2016-08-04, 08:22
(2016-08-04, 04:45)Ned Scott Wrote: [ -> ]Does SPMC give different results?
I haven't tried. Where is that build for the Hub please?
(2016-07-23, 19:02)jb1977 Wrote: [ -> ]@chrisSo I got my new exchanged device from WeTek (really great and fast support) and everythinh is working fine by now. So it was a hardware problem.. thx for your help
Thx for your answere.
I first notice this problem at stresming from my Server with kodi. Then I checked with speedtest.com my internetconnection. Download only 10 Mbit. Connected with my Wlan: download 75Mbit. Also with a notebook at the same ethernet cable 75 Mbit.
So I suggest, that there is problem with my ethernet port.
(2016-08-04, 11:19)jb1977 Wrote: [ -> ](2016-07-23, 19:02)jb1977 Wrote: [ -> ]@chrisSo I got my new exchanged device from WeTek (really great and fast support) and everythinh is working fine by now. So it was a hardware problem.. thx for your help
(2016-08-04, 12:15)Dave 130R Wrote: [ -> ](2016-08-04, 11:19)jb1977 Wrote: [ -> ](2016-07-23, 19:02)jb1977 Wrote: [ -> ]@chrisSo I got my new exchanged device from WeTek (really great and fast support) and everythinh is working fine by now. So it was a hardware problem.. thx for your help
The after sales of Wetek is indeed excellent, I could return my device without any questions asked. Arrangement for pickup and communications where good and very quick.
LibreELEC:~/.kodi/temp # grep -i cec kodi.log
LibreELEC:~/.kodi/temp # dmesg | grep -i cec
[ 0.000000@0] Kernel command line: rootfstype=ramfs init=/init console=ttyS0,115200 no_console_suspend earlyprintk=aml-uart,0xc81004c0 ramoops.mem_address=0x20000000 ramoops.mem_size=0x100000 ramoops.record_size=0x8000 ramoops.console_size=0x4000 androidboot.selinux=permissive logo=osd1,loaded,0x3f800000,1080p50hz hdmimode=1080p50hz cvbsmode=576cvbs hdmitx=cec0xf androidboot.firstboot=0 androidboot.serialno=A01B01C0000073 mac=E8:18:63:50:CE:CC androidboot.mac=E8:18:63:50:CE:CC boot=/dev/mmcblk0p1 disk=/dev/mmcblk0p2 BOOT_IMAGE=kernel.img console=tty0 consoleblank=0 scaling_governor=hotplug scaling_min_freq=96000 scaling_max_freq=2016000 systemd.show_status=auto
[ 0.000000@0] hdmitx: cec: HDMI hdmi_cec_func_config:0xf
[ 5.489022@0] x9 : 0000007f9aceca20 x8 : 0000000000000116
(2016-08-05, 23:02)Stimmenhotel Wrote: [ -> ]Animes in X264 H10P won't play, according to the table and other tests.Have sample of X265 H10P? Is this one of them?
But I am stumbling across X265 H10P Animes, are they playing?
(2016-08-06, 08:18)mmesh Wrote: [ -> ]Hi,Firstly LG TV's belong in the special needs basket due to non standard custom extensions LG decided to add to the CEC protocol, LG called SimpLink There really is not much we can do when that happens apart from using a previous working version of LE in the interim until AML or the CEC Kernel guys sort out a LG workaround fix.
After updating my WETEK Hub with the LibreELEC-WeTek_Hub.aarch64-7.0.2.Hybrid.CEC.tar I don't have HDMI-CEC any more.
How can I help in debugging this issue?
My TV is LG 42LB730V-ZD and WETEK Hub is directly connected to the HDMI3 while TV has a HDMI connection to the Denon AVR X1100W (HDMI ARC, DD and DTS passthrough is working).
Kodi log is not showing a trace of CEC related messages:
Code:LibreELEC:~/.kodi/temp # grep -i cec kodi.log
while `dmesg` is showing standard line as far as I know:
Code:LibreELEC:~/.kodi/temp # dmesg | grep -i cec
In Kodi I can't access Settings -> System -> Input devices -> Peripherals because it's greyed out.
Some assistance, please.
(2016-08-06, 20:44)hdmkv Wrote: [ -> ]If Anime H264 HiP10 is re-encoded into standard 10bit HEVC then video will play. If these Anime dickheads, decide to to use 12bit then you have no hope.(2016-08-05, 23:02)Stimmenhotel Wrote: [ -> ]Animes in X264 H10P won't play, according to the table and other tests.Have sample of X265 H10P? Is this one of them?
(2016-07-23, 10:49)jb1977 Wrote: [ -> ]Hallo all,Mmmm, my hub was also delivered as one of the 1st. After some initial test playing I couldn't continue testing /setting all up due to real life priorities etc...
I'm new to the forum , but was reading for a long time here.
I also recieved my hub this week and was playing around since then.
All seams decent with some pros and cons, but with potential.
My biggest problem is the performance of the ethernet port. I only get about 10 Mbit. Wlan seams to be ok.
Is there any tweak which I can try for decent ethernet peformance or to I have a broken ethernet port?
PS. I'm under android with latest OTA. Also tried to reset the box.
Thanks.... and what a great and inspiring forum.
Jürgen
