No the previous one. I mean the one with the older kodi version (17, 18 or 19) but with media import. Cheers!
Update: Just bought a new ethernet cable long enough to plug into my slave unit, Watched two movies yesterday without any issues
(2022-11-11, 21:07)Lockos Wrote: [ -> ]Hi, can you tell how to install the latest test build for Kodi 19.4
This link doesn't seem to be working : https://mirrors.kodi.tv/test-builds/wind...ix-x64.exe
And this build is only source code so no kodi.exe : https://github.com/xbmc/xbmc/releases/tag/19.4-Matrix
, so I'm not sure how to install this, I just wanna test the plex media import feature, could someone help me ?
Thanks in advance
Sorry for the late response and thanks for your interest in my work. Unfortunately the test builds are automatically deleted after a certain amount of time. Furthermore I've moved on to provide test builds for Kodi 20 Alpha instead of 19 stable. But if you tell me which platform you are using I should be able to provide you with a fresh build.
Where can I find test-builds for Kodi 20 Nexus?
The test builds expire after a couple months. Which platform's test builds are you looking? Montellese will run a build as soon as he gets a chance.
Cheers
Ah, ok, thanks. That's why i cant find any test builds. I'm looking for an Android Kodi 20 test build.
@sketpet,
Montellese has been kind enough to run a test build. It is not the latest, it's based on Nexus alpha 2. He will rebase onto a newer branch when he has the time. As you know this is the time of year when work and family demands are greatest. The builds are on the download page
https://github.com/Montellese/xbmc/wiki/...#downloads
Enjoy
LongMan
Thank you! I searched everywhere for download links. Thanks for sharing and thanks to Montellese as well.
Montellese, Can you please rebase onto Nexus final. I want to run a build based on LibreELEC 11.0 final.
Edit: 20.1 is now the latest release. So that should be the base
(2023-03-08, 00:57)LongMan Wrote: [ -> ]@Montellese, Can you please rebase onto Nexus final. I want to run a build based on LibreELEC 11.0 final.
I would appriciate if you could make a build for me after you get it, I'm using a intel NUC, so a generic build. Cheers!
Thank you very much! I don't even know what emby or jellyfin are haha..
What is the difference between the legacy version and the other one?
