Full Version: Media importing and library integration (UPnP, Emby, Plex, ...)
I'm good again. It took a while for my sense of smell to return but I'm guessing it works 80% of the time again.
Unfortunately the combination of Christmas time and ever changing Covid-19 restrictions makes things even more hectic than usual so I haven't found any time to finally figure out what I'm doing wrong in my current rework of the database layout. I hope I'll find some time after Christmas.
Enjoy Christmas time as good as possible and stay healthy.
Good news, indeed! Same to you...   ;-)
@Montellese,
Glad hear that you have weathered that storm.
Could you kick off another for the last released (ie Aplha 2) version or suggest someone who has the rights to do it. The links have expired.
Cheers,
LongMan
(2020-12-13, 01:05)LongMan Wrote: [ -> ]@Montellese,
Cheers,
LongMan
I started new test builds at https://jenkins.kodi.tv/view/Automation/...hoice/494/.
Thank You.
Media Import/Wiki/Downloads have been updated with the links
Happy Holidays to all.
(2020-12-13, 15:56)Montellese Wrote: [ -> ]
This link dont work... can you please tell us when and where can download Matrix beta 2...i want to test how this work with my Plex...thanks :-)
(2021-01-02, 12:13)webmaher Wrote: [ -> ]
 Try https://github.com/Montellese/xbmc/wiki/...#downloads
Edit: There is no Beta 2 yet. Hang in there.
I've done the rebase onto Matrix Beta 2. There were only very few conflicts and they were easy to solve. I've started builds at https://jenkins.kodi.tv/view/Automation/...hoice/497/ but I haven't runtime tested this so beware as always.
@Montellese, Thanks for taking the time.
@webmaher,
Beta 2 has arrived. Check the link below
https://github.com/Montellese/xbmc/wiki/...#downloads has been updated.
Is there anyone following the thread that has experience building LibreELEC and/or CoreELEC? Would appreciate if someone could run Beta 2 builds.
(2021-01-03, 02:21)LongMan Wrote: [ -> ]@Montellese, Thanks for taking the time.
@webmaher,
I cant install mediaimporter.plex from zip file....The dependency on script.module.websocket_client version 0.57.0 could not be satisfied.
https://github.com/Montellese/mediaimporter.plex
The MediaImport repo is included but disabled. Enable it and install from the repo.
@LongMan thanks :-)
But as I see i can add only folder...I cant open folders and browse to add only few movies and series to my library. How can i do that?
Unfortunately I haven't done anything with Plex in quite some time. I probably need to set up a server so that I can give some guidance. I will see what I can setup.
Cheers,
LongMan
