(2020-03-04, 00:26)DjDiabolik Wrote: [ -> ]@phate89 hi..... can you try to a look if works this films ??
"Il Principe Cerca Moglie" goes aired this pass sunday on Italia 1. It's correctly listed but when try to reproduce it it's appear a message on TV say to install somethings called "Widevine inputstream". If you accept to install it's after some seconds another message say to you that need to extract it from "Chrome OS" and it's need about 2.0GB of free space!!!
No wait..... No wait............
From a pc and from a normal browser this films can be found here:
https://www.mediasetplay.mediaset.it/vid...7401000104
This movie is encrypted so you need a login and widevine to decrypt it..you have to follow the instructions, there's no way around it.
(2020-02-14, 02:30)Lelefab Wrote: [ -> ] (2020-01-20, 11:36)micky19 Wrote: [ -> ]sorry for this but is anyone having trouble with the Mediaset play as i can watch Dirette and Programmi tv but when i try to watch films or fiction e serie tv - I press on the tv film i choose and then all you see is a turning wheel and nothing opens up, I have done the correct things such as updates needed and still doesn't work. Could anyone help or advise anything as it has been like this past week.
Regards Micky19
I also having problems with mediaset programs. On the mobile a few days ago I had to login to the mediaset play app to watch the film! but on Kodi I have no idea how to do it!
In the add-on setting syou can set user and password
(2020-03-06, 22:06)gprx Wrote: [ -> ]@phate89
Hi, any update?
What doesn't work?
Hi, any update?
Hi, Mediaset play, I don't see anything anymore the contents are no longer visible.
(2020-03-06, 23:08)phate89 Wrote: [ -> ] (2020-03-06, 22:06)gprx Wrote: [ -> ]@phate89
Hi, any update?
What doesn't work?
(2020-03-07, 21:18)gprx Wrote: [ -> ] (2020-03-06, 23:08)phate89 Wrote: [ -> ] (2020-03-06, 22:06)gprx Wrote: [ -> ]@phate89
Hi, any update?
What doesn't work?
Works fine for me.. do you have a debug log?
(2020-03-07, 22:14)phate89 Wrote: [ -> ] (2020-03-07, 21:18)gprx Wrote: [ -> ] (2020-03-06, 23:08)phate89 Wrote: [ -> ]What doesn't work?
Where can i find the version you are using?
Cheers man, I was using another mediaset play addon (perhaps it was still yours but an older version) and it stopped working for ondemand programs, only worked for live tv.
I installed yours (from abarepo) which gave me a notification in the event log that I need a certain script plus I also installed the repo from github and now all works well.
Both my mom and my sister are very grateful for this app, a life save!
Hi, many ondemand programs are no longer available. Big brother, Live, who wants to be a millionaire. Some idea ?
Hi some programs have season for exemple "Le Iene" has season 2019/2010 and season 2018/2019 but I can't see al seasons from add-on only rhe last one on Mediaset Play app I can see all seasons after login
(2020-03-15, 00:53)nik2143 Wrote: [ -> ]Hi some programs have season for exemple "Le Iene" has season 2019/2010 and season 2018/2019 but I can't see al seasons from add-on only rhe last one on Mediaset Play app I can see all seasons after login
My error I wasn't using the latest beta
Hi!
I've installed the add-on from the official repository, and tried it several times. Everything works except from Live streaming of CANALE 5. It starts to load but then it stops.
Any suggestion?
(2020-03-17, 20:15)ng_4r Wrote: [ -> ]Hi!
Any suggestion?
update to latest beta from phate89 repo.
if live channel not work anyway it's possible... it's changed rapidly and frequently.
probably it's also geo blocked....
Hi I found a big problem in the latest version. Example: If I go to 'Programmi' then 'In Onda' or 'Tutti' and then on 'Stasera Italia' and click on 'Puntate intere' you will find the Episodes go until January and not thew most recents (it is on everyday). Whereas, the previous version (not 'BETA') it works perfectly and gives the most recent (which should be today).
I hope you can solve this problem and I want to also take this moment to thank you for all your hard work you and dedication!
TO phate89
