to protect the rest of my family.
Sorry to hear that. Hopefully it works out well. These days it seems they have a better idea how to treat it. Have to keep the family safe.
Montellese : Crikey. Good and quick recovery! Everything else can wait...
Montellese,
How is the recovery going? Hoping yours is one with mild symtoms.
Cheers,
LongMan
Gee11,
These are separate concerns. However, I am happy that you found something that works for you.
Cheers,
LongMan
Agreed. Media importer is on a completely different level, as it stays true to the idea of an integrated media center. Add-ons are "just" apps within the Kodi "app" and native apps are increasingly replacing those AND Kodi on many platforms. That's certainly true in the DRM space (Netflix, Prime, Disney+, etc.) and likely unavoidable. But there is an ever increasing amount of legal content, on the internet and remote storage alike, that could be seamlessly integrated into Kodi using the media importer approach. This is the way to go! The only way to go in the bigger scheme of things, if you ask me...
I've seen you being active on github recently, so I hope you are well again @
Montellese. Take your time. I will wait... ;-)
